[Resolved] Issue changing the apache user/group
Re: Issue changing the apache user/group
Excellent. Glad you got it working.
Spart
Post by Spart »
Thanks for all the help!
Spart
Re: [Resolved] Issue changing the apache user/group
Post by Spart »
One quick addendum to this:
The FreePBX instructions do not mention this directory and it's easy to overlook, but necessary for authentication to work with ZM.
Whenever I enabled authentication (by enabling OPT_USE_AUTH in the options) I could not log in.
I enabled debugging and I was getting these PHP warnings which were being suppressed without debugging on:
Warning: session_start(): open(/var/lib/php/session/sess_rle6amfkmh8tpr5slqv8bltc25, O_RDWR) failed: Permission denied (13) in /usr/share/zoneminder/www/index.php on line 128
Warning: session_write_close(): open(/var/lib/php/session/sess_rle6amfkmh8tpr5slqv8bltc25, O_RDWR) failed: Permission denied (13) in /usr/share/zoneminder/www/index.php on line 193
Warning: session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/session) in /usr/share/zoneminder/www/index.php on line 193
The ownership on /var/lib/php/session was "root:apache" and it needs to be "root:asterisk"
"chown -R root:asterisk /var/lib/php/session" fixed this.
