unable to open input
Heimo
Re: unable to open input
Post by Heimo »
Heimo wrote: Fri Sep 09, 2022 4:07 pm
iconnor wrote: Fri Sep 09, 2022 4:01 pm So the no route to host are obvious.
The rest is basically saying that it is taking too long for ffmpeg to figure out what the stream is.
You might try setting the Options feild to probesize=50000
You might also have to adjust Options->System->WATCH_MAX_DELAY larger.
I take it these are older cams? I wouldn't expect the keyframe interval to be too huge, but maybe so...
it does not work.
I have set the rate to 3 and the interval to 10
you are right, these are older cams
Heimo
Post by Heimo »
Heimo wrote: Fri Sep 09, 2022 4:08 pm
it does not work.
I have set the rate to 3 and the interval to 10 -> on the cam
Sorted now?
Heimo
Post by Heimo »
Magic919 wrote: Fri Sep 09, 2022 6:02 pmSorted now?
no, does not work
So vlc works with the url what about ffplay?
I use 1.36.25 with lots of old Axis and Foscam cameras. Nothing special about them, they should work fine.
Heimo
Post by Heimo »
iconnor wrote: Fri Sep 09, 2022 6:47 pm So vlc works with the url what about ffplay?
Is it possible to get the parameters you use of all pages? I am using for instance FI9826P V2
They worked very well eith 1.32
I see that with my foscams I have specified port 80 for the rtsp stream... rtsp://192.168.2.17:80/videoMain
Which is weird, but whatever.
What’s the deal with the no route host errors?
Heimo
Post by Heimo »
It works with remote and rtsp/unicast This is ok.
Thanks for your help.
Regards
Heimo
Heimo
Post by Heimo »
Dear all,
after installing a new cam, I had the same problem. Same cams, one works, one did not with the same parameter.
Now I think I have found the problem and the solution, hopefully.
Hardware:
raspberry PI 4 wit 4GB RAM
cams which did not work: foscam wiht ffmpeg
ZM 1.36.33
I encreased the GPU MEM from 64MB to 128 MB and now it works fine
Best greetings from Lower Austria.
Heimo
