Foscam FI8908W IP Camera with PT (no Z) Working in ZM 1.24.2
I'm having a hard time to get it running.. To debug it I try to run it from the commandline:
/usr/bin/zmcontrol.pl --id=9 --command=moveConDown
It fails with:
Can't connect: Connection refused at /usr/lib/perl5/vendor_perl/5.10.0/ZoneMinder/Debug.pm line 349
ZoneMinder::Debug::Fatal('Can\'t connect: Connection refused') called at /usr/bin/zmcontrol.pl line 158
I would like to get it running and extend the script with preset locations (approximately with timed moves), brightness and contrast controls, mirroring etc.
update: still haven't got it running, but my PID file was corrupted. I had a line...
$ENV{LD_PRELOAD} = '/usr/lib/libv4l/v4l2convert.so';
...added to my zmdc.pl file for a usb webcam, this caused the pid file to contain:
Still doesn't solve my problems
Update: Got it working. Hint: zmcontrol.pl keeps running, when making changes in the script first do a killall zmcontrol.pl.
I'm working on an updated version of the script.
It fails with:
19863ERROR: ld.so: object '/usr/lib/libv4l/v4l2convert.so' from LD_PRELOAD cannot be preloaded: ignored.
Put the IP-address of your camera in the 'control address field'.
Have you editted all name/password entries in the .pm file?
Diagnosing:
First try to execute the control command from the commandline. For example:
/usr/bin/zmcontrol.pl --id=1 --command=moveConUp
Where 1 = your monitor ID. If something is wrong it probably says so on standard out. Also check the zmcontrol.log
If you see something like:
or
Then first do a killall -9 zmcontrol.pl
Then select the 'Panasonic IP' control type
Execute /usr/bin/zmcontrol.pl --id=1 --command=moveConUp again
It won't move your camera, but if zmcontrol.pl doesn't report anything, the problem is most probably in your 'Foscam FI8908W.pm' script
Best way is to use the 'Panasonic IP.pm' script and start over again: copy everything from the Foscam script, line by line. After every change to the script killall zmcontrol.pl!
Some other hints
Check if your /var/run/zm/zm.pid contains the correct process id (try restarting zm). And check if /var/run/control socket files exist (I forgot the correct names, because I now also have problems with it
To check your script, try:
Diagnosing:
Can't connect: No such file or directory at /usr/lib/perl5/vendor_perl/5.10.0/ZoneMinder/Debug.pm line 349
ZoneMinder::Debug::Fatal('Can\'t connect: No such file or directory') called at /usr/bin/zmcontrol.pl line 154
Some other hints
perl /usr/lib/perl5/vendor_perl/5.10.0/ZoneMinder/Control/FoscamFI8908W.pm
Managed to get it working earlier today. The fixing change was adding the IP address of the camera to the "Control Address" field in the camera settings. The KEY is running
EVERY time you make a change to see if it is working!
Of course after I got it working by running the script manually I ran into the "can't bind: address already in use" error but that was quickly fixed with the link below.
http://www.zoneminder.com/forums/viewto ... 425a008d13
Thanks for all of the help!
First i 'd like to thank the autor of the topic witch was very helpfull !
I was able to make work my foscam at the first time.
Just two little thing to solve.
- pan and tilt comand make move the camera until i hit the central control buton. in the foscam website, camera stop moving immediately when i stop to hit control buton. I d like to have the same in zm.
- how to reduce the streaming delay. zm picture arrive about 15 seconde later as the reality. that mean, when i hit a control comand, i have to wait 15 to see the new position. how to reduce this delay ?
thx
Chris.
thx
Chris.
Good work mbrinkho, some stuff there i wasn’t aware of, learn something new every day!
Chris, my setup is like yours and keeps panning/tilting until the stop command is sent, i actually preferred it this way and so haven’t looked to change it. I guess you could alter the Perl script to auto send a stop command after each move and make it more like the ipcamera site, but i haven’t tried this.
I also have a delay, but only around 1 - 1.5 seconds, which can make the panning/tilting a bit tricky sometimes. there could be a few factors for this if they are wireless cameras there will be a slight lag, if your machine is also wireless there would be a bit more lag. I would suspect that the computer would be the main reason for it being slow or network congestion, although this is a guess. I wonder if anyone else suffers from similar delays?
Hi dave, and thank for your answer.
I will try to modify perl script like you say... it's a good idea. In fact i was wondering, if if the way the camera still move was normal...
For the delay question, it's correct when i connect from my lan.
I had not precised it in my previous post, if i connect with my internet connection, i have about 10 to 15s delay.
If I VPN in from work, i probably get about a 3-4 second delay, depending on traffic. You could possbily lower the frame rate and resolution to try and combat this delay?
