Configuration help. Grandtech X guard
kim_asplund
Post by kim_asplund »
I tryed them all.... :lol: but nothing showed any image... it might have been somthing with the stream i guess... some default permissions or something. Well my redhat system is almost updated and ready to go... Fingers crossed. :?
kim_asplund
Last time i installed on redhat it went w/o problems.... but now.... NOOOO .... ? :?
/usr/local/bin/zmc: error while loading shared libraries: libavformat.so: cannot open shared object file: No such file or directory
I Compiled ffmpeg with shared, so they are installed.
suggestions
zoneminder
Site Admin
Post by zoneminder »
Did you install it into /usr/local/lib? In which case you may need to update /etc/ld.so.conf and rerun ldconfig.
Phil,
kim_asplund
Up and running :lol: :lol:
But i dont seem to be able to stream mpeg onlu jpg is working.
only error i found.
'zmfilter.pl ' stopping at 04/05/28 11:58:54
'zmfilter.pl ' died at 04/05/28 11:58:54, signal 14
Use of uninitialized value in hash element at /usr/local/bin/zmdc.pl line 281, <CLIENT> line 1.
Use of uninitialized value in concatenation (.) or string at /usr/local/bin/zmdc.pl line 284, <CLIENT> line 1.
Can't find process with command of ''
Server starting at 04/05/28 11:58:54
'zmc -d 0' started at 04/05/28 11:58:58
'zmc -d 0' starting at 04/05/28 11:58:58, pid = 2402
'zma -m 1' started at 04/05/28 11:58:58
'zma -m 1' starting at 04/05/28 11:58:58, pid = 2406
'zmfilter.pl' started at 04/05/28 11:58:59
'zmfilter.pl' starting at 04/05/28 11:58:59, pid = 2410
kim_asplund
my mistake... wmp was not working correctly...
Is there any (free)software to enable windows and a webcam to work with ZM?
