Floating Point Exception Filling Logs
Re: Floating Point Exception Filling Logs
Just for clarity...
zmc_m1 was showing "Segmentation Fault"s
zmc_m2 was showing "Floating Point Exceptions"
The Segmentation Fault and Floating Point Exceptions were happening at different times.
Also... Sorry I'm not very good with github. How do I update zoneminder to the version you pushed?
Thanks again for your help.
If you are running ubuntu or debian, then sudo apt update && sudo apt install zoneminder
Got:
zoneminder is already the newest version (1.37.61~20240617135553-focal)
Yeah that's def not latest.
I just push a possible fix for the float point exception. I noticed that it was reporting a negative fps, so I've fixed that. We will see if it fixes the exception.
New packages building, should be zoneminder_1.37.61~20240621 ish.
I think the update & install worked this time.
"Setting up zoneminder (1.37.61~20240621140450-focal)"
Should I turn LOG_DEBUG ON again, or watch for the errors and turn it ON only if they return?
Wait for them to return.
Looking good so far. No Floating Point or Segmentation Fault errors yet.
Started getting Segmentation Faults in zmc_m1.log again.
I've set all the logging levels to "info" and turned logging back on. Waiting for the Seg Faults to start again...
Attached is a portion of the zmc_m1.log file with segmentation fault errors:
- zmc_m1.log
- (29.42 KiB) Downloaded 149 times
I may have fixed it this morning. Please update.
Sorry for the delay in response. It had seemed to work for a while (v1.37.62). I am now getting 3Gb log files with the following error:
I will turn on info level debug logging to get more information.
zmc_m1.log
zmc_m1.log
07/09/24 01:11:15.880224 zmc_m1[135600].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 02:21:51.713253 zmc_m1[135600].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 02:21:51.931591 zmc_m1[135600].ERR-zm_ffmpeg_camera.cpp/366 [Unable to open input rtsp://192.168.0.20:554/videoMain due to: Immediate exit requested]
07/09/24 03:32:28.755578 zmc_m1[158056].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 04:43:04.388511 zmc_m1[158056].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 05:53:40.134787 zmc_m1[158056].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 07:10:40.423942 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 08:21:16.668438 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 08:57:16.095508 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 09:17:51.845586 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 10:28:27.666040 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 11:20:26.016992 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 12:32:00.658589 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 13:43:35.577952 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 14:55:10.550783 zmc_m1[170836].ERR-zmc.cpp/318 [Failed to capture image from monitor 1 Back Porch (1/1)]
07/09/24 15:26:24.547256 zmc_m1[211047].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
07/09/24 15:26:24.547298 zmc_m1[211047].ERR-zm_signal.cpp/82 [Signal address is 0x10, from 0x55cb51fe5c9f]
07/09/24 15:26:24.552407 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 0: /usr/bin/zmc(+0x100b89) [0x55cb51efbb89]]
07/09/24 15:26:24.552426 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f2c751da420]]
07/09/24 15:26:24.552432 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 2: /usr/bin/zmc(+0x1eac9f) [0x55cb51fe5c9f]]
07/09/24 15:26:24.552437 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 3: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f2c74892df4]]
07/09/24 15:26:24.552442 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 4: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f2c751ce609]]
07/09/24 15:26:24.552447 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f2c7457d353]]
07/09/24 15:26:24.552452 zmc_m1[211047].ERR-zm_signal.cpp/127 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
07/09/24 15:26:24.552457 zmc_m1[211047].ERR-zm_signal.cpp/128 [and execute the following command for more information:]
07/09/24 15:26:24.552461 zmc_m1[211047].ERR-zm_signal.cpp/129 [addr2line -Cfip -e /usr/bin/zmc 0x100b89 0x1eac9f]
07/09/24 15:26:24.552473 zmc_m1[211047].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
07/09/24 15:26:24.552479 zmc_m1[211047].ERR-zm_signal.cpp/82 [Signal address is 0x10, from 0x55cb51fe5c9f]
07/09/24 15:26:24.552609 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 0: /usr/bin/zmc(+0x100b89) [0x55cb51efbb89]]
07/09/24 15:26:24.552616 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f2c751da420]]
07/09/24 15:26:24.552620 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 2: /usr/bin/zmc(+0x1eac9f) [0x55cb51fe5c9f]]
07/09/24 15:26:24.552625 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 3: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f2c74892df4]]
07/09/24 15:26:24.552629 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 4: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f2c751ce609]]
