Here is the info you have requested. This is a start up with a few more lines for good measure!
There is no image moving or stationary, almost every location an image should appear it is missing. The montage for example is a window that allows space in my case for two images. They do not appear the headings text boxes and legends appear as they should. The picture is simply missing. I can note however that there is no info provided for the fps which does show up in the log. All other windows likewise show the proper info with space for an image that does not exist.
Timeline does show a small image. but event playback does not.
Could there be a password problem? i did have some trouble when i modified the default password. But changing it in other locations seemed to cure it..
Thanks george....
Updated: Sat 21st Nov, 5:54pm State: alert Total: 393263 Available: 393263 Displaying: 116
Filter log - Component
PID Level File Line
Date/Time
Component PID Level Message File Line
2015-11-21 17:54:03.485894 zma_m4 3652 INF Driveway: 3000 - Processing at 10.20 fps zm_monitor.cpp 1160
2015-11-21 17:54:02.973163 zmc_m4 4211 INF Driveway: 3000 - Capturing at 10.20 fps zm_monitor.cpp 2907
2015-11-21 17:53:51.489865 zma_m2 3564 INF Barn: 3000 - Processing at 10.20 fps zm_monitor.cpp 1160
2015-11-21 17:53:50.132569 zmc_m2 3543 INF Barn: 3000 - Capturing at 10.20 fps zm_monitor.cpp 2907
2015-11-21 17:52:25.301426 zma_m4 3652 INF Driveway: 2000 - Processing at 10.10 fps zm_monitor.cpp 1160
2015-11-21 17:52:24.806783 zmc_m4 4211 INF Driveway: 2000 - Capturing at 10.10 fps zm_monitor.cpp 2907
2015-11-21 17:52:13.386314 zma_m2 3564 INF Barn: 2000 - Processing at 10.20 fps zm_monitor.cpp 1160
2015-11-21 17:52:12.012862 zmc_m2 3543 INF Barn: 2000 - Capturing at 10.10 fps zm_monitor.cpp 2907
2015-11-21 17:50:46.164201 zma_m4 3652 INF Driveway: 1000 - Processing at 9.17 fps zm_monitor.cpp 1160
2015-11-21 17:50:45.598238 zmc_m4 4211 INF Driveway: 1000 - Capturing at 10.10 fps zm_monitor.cpp 2907
2015-11-21 17:50:35.158308 zma_m2 3564 INF Barn: 1000 - Processing at 10.10 fps zm_monitor.cpp 1160
2015-11-21 17:50:33.823156 zmc_m2 3543 INF Barn: 1000 - Capturing at 10.20 fps zm_monitor.cpp 2907
2015-11-21 17:50:00.419346 zma_m4 3652 INF Driveway: 535 - Opening new event 306, section start zm_monitor.cpp 1405
2015-11-21 17:50:00.276148 zma_m2 3564 INF Barn: 645 - Opening new event 305, section start zm_monitor.cpp 1405
2015-11-21 17:50:00.049842 zma_m2 3564 INF Barn: 645 - Closing event 303, section end zm_monitor.cpp 1385
2015-11-21 17:50:00.046928 zma_m4 3652 INF Driveway: 535 - Closing event 304, section end zm_monitor.cpp 1385
2015-11-21 17:49:13.163205 zma_m4 3652 INF Driveway: 059 - Left alarm state (304) - 33(8) images zm_monitor.cpp 1507
2015-11-21 17:49:10.786410 zma_m4 3652 INF Driveway: 034 - Gone into alert state zm_monitor.cpp 1500
2015-11-21 17:49:09.973740 zma_m4 3652 INF Driveway: 026 - Gone into alarm state zm_monitor.cpp 1444
2015-11-21 17:49:09.923539 zma_m4 3652 INF Driveway: 026 - Opening new event 304, section start zm_monitor.cpp 1405
