Not show the events
bb99
Re: Not show the events
Post by bb99 »
I see your apache2.conf refers to include user configuration in httpd.conf:
Include httpd.conf
Please post httpd.conf file contents; I believe this i where Cordel suggested to append
FollowSymLinks
to the
Options Indexes
entry or you may have to create the section:
<Directory>
Francisconi
Post by Francisconi »
I open my httpd.conf and insert this:
<Directory>
And not run. See the printscreen attached...
Francisconi
See my httpd.conf:
<Directory /media/cameras/cameras/events>
</Directory>
and the result this on image attache. NOT SHOW THE EVENTS RECORDED...
ScreenShot005 (512 x 384).jpg (35.11 KiB) Viewed 3759 times
Francisconi
This is a part of my error.log in /var/log/apache2/
Mon Jul 25 13:41:00 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:03 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:03 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:06 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:06 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:09 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:09 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:13 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:13 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:16 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:16 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:19 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:19 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:22 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:22 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:26 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:26 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:29 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:29 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:32 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:32 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:35 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:35 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:39 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:39 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:42 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:42 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:45 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:45 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:48 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:48 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:52 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:52 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:55 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:55 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:58 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:41:58 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:02 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:02 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:05 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:05 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:08 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:08 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:11 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:11 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:15 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:15 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:18 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:18 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-974722s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:21 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:21 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-576348s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:24 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:24 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-800931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:28 2011] [error] [client 192.168.1.106] socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:42:28 2011] [error] [client 192.168.1.106] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-037142s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
[Mon Jul 25 13:45:04 2011] [error] [client 192.168.1.106] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Mon Jul 25 13:59:33 2011] [error] [client 192.168.1.106] PHP Notice: session_start(): ps_files_cleanup_dir: opendir(/var/lib/php5) failed: Permission denied (13) in /usr/share/zoneminder/index.php on line 77, referer: http://187.22.188.31:8000/zm/index.php? ... ge&group=0
bb99
Post by bb99 »
Francisconi
bb99
Thanks for you help, but not run yet.
I click with the right button mouse on the image breaked on windows events and copy the adress, see this:
http://187.22.188.31:8000/cgi-bin/nph-z ... 1311681291
Francisconi
This is last errors in the error.log:
[Tue Jul 26 09:07:51 2011] [error] [client 192.168.1.100] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 823, referer: http://187.22.188.31:8000/zm/index.php? ... [0][val]=4
[Tue Jul 26 09:07:51 2011] [error] [client 192.168.1.100] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 828, referer: http://187.22.188.31:8000/zm/index.php? ... [0][val]=4
[Tue Jul 26 09:07:54 2011] [error] [client 192.168.1.100] socket_sendto( /tmp/zms-989021s.sock ) failed: No such file or directory, referer: http://187.22.188.31:8000/zm/index.php? ... c=1&page=1
[Tue Jul 26 09:07:54 2011] [error] [client 192.168.1.100] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-989021s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... c=1&page=1
Francisconi
The problem is here, is not it??
[Tue Jul 26 09:07:54 2011] [error] [client 192.168.1.100] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-989021s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://187.22.188.31:8000/zm/index.php? ... 303&filter[terms][0][attr]=MonitorId&filter[terms][0][op]=%3D&filter[terms][0][val]=4&sort_field=StartTime&sort_asc=1&page=1
Francisconi
Anybody have a tip for this?
