ZoneMinder 1.27 remote camera orange, but no picture?
eiger3970
Re: ZoneMinder 1.27 remote camera orange, but no picture?
Post by eiger3970 »
Thanks, I think that moved the issue forward a step.
Now, ZoneMinder shows an icon of a broken image, suggesting the camera data is trying to load via ZoneMinder, but not succeeding.
So, my current ZoneMinder settings with your suggestions are:
ZoneMinder > Source > General >
Source Type: Remote
Function: Monitor
Enabled: ticked
Linked Monitors: Security_camera
Maximum FPS: blank
Alarm Maximum FPS: blank
Reference Image Blend %ge: 6.25% (Indoor)
Alarm Reference Image Blend %ge: 3.125%
Triggers: None available.
> Source >
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: Camera IP address
Remote Host Port: 88
Remote Host Path: /videostream.cgi?user=<cameraUserName>&pwd=<cameraPassword>
Target Colorspace: 24 bit colour
Capture Width (pixels): 640
Capture Height (pixels): 480
Preserve Aspect Ratio: unticked
Orientation: Normal
Deinterfacing: Disabled
Just checked the ZoneMinder camera 5 minutes later, and now shows the same red screen, rather than the broken image icon.
hesral
Post by hesral »
What does the log say now?
eiger3970
Post by eiger3970 »
Just checked, and now ZoneMinder is showing picture.
I didn't change anything? Seems to have magically fixed itself (maybe be restarting itself?)
The Log now says:
Message File Line
Security_camera: 60000 - Capturing at 12.82 fps zm_monitor.cpp 2783
Error log up to 2014-07-03 08:10:45.754334 was:
Unable to capture image, retrying.
Connection dropped by remote end.
Select timed out.
Unable to get response.
Error log at 2014-07-03 08:10:57.491790 was:
Restarting capture daemon for Security_camera, time since last capture 12 seconds (1404335457-1404335445)
Error log at 2014-07-03 08:10:58.143560 was:
'zmc -m 1' stopping at 14/07/03 07:10:58
Error log at 2014-07-03 08:10:58.238770 was:
Got signal 15 (Terminated), exiting
Error log at 2014-07-03 08:11:04.291220 was:
Can't find child with pid of '1101'
Error log at 2014-07-03 08:11:04.294920 was:
'zmc -m 1' crashed, signal 8
Error log at 2014-07-03 08:11:04.407350 was:
Starting pending process, zmc -m 1
Error log at 2014-07-03 08:11:04.563760 was:
'zmc -m 1' starting at 14/07/03 07:11:04, pid = 1837
Error log at 2014-07-03 08:11:04.569080 was:
'zmc -m 1' started at 14/07/03 07:11:04
Error log at 2014-07-03 08:11:05.258091 was:
Starting capture.
That's good, now I can get on with figuring out the recording settings for the PTZ camera.
Hope I don't don't get 1000's of false positives and email notifications ;-)
hesral
Post by hesral »
Great that you got it to work:) I have noe experience with ptz, so you should make a new thread for that one...