2015-11-21 17:49:06.485661 zmc_m4 4211 INF Starting Capture zmc.cpp 195
2015-11-21 17:49:06.235050 zmdc 4211 INF 'zmc -m 4' started at 15/11/21 17:49:06 zmdc.pl
2015-11-21 17:49:06.234970 zmdc 3279 INF 'zmc -m 4' starting at 15/11/21 17:49:06, pid = 4211 zmdc.pl
2015-11-21 17:49:06.080410 zmdc 3279 INF Starting pending process, zmc -m 4 zmdc.pl
2015-11-21 17:49:01.235936 zma_m4 3652 INF In mode 5/1, warming up zma.cpp 105
2015-11-21 17:49:01.148650 zmdc 3279 ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
2015-11-21 17:49:01.073135 zmc_m4 3633 INF Terminating Logger zm_logger.cpp 236
2015-11-21 17:49:00.985070 zmwatch 3879 INF Watchdog pausing for 30 seconds zmwatch.pl
2015-11-21 17:49:00.939910 zmdc 3966 INF 'zmupdate.pl -c' started at 15/11/21 17:49:00 zmdc.pl
2015-11-21 17:49:00.936930 zmdc 3279 INF 'zmupdate.pl -c' starting at 15/11/21 17:49:00, pid = 3966 zmdc.pl
2015-11-21 17:49:00.925540 zmwatch 3879 INF Watchdog starting zmwatch.pl
2015-11-21 17:49:00.909932 zmc_m4 3633 ERR Failed to pre-capture monitor 4 (0/1) zmc.cpp 260
2015-11-21 17:49:00.847116 zmc_m4 3633 ERR Unable to connect to camera zm_remote_camera_http.cpp 1148
2015-11-21 17:49:00.775950 zmc_m4 3633 ERR Unable to connect to the remote camera, aborting zm_remote_camera_http.cpp 115
2015-11-21 17:49:00.749459 zmc_m4 3633 WAR Can't connect to remote camera: No route to host zm_remote_camera_http.cpp 106
2015-11-21 17:49:00.507020 zmaudit 3813 INF closing zmaudit.pl
2015-11-21 17:49:00.428160 zmaudit 3813 INF Found open event '302' zmaudit.pl
2015-11-21 17:49:00.128720 zmfilter 3755 INF Scanning for events zmfilter.pl
2015-11-21 17:48:59.868697 zma_m4 3652 WAR Waiting for capture daemon zm_monitor.cpp 486
2015-11-21 17:48:59.845750 zmdc 3879 INF 'zmwatch.pl' started at 15/11/21 17:48:59 zmdc.pl
2015-11-21 17:48:59.842910 zmdc 3279 INF 'zmwatch.pl' starting at 15/11/21 17:48:59, pid = 3879 zmdc.pl
2015-11-21 17:48:59.334833 zma_m2 3564 INF Barn: 026 - Opening new event 303, section start zm_monitor.cpp 1405
2015-11-21 17:48:58.888980 zmdc 3279 INF 'zmaudit.pl -c' starting at 15/11/21 17:48:58, pid = 3813 zmdc.pl
2015-11-21 17:48:58.886650 zmdc 3813 INF 'zmaudit.pl -c' started at 15/11/21 17:48:58 zmdc.pl
2015-11-21 17:48:58.819102 zma_m4 3652 WAR Waiting for capture daemon zm_monitor.cpp 486
2015-11-21 17:48:58.112060 zmdc 3755 INF 'zmfilter.pl' started at 15/11/21 17:48:58 zmdc.pl
2015-11-21 17:48:58.109890 zmdc 3279 INF 'zmfilter.pl' starting at 15/11/21 17:48:58, pid = 3755 zmdc.pl
2015-11-21 17:48:57.731266 zma_m4 3652 WAR Waiting for capture daemon zm_monitor.cpp 486
2015-11-21 17:48:57.299513 zmc_m4 3633 INF Starting Capture zmc.cpp 195
2015-11-21 17:48:57.109713 zma_m2 3564 INF In mode 5/1, warming up zma.cpp 105
2015-11-21 17:48:56.825260 zmdc 3652 INF 'zma -m 4' started at 15/11/21 17:48:56 zmdc.pl
2015-11-21 17:48:56.821140 zmdc 3279 INF 'zma -m 4' starting at 15/11/21 17:48:56, pid = 3652 zmdc.pl
2015-11-21 17:48:56.586080 zmdc 3633 INF 'zmc -m 4' started at 15/11/21 17:48:56 zmdc.pl
2015-11-21 17:48:56.580780 zmdc 3279 INF 'zmc -m 4' starting at 15/11/21 17:48:56, pid = 3633 zmdc.pl
