Initially, mostly tier one technical support and documentation.
I have a half a dozen ideas for a little things around the edges that will make both use and the aforementioned support easier, but I have to get my head around the code first.
Building for dev
- knight-of-ni
Re: Building for dev
We are often in our irc channel on freenode, usually during typical US business hours.
This would be a good place to ask questions and get to know everyone better.
Documentation is where I started, thought hey I can help out and fix that, then I ended up watching cppcon youtube videos at 2:00am.
I have clone the ZoneMinder repository from github. But I can't understand how to run ZoneMinder project locally.
My system is Ubuntu 16.04.
It will be great if anyone help me with step by step process of running ZoneMinder repository locally.
And also which IDE should I use.
I have clone the ZoneMinder and zmNinja repository from github. But I'm having hard time to run both the code base locally( Link of those attached below).
I am using zoneminder-1.34 & My system is Ubuntu 16.04.
Github repositories I am using :
https://github.com/ZoneMinder/zoneminder
https://github.com/ZoneMinder/zmNinja
It will be greatful if anyone help me out with step by step process of running the two above repository locally.
Thanks in advance.
Thanks in advance.
Why 1.34? Old unsupported release. If you want to do development, use latest master. Otherwise just install the packages which is well documented at https://zoneminder.readthedocs.io/en/st ... buntu.html#
I downloaded both the repo
I want to run this code base in my local system. Can anyone help me out with this.
