ZM Update from PPA problems 14FEB15
tyler_h
Re: ZM Update from PPA problems 14FEB15
Post by tyler_h »
Just installed and tested, everything is back to normal!
Iconnor, I'm sure you get the most attention when something fucks up, but I'd like to say thank you for all the hard work and effort you put into your part for Zoneminder. I love the program and love the people that work to keep it running!
Thanks so much!!!
new packages are available that should fix the 1.28.0 problem.
It works! Upgraded my test platform with no issues. Now to wait for the 1 TB drive in my production machine to finish deleting events so I can reinstall ZM. At least I did not have to make the 30 mile trip in zero degree (F) weather to the location of the server and wait all day for files to get cleaned up!
Will double check the easy how-to on the WIKI for changes...
bb