2015-11-21 17:48:56.521980 zmdc 3279 INF Starting pending process, zmc -m 4 zmdc.pl
2015-11-21 17:48:56.485550 zmdc 3279 ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
2015-11-21 17:48:56.346480 zmdc 3608 INF 'zmc -m 4' started at 15/11/21 17:48:56 zmdc.pl
2015-11-21 17:48:56.343580 zmdc 3279 INF 'zmc -m 4' starting at 15/11/21 17:48:56, pid = 3608 zmdc.pl
2015-11-21 17:48:56.067857 zma_m2 3564 WAR Waiting for capture daemon zm_monitor.cpp 486
2015-11-21 17:48:55.908501 zmc_m2 3543 INF Starting Capture zmc.cpp 195
2015-11-21 17:48:55.861950 zmdc 3564 INF 'zma -m 2' started at 15/11/21 17:48:55 zmdc.pl
2015-11-21 17:48:55.849080 zmdc 3279 INF 'zma -m 2' starting at 15/11/21 17:48:55, pid = 3564 zmdc.pl
2015-11-21 17:48:55.634970 zmdc 3543 INF 'zmc -m 2' started at 15/11/21 17:48:55 zmdc.pl
2015-11-21 17:48:55.628870 zmdc 3279 INF 'zmc -m 2' starting at 15/11/21 17:48:55, pid = 3543 zmdc.pl
2015-11-21 17:48:55.592010 zmdc 3279 INF Starting pending process, zmc -m 2 zmdc.pl
2015-11-21 17:48:55.559440 zmdc 3279 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2015-11-21 17:48:55.335540 zmdc 3514 INF 'zmc -m 2' started at 15/11/21 17:48:55 zmdc.pl
2015-11-21 17:48:55.331030 zmdc 3279 INF 'zmc -m 2' starting at 15/11/21 17:48:55, pid = 3514 zmdc.pl
2015-11-21 17:48:51.930380 zmdc 3279 INF Server starting at 15/11/21 17:48:51 zmdc.pl
2015-11-21 17:48:50.560740 zmpkg 3062 INF Command: start zmpkg.pl
2015-11-21 14:53:11.081932 zma_m2 3624 INF Terminating Logger zm_logger.cpp 236
2015-11-21 14:53:07.343227 zma_m2 3624 INF Barn: 186688 - Closing event 301, reloading zm_monitor.cpp 1650
2015-11-21 14:53:06.276176 zma_m2 3624 INF Got signal 1 (Hangup), reloading zm_signal.cpp 34
2015-11-21 14:53:05.742995 zma_m2 3624 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2015-11-21 14:53:05.742578 zma_m4 3722 INF Got signal 1 (Hangup), reloading zm_signal.cpp 34
2015-11-21 14:53:05.488492 zma_m4 3722 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2015-11-21 14:53:04.992050 zmdc 3335 INF 'zma -m 4' stopping at 15/11/21 14:53:04 zmdc.pl
2015-11-21 14:52:46.761648 zma_m4 3722 INF Driveway: 180000 - Processing at 10.42 fps zm_monitor.cpp 1160
2015-11-21 14:52:00.165155 zma_m2 3624 INF Barn: 186000 - Processing at 10.42 fps zm_monitor.cpp 1160
2015-11-21 14:51:42.490564 zmc_m2 3596 INF Barn: 186000 - Capturing at 10.53 fps zm_monitor.cpp 2907
2015-11-21 14:51:33.348191 zmc_m4 3690 INF Driveway: 180000 - Capturing at 10.31 fps zm_monitor.cpp 2907
2015-11-21 14:51:10.194467 zma_m4 3722 INF Driveway: 179000 - Processing at 9.90 fps zm_monitor.cpp 1160
2015-11-21 14:50:24.755183 zma_m2 3624 INF Barn: 185000 - Processing at 10.53 fps zm_monitor.cpp 1160
2015-11-21 14:50:07.542969 zmc_m2 3596 INF Barn: 185000 - Capturing at 10.75 fps zm_monitor.cpp 2907
2015-11-21 14:50:00.670277 zma_m4 3722 INF Driveway: 178291 - Opening new event 302, section start zm_monitor.cpp 1405
2015-11-21 14:50:00.459445 zma_m2 3624 INF Barn: 184758 - Opening new event 301, section start zm_monitor.cpp 1405
2015-11-21 14:50:00.104084 zma_m4 3722 INF Driveway: 178291 - Closing event 299, section end zm_monitor.cpp 1385
