Install error with newest 1.24 2734
I have used the newest 1.24 with mpjg_streamer and the Orbit AF cam. It works perfect and I've already gained control of the Orbit from within Zoneminder with help from someone else. We have pan tilt and reset working so far, hope to get more working. Actually the person I contacted has been doing all the work, just helping him test it.
Anyway, uvcvideo should work just fine, but the newer mjpg_streamer is money.
This should help you out.
http://www.zoneminder.com/wiki/index.php/Uvc
I'm not sure about phillips, but I have another solution for that. I'll come back when I have it all working.
- zoneminder
- Site Admin
- Contact:
The mjpg_streamer app can either run on the computer hosting zoneminder or run on an external machine for setting up remote camera's. It's actually really handy and I'll be including it in my Live DVD along. I hope to bring a whole new line of equipment that is going to be very inexpensive and can host multiple usb camera's on remote Wireless repeaters.
I've got ahold of the mjpgstreamer control setup for the Orbit cam and included it also in a DVD. I see you posted a new fix for the control settings, I'll release an update for anyone that's already downloaded my DVD and it will automatically bring it up to the newest release.
Sorry, didn't actually mention much about mjpg_streamer. Here is a quick link to get an idea of how it can work with Zoneminder.
http://ubuntuforums.org/showthread.php?t=882863
- zoneminder
- Site Admin
- Contact:
I've confirmed this compile error is occurring with *Ubuntu 8.04.1 (LTS). Commenting out the lines fixed the problems.zoneminder wrote:I have been talking a complete load of b*ll*x it appears, my excuse was that it was late.
The problem files are not ffmpeg but the Video 4 Linux 2 headers. There seems to be more than one version out there, which differ in what they contain. For now commenting out the offending lines is probably the right course of action, it won't affect functionality as those defines are included only for the sake of completeness and are not directly supported anyway.
If you have hit this issue it would be useful to know what distro and version you are running on.
All ubuntu packages are up to date so I'm not sure where to begin on that.
I get similar errors for my uvc cams, I believe the below note from a different topic sums up the problem. uvcvideo cams being V4L2 typically?This built supports uvcvideo driven cams right?tiggy@gecko:~$ sudo zmu -d /dev/video0 -q -v
Error, failed to get channel 0 attributes: Invalid argument
tiggy@gecko:~$
zoneminder wrote:The zmu query function currently only functions on V4L1. I plan to add V4L2 queries when I get time. In the meantime I recommend using v4l-info as it does pretty much the same thing for V4L2 devices anyway.
- zoneminder
- Site Admin
- Contact:
My dev system has just gone up to Fedora 10 but my laptop is Ubuntu 8.10 so I guess the new definitions must have been added quite recently, ie since 8.04.curtishall wrote:I've confirmed this compile error is occurring with *Ubuntu 8.04.1 (LTS). Commenting out the lines fixed the problems.zoneminder wrote:I have been talking a complete load of b*ll*x it appears, my excuse was that it was late.
Phil
This affects older kernels.
I have confirmed it affects 2.6.18 with v4l2 enabled in the kernel build.
Though mine is a different set:
# Multimedia devices
CONFIG_VIDEO_DEV=m
CONFIG_VIDEO_V4L1=y
CONFIG_VIDEO_V4L1_COMPAT=y
CONFIG_VIDEO_V4L2=y
zm_local_camera.cpp:173: error: ‘V4L2_PIX_FMT_YUV565’ was not declared in this scope
zm_local_camera.cpp:174: error: ‘V4L2_PIX_FMT_YUV32’ was not declared in this scope
zm_local_camera.cpp:181: error: ‘V4L2_PIX_FMT_SGBRG8’ was not declared in this scope
zm_local_camera.cpp:182: error: ‘V4L2_PIX_FMT_SBGGR16’ was not declared in this scope
zm_local_camera.cpp:191: error: ‘V4L2_PIX_FMT_SPCA501’ was not declared in this scope
zm_local_camera.cpp:192: error: ‘V4L2_PIX_FMT_SPCA505’ was not declared in this scope
zm_local_camera.cpp:193: error: ‘V4L2_PIX_FMT_SPCA508’ was not declared in this scope
zm_local_camera.cpp:194: error: ‘V4L2_PIX_FMT_SPCA561’ was not declared in this scope
zm_local_camera.cpp:195: error: ‘V4L2_PIX_FMT_PAC207’ was not declared in this scope
zm_local_camera.cpp:196: error: ‘V4L2_PIX_FMT_PJPG’ was not declared in this scope
zm_local_camera.cpp:197: error: ‘V4L2_PIX_FMT_YVYU’ was not declared in this scope
zm_local_camera.cpp:116: error: ‘V4L2_PIX_FMT_RGB444’ was not declared in this scope
zm_local_camera.cpp:149: error: ‘V4L2_PIX_FMT_YUV444’ was not declared in this scope
zm_local_camera.cpp:167: error: ‘V4L2_PIX_FMT_Y16’ was not declared in this scope
zm_local_camera.cpp:168: error: ‘V4L2_PIX_FMT_PAL8’ was not declared in this scope
zm_local_camera.cpp:172: error: ‘V4L2_PIX_FMT_YUV555’ was not declared in this scope
