New zmNinja release for Android
Re: New zmNinja release for Android
yeah zmninja-pro is the old, and we can't make it non-free, so it has to go away. Should disappear from play store soon. Although if it is working for you can a person didn't want to pay $5, then hey they can just keep using it.
zmNinja is the new update, version is now at 1.7.003.
There may someday be another zmNinja-Pro, but it will have PRO features whatever they are, and likely cost a bit more. We will see. Right now just trying to get comfortable with the code and make it support new features in 1.37.
Also still failing to build for mac. Getting there.
dvsapp
Post by dvsapp »
First off, thank you so much for work you're doing with ZM and zmNinja. I've run into an issue maybe similar to what others have; no video on either monitors or events. I have 3 Android phones running zmNinja-pro ver1.6.009. They work very well. I now added another phone and the new version 1.7.002 is installed. No video on that phone only. I upgraded one of the other phones from 1.6.009 to the new 1.7.002 version, and same problem; no video. My Zoneminder version is 1.37.47. API's check good. Another strange thing is that I cannot email the log files from version 1.7.002, the e-mail button on the logs tab doesn't function. Android OS ver14 and ver 12.
Thanks again for all the hard work and time put into this software!
The only thing I can think of is that your url to zms is wrong. In which case you should be seeing 404 errors in your apache logs.
emike
Post by emike »
This is awesome. Glad I found this.
I've downloaded zmNinja from the play store, says version 1.7.002
Used the wizard to configure (just my zm URL: "http://www.mydomain.com/zm")
It sees the one camera I have configured, but only shows a square with ... in the middle (camera view and montage).
Don't know where to start troubleshooting.
Thanks!!
What we are seeing is that android will no longer load images without https.
So please setup https
