Data source path for USB drive not found - solved. Needed to edit FSTAB to survive PI reboot
Re: Data source path for USB drive not found - solved
Now I only get a telemetry error
The site that's looking for is down, possibly permanently.
There's a switch for it in Options.
fairfacts
Post by fairfacts »
Thanks - found it
but overnight the disk error came back :-( nothing changed
fairfacts
Re: Data source path for USB drive not found - solved. Needed to edit FSTAB to survive PI reboot
Post by fairfacts »
changed FSTAB to ensure disk can back to same mount point if the PI rebooted