2015-11-21 14:50:00.029865 zma_m2 3624 INF Barn: 184758 - Closing event 300, section end zm_monitor.cpp 1385
2015-11-21 14:49:56.910238 zmc_m4 3690 INF Driveway: 179000 - Capturing at 10.31 fps zm_monitor.cpp 2907
2015-11-21 14:49:45.054058 zma_m4 3722 INF Driveway: 178136 - Left alarm state (299) - 5999(79) images zm_monitor.cpp 1507
2015-11-21 14:49:42.976417 zma_m4 3722 INF Driveway: 178111 - Gone into alert state zm_monitor.cpp 1500
2015-11-21 14:49:33.509354 zma_m4 3722 INF Driveway: 178037 - Gone into alarm state zm_monitor.cpp 1444
2015-11-21 14:49:30.090331 zma_m4 3722 INF Driveway: 178007 - Left alarm state (299) - 5870(5) images zm_monitor.cpp 1507
2015-11-21 14:49:29.392428 zma_m4 3722 INF Driveway: 178000 - Processing at 10.31 fps zm_monitor.cpp 1160
2015-11-21 14:49:27.659482 zma_m4 3722 INF Driveway: 177982 - Gone into alert state zm_monitor.cpp 1500
2015-11-21 14:49:27.064700 zma_m4 3722 INF Driveway: 177977 - Gone into alarm state zm_monitor.cpp 1444
2015-11-21 14:48:49.134751 zma_m2 3624 INF Barn: 184000 - Processing at 10.42 fps zm_monitor.cpp 1160
2015-11-21 14:48:34.010061 zmc_m2 3596 INF Barn: 184000 - Capturing at 10.42 fps zm_monitor.cpp 2907
2015-11-21 14:48:19.827452 zmc_m4 3690 INF Driveway: 178000 - Capturing at 10.31 fps zm_monitor.cpp 2907
2015-11-21 14:47:52.573005 zma_m4 3722 INF Driveway: 177000 - Processing at 10.31 fps zm_monitor.cpp 1160
2015-11-21 14:47:13.912765 zma_m2 3624 INF Barn: 183000 - Processing at 10.64 fps zm_monitor.cpp 1160
2015-11-21 14:46:58.528989 zmc_m2 3596 INF Barn: 183000 - Capturing at 10.53 fps zm_monitor.cpp 2907
2015-11-21 14:46:42.720956 zmc_m4 3690 INF Driveway: 177000 - Capturing at 10.31 fps zm_monitor.cpp 2907
2015-11-21 14:46:15.825198 zma_m4 3722 INF Driveway: 176000 - Processing at 10.20 fps zm_monitor.cpp 1160
2015-11-21 14:45:39.173211 zma_m2 3624 INF Barn: 182000 - Processing at 10.31 fps zm_monitor.cpp 1160
2015-11-21 14:45:23.819255 zmc_m2 3596 INF Barn: 182000 - Capturing at 10.31 fps zm_monitor.cpp 2907
2015-11-21 14:45:05.492973 zmc_m4 3690 INF Driveway: 176000 - Capturing at 10.20 fps zm_monitor.cpp 2907
2015-11-21 14:44:37.932677 zma_m4 3722 INF Driveway: 175000 - Processing at 10.31 fps zm_monitor.cpp 1160
2015-11-21 14:44:02.506743 zma_m2 3624 INF Barn: 181000 - Processing at 10.42 fps zm_monitor.cpp 1160
2015-11-21 14:43:46.506418 zmc_m2 3596 INF Barn: 181000 - Capturing at 10.42 fps zm_monitor.cpp 2907
2015-11-21 14:43:27.904666 zmc_m4 3690 INF Driveway: 175000 - Capturing at 10.31 fps zm_monitor.cpp 2907
2015-11-21 14:43:00.746158 zma_m4 3722 INF Driveway: 174000 - Processing at 10.42 fps zm_monitor.cpp 1160
2015-11-21 14:42:26.229400 zma_m2 3624 INF Barn: 180000 - Processing at 10.53 fps zm_monitor.cpp 1160
2015-11-21 14:42:10.590254 zmc_m2 3596 INF Barn: 180000 - Capturing at 10.64 fps zm_monitor.cpp 2907
2015-11-21 14:41:50.896058 zmc_m4 3690 INF Driveway: 174000 - Capturing at 10.31 fps zm_monitor.cpp 2907
2015-11-21 14:41:24.008334 zma_m4 3722 INF Driveway: 173000 - Processing at 10.20 fps zm_monitor.cpp 1160