07/09/24 15:26:24.552633 zmc_m1[211047].ERR-zm_signal.cpp/108 [Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f2c7457d353]]
07/09/24 15:26:24.552638 zmc_m1[211047].ERR-zm_signal.cpp/127 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
07/09/24 15:26:24.552642 zmc_m1[211047].ERR-zm_signal.cpp/128 [and execute the following command for more information:]
07/09/24 15:26:24.552647 zmc_m1[211047].ERR-zm_signal.cpp/129 [addr2line -Cfip -e /usr/bin/zmc 0x100b89 0x1eac9f]
07/09/24 15:26:24.552655 zmc_m1[211047].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
07/09/24 15:26:24.552660 zmc_m1[211047].ERR-zm_signal.cpp/82 [Signal address is 0x10, from 0x55cb51fe5c9f]
Here is part of zm1 with debug levels set to info:
07/11/24 06:33:55.146580 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10100 - Capturing at 4.99 fps, capturing bandwidth 124511bytes/sec Analysing at 1.70 fps]
07/11/24 06:34:15.126792 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10200 - Capturing at 5.00 fps, capturing bandwidth 125084bytes/sec Analysing at 1.65 fps]
07/11/24 06:34:35.112985 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10300 - Capturing at 5.00 fps, capturing bandwidth 122080bytes/sec Analysing at 1.65 fps]
07/11/24 06:34:55.135245 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10400 - Capturing at 4.99 fps, capturing bandwidth 122557bytes/sec Analysing at 1.70 fps]
07/11/24 06:35:15.132449 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10500 - Capturing at 5.00 fps, capturing bandwidth 123634bytes/sec Analysing at 1.65 fps]
07/11/24 06:35:35.134833 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10600 - Capturing at 5.00 fps, capturing bandwidth 124165bytes/sec Analysing at 1.65 fps]
07/11/24 06:35:55.128876 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10700 - Capturing at 5.00 fps, capturing bandwidth 122834bytes/sec Analysing at 1.70 fps]
07/11/24 06:36:15.125908 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10800 - Capturing at 5.00 fps, capturing bandwidth 124195bytes/sec Analysing at 1.65 fps]
07/11/24 06:36:35.132320 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 10900 - Capturing at 5.00 fps, capturing bandwidth 123178bytes/sec Analysing at 1.65 fps]
07/11/24 06:36:55.142614 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11000 - Capturing at 5.00 fps, capturing bandwidth 122157bytes/sec Analysing at 1.70 fps]
07/11/24 06:37:15.135524 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11100 - Capturing at 5.00 fps, capturing bandwidth 123905bytes/sec Analysing at 1.65 fps]
07/11/24 06:37:35.155345 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11200 - Capturing at 5.00 fps, capturing bandwidth 123258bytes/sec Analysing at 1.65 fps]
07/11/24 06:37:55.154787 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11300 - Capturing at 5.00 fps, capturing bandwidth 123765bytes/sec Analysing at 1.70 fps]
07/11/24 06:38:15.154697 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11400 - Capturing at 5.00 fps, capturing bandwidth 123142bytes/sec Analysing at 1.65 fps]
07/11/24 06:38:19.547409 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 11421 - Gone into prealarm state]
07/11/24 06:38:20.745811 zmc_m1[374842].INF-zm_monitor.cpp/2339 [Back Porch: 11427 - Gone into alarm state PreAlarmCount: 2 > AlarmFrameCount:3 Cause:Motion:MotionArea]
07/11/24 06:38:20.745863 zmc_m1[374842].INF-zm_monitor.cpp/2523 [Back Porch: 11427 - Opening event timestamp 1720697900 % 500]
07/11/24 06:38:21.143992 zmc_m1[374842].INF-zm_monitor.cpp/2530 [Opened new event 48619 Motion:MotionArea]
07/11/24 06:38:28.554943 zmc_m1[374842].INF-zm_monitor.cpp/2372 [Back Porch: 11466 - Gone into alert state]
07/11/24 06:38:35.145624 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11500 - Capturing at 5.00 fps, capturing bandwidth 119245bytes/sec Analysing at 0.95 fps]
07/11/24 06:38:38.733817 zmc_m1[374842].INF-zm_monitor.cpp/2377 [Back Porch: 11517 - Left alert state]
07/11/24 06:38:38.733851 zmc_m1[374842].INF-zm_monitor.cpp/2498 [Back Porch: 11517 - Closing event 48619 1720697918 - 1720697897 = 21 >= 600]
07/11/24 06:38:51.348268 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 11580 - Gone into prealarm state]
07/11/24 06:38:52.527277 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 11586 - Gone into prealarm state]
07/11/24 06:38:55.156108 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11600 - Capturing at 5.00 fps, capturing bandwidth 124073bytes/sec Analysing at 1.40 fps]
07/11/24 06:39:15.164299 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11700 - Capturing at 5.00 fps, capturing bandwidth 122640bytes/sec Analysing at 1.65 fps]
07/11/24 06:39:35.164527 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11800 - Capturing at 5.00 fps, capturing bandwidth 122808bytes/sec Analysing at 1.65 fps]
07/11/24 06:39:55.162529 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 11900 - Capturing at 5.00 fps, capturing bandwidth 122585bytes/sec Analysing at 1.70 fps]
