The error seems to be the same:
# cat zm_debug.log.31181
02/16/09 20:14:27.043313 zmc_dvideo0[-1].INF-zm_debug.c/292 [New Debug Level = 9, New Debug Log = /var/log/zm/zm_debug.log.31181]
02/16/09 20:14:27.043473 zmc_dvideo0[-1].DB1-zm_monitor.cpp/1706 [Got 1 monitors]
02/16/09 20:14:27.043516 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/287 [V4L2 support enabled, using V4L2 api]
02/16/09 20:14:27.044804 zmc_dvideo0[-1].DB1-zm_monitor.cpp/338 [monitor purpose=1]
02/16/09 20:14:27.044824 zmc_dvideo0[-1].DB1-zm_monitor.cpp/345 [mem.size=36865524]
02/16/09 20:14:27.044860 zmc_dvideo0[-1].DB1-zm_monitor.cpp/369 [Unable to map file /dev/shm/.zm.mmap.5 (36865524 bytes) to locked memory, trying unlocked]
02/16/09 20:14:27.066349 zmc_dvideo0[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
02/16/09 20:14:27.066598 zmc_dvideo0[-1].DB9-zm_image.cpp/1351 [x1:0,y1:479 x2:0,y2:0]
02/16/09 20:14:27.066612 zmc_dvideo0[-1].DB9-zm_image.cpp/1351 [x1:0,y1:0 x2:639,y2:0]
02/16/09 20:14:27.066622 zmc_dvideo0[-1].DB9-zm_image.cpp/1351 [x1:639,y1:0 x2:639,y2:479]
02/16/09 20:14:27.066633 zmc_dvideo0[-1].DB9-zm_image.cpp/1351 [x1:639,y1:479 x2:0,y2:479]
02/16/09 20:14:27.066649 zmc_dvideo0[-1].DB9-zm_image.cpp/1371 [0: min_y: 0, max_y:479, min_x:0.00, 1/m:-0.00]
02/16/09 20:14:27.066672 zmc_dvideo0[-1].DB9-zm_image.cpp/1371 [1: min_y: 0, max_y:479, min_x:639.00, 1/m:0.00]
02/16/09 20:14:27.066689 zmc_dvideo0[-1].DB9-zm_image.cpp/1385 [Moving global edge]
02/16/09 20:14:27.066703 zmc_dvideo0[-1].DB9-zm_image.cpp/1385 [Moving global edge]
02/16/09 20:14:27.066714 zmc_dvideo0[-1].DB9-zm_image.cpp/1406 [0 - 0: min_y: 0, max_y:479, min_x:0.00, 1/m:-0.00]
02/16/09 20:14:27.066726 zmc_dvideo0[-1].DB9-zm_image.cpp/1406 [0 - 1: min_y: 0, max_y:479, min_x:639.00, 1/m:0.00]
02/16/09 20:14:27.066746 zmc_dvideo0[-1].DB9-zm_image.cpp/1406 [1 - 0: min_y: 0, max_y:479, min_x:0.00, 1/m:-0.00]
02/16/09 20:14:27.152689 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:74, y:479.00]
02/16/09 20:14:27.152700 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:73, y:479.00]
02/16/09 20:14:27.152712 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:72, y:479.00]
02/16/09 20:14:27.152723 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:71, y:479.00]
02/16/09 20:14:27.152734 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:70, y:479.00]
02/16/09 20:14:27.152745 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:69, y:479.00]
02/16/09 20:14:27.152756 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:68, y:479.00]
02/16/09 20:14:27.152768 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:67, y:479.00]
02/16/09 20:14:27.152779 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:66, y:479.00]
02/16/09 20:14:27.152790 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:65, y:479.00]
02/16/09 20:14:27.152801 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:64, y:479.00]
02/16/09 20:14:27.152812 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:63, y:479.00]
02/16/09 20:14:27.152824 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:62, y:479.00]
02/16/09 20:14:27.152835 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:61, y:479.00]
02/16/09 20:14:27.152846 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:60, y:479.00]
02/16/09 20:14:27.152857 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:59, y:479.00]
02/16/09 20:14:27.152868 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:58, y:479.00]
02/16/09 20:14:27.152880 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:57, y:479.00]
02/16/09 20:14:27.152891 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:56, y:479.00]
02/16/09 20:14:27.152902 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:55, y:479.00]
02/16/09 20:14:27.152913 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:54, y:479.00]
02/16/09 20:14:27.152924 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:53, y:479.00]
02/16/09 20:14:27.152935 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:52, y:479.00]
02/16/09 20:14:27.152947 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:51, y:479.00]
02/16/09 20:14:27.152958 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:50, y:479.00]
02/16/09 20:14:27.152969 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:49, y:479.00]
02/16/09 20:14:27.152980 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:48, y:479.00]
