I should note that my ZM is set to the default V4L version2 and I do not enable alarm but record images all the time. It is a company site and the linux box routes internet&VPN at the same time. That is why I need DVR to run under linux and cannot use the old HICAP50 board. Hope CPU capacity will not be exceeded with 8 cameras at high resolulion.
The 15 fps which You set is actually a kind of upper limit, what is the view speed while watching a monitor or montage? I set 2-3 fps in Monitor-General, but under each monitor in Montage view in streaming mode on Mozilla I read "0.96fps". I think that Captures_per_frame states the missed frames between two captures, which allow correct multiplexing of several camera streams, connected to one chip. With my value of 2 it means that the total number of processed frames is 8 cameras* (1frame captured + 2 frames missed) = 24 fps. I presume this is the result of using just one of the 4 chips on the DVR card. 3-4 fps is quite enough for my job, hope I can reach that speed by actually using all 4 chips. The box has 1GB RAM and I have set 512MB to shared memory. After finalizing it I will post a detailed report.
HICAP50 DVR board is discarded to a friend's farm