07/11/24 06:40:15.150005 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 12000 - Capturing at 5.00 fps, capturing bandwidth 124102bytes/sec Analysing at 1.65 fps]
07/11/24 06:40:19.555884 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 12021 - Gone into prealarm state]
07/11/24 06:40:21.947082 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 12033 - Gone into prealarm state]
07/11/24 06:40:35.173417 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 12100 - Capturing at 4.99 fps, capturing bandwidth 121985bytes/sec Analysing at 1.65 fps]
07/11/24 06:40:55.173407 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 12200 - Capturing at 5.00 fps, capturing bandwidth 123984bytes/sec Analysing at 1.70 fps]
07/11/24 06:41:15.193344 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 12300 - Capturing at 5.00 fps, capturing bandwidth 123212bytes/sec Analysing at 1.65 fps]
07/11/24 06:41:35.185711 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 12400 - Capturing at 5.00 fps, capturing bandwidth 123410bytes/sec Analysing at 1.65 fps]
07/11/24 06:41:53.763864 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 12492 - Gone into prealarm state]
07/11/24 06:41:54.974052 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 12498 - Gone into prealarm state]
07/11/24 06:41:55.171705 zmc_m1[374776].INF-zm_monitor.cpp/1934 [Back Porch: 12500 - Capturing at 5.00 fps, capturing bandwidth 123618bytes/sec Analysing at 1.70 fps]
07/11/24 06:42:03.954960 zmc_m1[374842].INF-zm_monitor.cpp/2343 [Back Porch: 12543 - Gone into prealarm state]
07/11/24 06:42:05.176333 zmc_m1[374842].INF-zm_monitor.cpp/2339 [Back Porch: 12549 - Gone into alarm state PreAlarmCount: 2 > AlarmFrameCount:3 Cause:Motion:MotionArea]
07/11/24 06:42:05.176379 zmc_m1[374842].INF-zm_monitor.cpp/2523 [Back Porch: 12549 - Opening event timestamp 1720698125 % 125]
07/11/24 06:42:05.399816 zmc_m1[374842].INF-zm_monitor.cpp/2530 [Opened new event 48624 Motion:MotionArea]
07/11/24 06:42:05.400405 zmc_m1[378156].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
07/11/24 06:42:05.400439 zmc_m1[378156].ERR-zm_signal.cpp/82 [Signal address is 0xdaf, from 0x5626349d05f1]
07/11/24 06:42:05.400688 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 0: /usr/bin/zmc(+0x100b89) [0x5626349ffb89]]
07/11/24 06:42:05.400698 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f9e96b48420]]
07/11/24 06:42:05.400706 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 2: /usr/bin/zmc(+0xd15f1) [0x5626349d05f1]]
07/11/24 06:42:05.400714 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 3: /usr/bin/zmc(+0x1eab2c) [0x562634ae9b2c]]
07/11/24 06:42:05.400721 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 4: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f9e96200df4]]
07/11/24 06:42:05.400728 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 5: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f9e96b3c609]]
07/11/24 06:42:05.400735 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f9e95eeb353]]
07/11/24 06:42:05.400741 zmc_m1[378156].ERR-zm_signal.cpp/127 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
07/11/24 06:42:05.400748 zmc_m1[378156].ERR-zm_signal.cpp/128 [and execute the following command for more information:]
07/11/24 06:42:05.400755 zmc_m1[378156].ERR-zm_signal.cpp/129 [addr2line -Cfip -e /usr/bin/zmc 0x100b89 0xd15f1 0x1eab2c]
07/11/24 06:42:05.400767 zmc_m1[378156].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
07/11/24 06:42:05.400774 zmc_m1[378156].ERR-zm_signal.cpp/82 [Signal address is 0xdaf, from 0x5626349d05f1]
07/11/24 06:42:05.400906 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 0: /usr/bin/zmc(+0x100b89) [0x5626349ffb89]]
07/11/24 06:42:05.400915 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f9e96b48420]]
07/11/24 06:42:05.400922 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 2: /usr/bin/zmc(+0xd15f1) [0x5626349d05f1]]
07/11/24 06:42:05.400929 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 3: /usr/bin/zmc(+0x1eab2c) [0x562634ae9b2c]]
07/11/24 06:42:05.400936 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 4: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f9e96200df4]]
07/11/24 06:42:05.400943 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 5: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f9e96b3c609]]
07/11/24 06:42:05.400950 zmc_m1[378156].ERR-zm_signal.cpp/108 [Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f9e95eeb353]]
07/11/24 06:42:05.400956 zmc_m1[378156].ERR-zm_signal.cpp/127 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
07/11/24 06:42:05.400963 zmc_m1[378156].ERR-zm_signal.cpp/128 [and execute the following command for more information:]
07/11/24 06:42:05.400970 zmc_m1[378156].ERR-zm_signal.cpp/129 [addr2line -Cfip -e /usr/bin/zmc 0x100b89 0xd15f1 0x1eab2c]
07/11/24 06:42:05.400980 zmc_m1[378156].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
INF is not useful. Need Debug=4
I will get that to you Monday.
