You might want to try the fix Rockedge came up with for Bionic with PHP7.2. I suspect that some changes have been made to Ubuntu 17.10 in prep for 18.04.
bbunge wrote: ↑Fri Mar 23, 2018 12:04 am
My environment is on 16.04 and PHP7.0, so unlikely to be related.
rockedge wrote: ↑Thu Mar 22, 2018 11:49 pm
that looks like some problem in the API. I have not seen this error before... did anything change as far as URL re-writes goes?
In my case I did nothing other than upgrading the zoneminder packages to v1.31.39.
If I try requesting the same URL directly (in my error log above it was /zm/api/events/5739.json) I get the same error, so this is definitely an API issue as opposed to a ZMNinja issue...