02/16/09 20:14:27.152991 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:47, y:479.00]
02/16/09 20:14:27.153003 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:46, y:479.00]
02/16/09 20:14:27.153014 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:45, y:479.00]
02/16/09 20:14:27.153025 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:44, y:479.00]
02/16/09 20:14:27.153036 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:43, y:479.00]
02/16/09 20:14:27.153047 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:42, y:479.00]
02/16/09 20:14:27.153059 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:41, y:479.00]
02/16/09 20:14:27.153070 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:40, y:479.00]
02/16/09 20:14:27.153081 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:39, y:479.00]
02/16/09 20:14:27.153092 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:38, y:479.00]
02/16/09 20:14:27.153103 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:37, y:479.00]
02/16/09 20:14:27.153115 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:36, y:479.00]
02/16/09 20:14:27.153126 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:35, y:479.00]
02/16/09 20:14:27.153137 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:34, y:479.00]
02/16/09 20:14:27.153148 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:33, y:479.00]
02/16/09 20:14:27.153159 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:32, y:479.00]
02/16/09 20:14:27.153170 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:31, y:479.00]
02/16/09 20:14:27.153182 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:30, y:479.00]
02/16/09 20:14:27.153200 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:29, y:479.00]
02/16/09 20:14:27.153214 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:28, y:479.00]
02/16/09 20:14:27.153225 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:27, y:479.00]
02/16/09 20:14:27.153237 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:26, y:479.00]
02/16/09 20:14:27.153248 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:25, y:479.00]
02/16/09 20:14:27.153259 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:24, y:479.00]
02/16/09 20:14:27.153270 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:23, y:479.00]
02/16/09 20:14:27.153281 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:22, y:479.00]
02/16/09 20:14:27.153293 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:21, y:479.00]
02/16/09 20:14:27.153304 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:20, y:479.00]
02/16/09 20:14:27.153315 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:19, y:479.00]
02/16/09 20:14:27.153326 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:18, y:479.00]
02/16/09 20:14:27.153338 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:17, y:479.00]
02/16/09 20:14:27.153349 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:16, y:479.00]
02/16/09 20:14:27.153360 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:15, y:479.00]
02/16/09 20:14:27.153371 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:14, y:479.00]
02/16/09 20:14:27.153382 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:13, y:479.00]
02/16/09 20:14:27.153393 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:12, y:479.00]
02/16/09 20:14:27.153405 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:11, y:479.00]
02/16/09 20:14:27.153416 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:10, y:479.00]
02/16/09 20:14:27.153427 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:9, y:479.00]
02/16/09 20:14:27.153438 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:8, y:479.00]
02/16/09 20:14:27.153450 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:7, y:479.00]
02/16/09 20:14:27.153461 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:6, y:479.00]
02/16/09 20:14:27.153472 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:5, y:479.00]
02/16/09 20:14:27.153483 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:4, y:479.00]
02/16/09 20:14:27.153494 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:3, y:479.00]
02/16/09 20:14:27.153505 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:2, y:479.00]
02/16/09 20:14:27.153516 zmc_dvideo0[-1].DB9-zm_image.cpp/1313 [x:1, y:479.00]
