1.37.x is is development, so docs come later.
1.37 just breaks out the various Function selections for finer control to match your needs. So
Low-Res stream with MoDect set
HiRes stream with NoDect set, triggered from Events on the LoRes stream
are spread across three pages:
Source->Decoding
Analysis->Motion Detection
Recording->Recording
Pick what you want in the dropdowns.
Upgrade from ZM 1.36 to 1.37
Re: Upgrade from ZM 1.36 to 1.37
I still havn't figured out how to upgrade when running on Fedora 40
I don't have a full html-view anymore after upgrade/new install of 1.37.64. Neither with firefox nor with chromium under debian12
<zmIP>/ZM looks like plain-text
Cleared the problem by myself by doing: apt remove --purge zoneminder and deleting all files and directories (including zm-db table) following the hints given by the --purge option. New install via 1.37 script did its job.