My system is offline atm whilst I do some work on fitting the cameras in more permanent positions, although im undecided where they are going so its not going to well lol
Let me know how you get on though. Cheers
Revision for HooToo IPCam
OK, so I didn't do my research terribly well and got stuck with a couple of these Foscam clones sold by an outfit known as HooToo.com. I had some trouble figuring out how to get the PT(no Z) controls to work with this camera. I initially used the scripts that Phillip Combes had posted without too much luck. I then invited some help from a programmer friend of mine, Steve Campbell. Here's what he came up with:
Enjoy and Use the Source!
# ZoneMinder HooToo IP Camera Control Protocol Module
# Copyright (C) 2010 Steven M Campbell
# This module contains the implementation of the HooToo IP camera control
# protocol. It was adapted from control protocol's written by Phillip Combes.
package ZoneMinder::Control::HooTooIPCam;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# HooTooIPCam Control Protocol
sub new {
my $class = shift;
my $id = shift;
Debug( "Camera New" );
bless( $self, $class );
return $self;
our $AUTOLOAD;
sub AUTOLOAD {
my $self = shift;
my $name = $AUTOLOAD;
Debug( "Camera AUTOLOAD" );
$name =~ s/.*://;
if ( exists($self->{$name}) ) {
return( $self->{$name} );
# You can change the user and password here for all control commands
my $user = "admin";
my $pwd = "";
# The basic decoder_control url just to make the below commands table easy
# to read
my $decoder = "decoder_control.cgi?user=$user&pwd=$pwd";
# Instead of writing a bunch of individual routines lets make real
# autoloader, we'll just look up the requested command in this table
# and send the corresponding url string
my %commands = (
'Up' => "$decoder&command=1",
'Down' => "$decoder&command=3",
'Left' => "$decoder&command=5",
'Right' => "$decoder&command=7",
'moveConUp' => "$decoder&command=1",
'moveConDown' => "$decoder&command=3",
'moveConLeft' => "$decoder&command=5",
'moveConRight' => "$decoder&command=7",
'moveStop' => "$decoder&command=2",
'presetHome' => "$decoder&command=25",
'reset' => "reboot.cgi?user=$user&pwd=$pwd",
'cameraReset' => "reboot.cgi?user=$user&pwd=$pwd"
# If the command exists in the table then we send it's url string
if (exists($commands{$name})) {
return($self->sendCmd($commands{$name}));
# Otherwise we fail
sub open {
my $self = shift;
$self->loadMonitor();
Debug( "Camera open" );
use LWP::UserAgent;
$self->{state} = 'open';
sub close {
my $self = shift;
$self->{state} = 'closed';
sub printMsg {
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd {
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
my $req = HTTP::Request->new(
GET=>"http://".$self->{Monitor}->{ControlAddress}."/$cmd" );
if ( $res->is_success ) {
$result = !undef;
else {
return( $result );
1;
__END__
=head1 NAME
ZoneMinder::Control::HooTooIPCam - Perl extension to zoneminder to implement
the control protocol for the HooToo IP Camera
=head1 SYNOPSIS
use ZoneMinder::Control::HooTooIPCam;
=head1 DESCRIPTION
An implementation of the control protocol for the HooToo IP Camera for
zoneminder.
=head1 EXPORT
None by default.
=head1 SEE ALSO
ZoneMinder
ZoneMinder::Control
=head1 AUTHOR
Steven M Campbell
=head1 COPYRIGHT AND LICENSE
Copyright (C) 2010 by Steven M Campbell
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
Rev Eggplant
Newb questions about configuring a HooToo camera
I managed to buy two of these Hootoo cameras myself... I was hoping that someone here could help me get ZM configured to use them.
I've put the module provided above in place, but I can't even get video/images from them, so I'll let the control aspect wait on that.
My monitor settings are:
General
source type: remote
function: monitor
enabled: checked
max fps: 10 or blank (no difference)
alarm max fps: 10 or blank (no difference)
ref image blend: 7
Source
protocol: http
method: simple
host name: 192.168.1.30
host port: 80 (this is correct)
host path: /videostream.cgi (tried this with user/pass also)
host subpath: <blank>
colours: 24 bit
width: 640
height: 480
Everything else left with defaults
I appreciate any help you can give!
General
source type: remote
function: monitor
enabled: checked
ref image blend: 7
Source
protocol: http
method: simple
colours: 24 bit
width: 640
height: 480
Re: Newb questions about configuring a HooToo camera
Happy to help!sraasch wrote:I managed to buy two of these Hootoo cameras myself... I was hoping that someone here could help me get ZM configured to use them.
General
source type: remote
function: monitor
enabled: checked
ref image blend: 7
Source
protocol: http
method: simple
colours: 24 bit
width: 640
height: 480
Change your settings to as follows:
host path: /videostream.cgi?user=admin&pwd=&resolution=8
This assumes that your admin username hasn't been changed nor a password added.
Change your width/height to 320/240 (change to resolution=32 for 640 x 480).
Holler with what results you end up with, and then we can tackle controls further.
Rev Eggplant