02/16/09 20:14:27.156314 zmc_dvideo0[-1].DB1-zm_monitor.cpp/1808 [Loaded monitor 5(test2), 1 zones]
02/16/09 20:14:27.156329 zmc_dvideo0[-1].INF-zmc.cpp/186 [Starting Capture]
02/16/09 20:14:27.156439 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/348 [Opening video device /dev/video0]
02/16/09 20:14:27.156467 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/354 [V4L2 support enabled, using V4L2 api]
02/16/09 20:14:27.156481 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/359 [Checking video device capabilities]
02/16/09 20:14:27.156500 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/369 [Setting up video format]
02/16/09 20:14:27.156514 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/398 [Setting up request buffers]
02/16/09 20:14:27.156618 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/420 [Setting up 8 data buffers]
02/16/09 20:14:27.156718 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/455 [Configuring video source]
02/16/09 20:14:27.156733 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/636 [Setting up static colour tables]
02/16/09 20:14:27.156750 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/1140 [Priming capture]
02/16/09 20:14:27.156760 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/1144 [Queueing buffers]
02/16/09 20:14:27.156774 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/1160 [Starting video stream]
02/16/09 20:14:29.030984 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/1190 [Pre-capturing]
02/16/09 20:14:29.031009 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/1237 [Capturing]
02/16/09 20:14:29.031023 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/1260 [Capturing 1 frames]
02/16/09 20:14:29.200952 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/1284 [Captured frame 0/1 from channel 0]
02/16/09 20:14:29.200972 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/1320 [Doing format conversion[swscaler @ 0x806de10]No accelerated colorspace conversion found.
02/16/09 20:14:29.201157 zmc_dvideo0[-1].INF-zm_signal.cpp/60 [Got signal 11 (Segmentation fault), crashing]
02/16/09 20:14:29.201192 zmc_dvideo0[-1].ERR-zm_signal.cpp/77 [Signal address is 0x10212, no eip]
02/16/09 20:14:29.201395 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /lib/libpthread.so.0 [0x7f40844237b0]]
02/16/09 20:14:29.201416 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/lib/libswscale.so.0 [0x7f4085d64e00]]
02/16/09 20:14:29.201435 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/lib/libswscale.so.0(sws_scale+0x590) [0x7f4085d55240]]
02/16/09 20:14:29.201452 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc [0x41bf85]]
02/16/09 20:14:29.201469 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc [0x424786]]
02/16/09 20:14:29.201486 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc [0x4068ea]]
02/16/09 20:14:29.201502 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /lib/libc.so.6(__libc_start_main+0xe6) [0x7f40832fd5a6]]
02/16/09 20:14:29.201518 zmc_dvideo0[-1].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc [0x406249]]
02/16/09 20:14:29.201535 zmc_dvideo0[-1].INF-zm_signal.cpp/99 [Backtrace complete]
# gdb /usr/local/bin/zmc
GNU gdb (GDB) 6.8.50.20090106-cvs-debian
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
For bug reporting instructions, please see:
<http>...
(gdb) run -d /dev/video0
Starting program: /usr/local/bin/zmc -d /dev/video0
[Thread debugging using libthread_db enabled]
[swscaler @ 0x60fbea0]No accelerated colorspace conversion found.
Program received signal SIGSEGV, Segmentation fault.
yuv2rgb_c_24_rgb (c=0x60fbea0, src=0x7fffffffe450, srcStride=0x7fffffffe470,
srcSliceY=<value>, srcSliceH=480, dst=0x60f9aa0, dstStride=0x7fffffffe480)
at libswscale/yuv2rgb.c:198
198 RGB(0);
Current language: auto; currently c
(gdb) bt
#0 yuv2rgb_c_24_rgb (c=0x60fbea0, src=0x7fffffffe450, srcStride=0x7fffffffe470,
#1 0x00007ffff79b9240 in sws_scale (c=0x60fbea0, src=<value>, srcStride=0x60e13d0, srcSliceY=
0, srcSliceH=480, dst=0x60f9aa0, dstStride=0x60f9ac0) at libswscale/swscale.c:2805
#2 0x000000000041bf85 in LocalCamera::Capture (this=0x60e7390, image=@0x60e7520) at zm_local_camera.cpp:1342
#3 0x0000000000424786 in Monitor::Capture (this=0x60e73f0) at zm_monitor.cpp:2470
#4 0x00000000004068ea in main (argc=<value>, argv=0x7fffffffe778) at zmc.cpp:256