Hi.
Ubuntu Server 5.15.0-113-generic #123~20.04.1-Ubuntu.
zoneminder-dbg/focal,now 1.37.62~20240707094607-focal amd64 [installed]
zoneminder-doc/focal,now 1.37.62~20240707094607-focal all [installed,automatic]
zoneminder/focal,now 1.37.62~20240707094607-focal amd64 [installed]
Usually this happens when it's time to create another continuous event (I have default section length = 600s for all monitors).
Debug=4 logs: https://drive.google.com/file/d/11FrA-L ... sp=sharing
110MB, too large to attach here. It's seems that there's not much more about the fault than there's in DB log, same lines repeating over and over:
07/13/24 15:00:01.507777 zmc_m202[17670].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
07/13/24 15:00:01.507785 zmc_m202[17670].DB1-zm_signal.cpp/57 [Signal information: number 11 code 128 errno 0 pid 0 uid 0 status 0]
07/13/24 15:00:01.507789 zmc_m202[17670].ERR-zm_signal.cpp/82 [Signal address is (nil), from 0x556262cbcc9f]
07/13/24 15:00:01.507967 zmc_m202[17670].ERR-zm_signal.cpp/108 [Backtrace 0: /usr/bin/zmc(+0x100b89) [0x556262bd2b89]]
07/13/24 15:00:01.507975 zmc_m202[17670].ERR-zm_signal.cpp/108 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f15ae59d420]]
07/13/24 15:00:01.507979 zmc_m202[17670].ERR-zm_signal.cpp/108 [Backtrace 2: /usr/bin/zmc(+0x1eac9f) [0x556262cbcc9f]]
07/13/24 15:00:01.507982 zmc_m202[17670].ERR-zm_signal.cpp/108 [Backtrace 3: /lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7f15adc54df4]]
07/13/24 15:00:01.508005 zmc_m202[17670].ERR-zm_signal.cpp/108 [Backtrace 4: /lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7f15ae591609]]
07/13/24 15:00:01.508010 zmc_m202[17670].ERR-zm_signal.cpp/108 [Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f15ad93f353]]
07/13/24 15:00:01.508015 zmc_m202[17670].ERR-zm_signal.cpp/127 [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
07/13/24 15:00:01.508019 zmc_m202[17670].ERR-zm_signal.cpp/128 [and execute the following command for more information:]
07/13/24 15:00:01.508022 zmc_m202[17670].ERR-zm_signal.cpp/129 [addr2line -Cfip -e /usr/bin/zmc 0x100b89 0x1eac9f]
~: addr2line -Cfip -e /usr/bin/zmc 0x100b89 0x1eac9f
addr2line: DWARF error: section .debug_info is larger than its filesize! (0x1021252 vs 0xb80bf0)
void std::vector<char, std::allocator<char> >::_M_realloc_insert<char>(__gnu_cxx::__normal_iterator<char*, std::vector<char, std::allocator<char> > >, char&&) at ??:?
std::mersenne_twister_engine<unsigned long, 32ul, 624ul, 397ul, 31ul, 2567483615ul, 11ul, 4294967295ul, 7ul, 2636928640ul, 15ul, 4022730752ul, 18ul, 1812433253ul>::operator()() at ??:?
