Ok, i set up some remote access if anyone wants to check it out and give it a try/give me some suggestions.
First - here is the address to my camera:
http://linuxmce.homelinux.com:8201
(username: guest, password: guest)
and here is the path directly to the mjpeg stream:
http://linuxmce.homelinux.com:8201/video1.mjpg
At this point, you should see that A) my IP camera works, and B) I know the proper path the MJPEG stream
Now, check out my ZM page:
http://linuxmce.homelinux.com:8200/zoneminder
(username:guest, password:guest)
(Guest account can edit monitors)
Now, you will see that zoneminder simply won't display the mjpeg steam!
If anyone can help, I would greatly appreciate it!
(I am 10000000% sure of the paths, I know this IP server inside and out)
Can't get video stream
Finally! Got it working!
In my Vivotek settings, the resolution was set to 352 x 240 - but in zoneminder, I was trying to capture at 320x240. I changed my ZM setup to capture at 352x240 and now all is good!
I do have a question now, though.... I was unaware that the capture resolution in ZM had to match exactly the resolution of the camera (otherwise, wouldn't the aspect ratio option be redundant, as if they have to be the same then of course the aspect ratio would be the same). So is the case, will I always have to exactly match the resolution of the MJPEG stream?
thanks
thanks
