Interesting picture
mikb
Re: Interesting picture
Post by mikb »
mcll wrote:Yes i think it's a datat corruption. But why, what's causing it? :)
Is there anything that might be upsetting your network in general, making it busy, dropped packets, a WIFI link anywhere that may be getting jammed out?
mcll
Post by mcll »
No. As i said it before camera and server are on the same local Network. Network is a Gigabit system (switches also), camera uses only 100mbit (WiFi is not used between camera and server). Network is not overloaded. Servers load is between 1 and 2, which is normal for a 2 core Linux system. When i watch in ZM the camera i did not recognize such jerky pictures.
Now i try to play with the jpeg quality settings in ZM.
Greetings,
Laszlo
Ubuntu Server 14.04.3LTS 64bit - ZoneMinder v1.32.3 - 2x AV-Tech AVN257 IP Cam; 1x Hikvision DS-2CD2020F-I IP Cam
This looks to me to be the same ffmpeg issue as this:
http://www.zoneminder.com/forums/viewto ... 30&t=21911
Either way, your camera would make a great candidate for the new "libvlc" method in the upcoming 1.27 release. It should be a drop-in replacement for ffmpeg, at least we hope.
You can help test and provide feedback:
https://github.com/ZoneMinder/ZoneMinde ... lease-1.27
