Here's my error log... (replaced ip address with "deleted")
[Tue Mar 03 09:36:17 2009] [warn] [client deleted] Timeout waiting for outpu t from CGI script /usr/lib/cgi-bin/nph-zms, referer: http://deleted/index .php?view=watch&mid=6
[Tue Mar 03 10:23:11 2009] [error] [client deleted] socket_sendto( /tmp/zms- 597833s.sock ) failed: No such file or directory, referer: http://deleted /index.php?view=event&eid=12715&filter[terms][0][attr]=Archived&filter[terms][0] [op]=%3D&filter[terms][0][val]=0&filter[terms][1][cnj]=and&filter[terms][1][attr ]=DateTime&filter[terms][1][op]=%3E%3D&filter[terms][1][val]=-1+day&filter[terms ][2][cnj]=and&filter[terms][2][attr]=MonitorId&filter[terms][2][op]=%3D&filter[t erms][2][val]=7&sort_field=StartTime&sort_asc=0&page=1
[Tue Mar 03 10:23:11 2009] [error] [client deleted] array (\n 0 => \n arra y (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 51,\n 'function ' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/ zms-597833s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' = > 'require_once',\n ),\n), referer: http://deleted/index.php?view=event& eid=12715&filter[terms][0][attr]=Archived&filter[terms][0][op]=%3D&filter[terms] [0][val]=0&filter[terms][1][cnj]=and&filter[terms][1][attr]=DateTime&filter[term s][1][op]=%3E%3D&filter[terms][1][val]=-1+day&filter[terms][2][cnj]=and&filter[t erms][2][attr]=MonitorId&filter[terms][2][op]=%3D&filter[terms][2][val]=7&sort_f ield=StartTime&sort_asc=0&page=1
