ZM-1.20.0 Fedoa Core 3 RPM
- zoneminder
- Site Admin
- Contact:
X10 and zmtrigger.pl
Phillip,
Thanks for updating zmtrigger.pl. I will try it out later today.
Cordel,
For X10, all you need is an activehome CM11A:
http://www.smarthome.com/1140.html
These are even cheaper on eBay.
and you will also need x10 motion sensors.
http://www.smarthome.com/4086.html
also, cheap on ebay or at x10.com
The great thing about X10 triggering is that with modect, zma only runs when motion is detected by the motion sensor. This cuts down significantly on false event triggers.
Cordel,
latest RC errors on build
I now recieve these errors when trying to build RC2
zm_user.cpp: In function `User* zmLoadAuthUser(const char*, bool)':
zm_user.cpp:187: error: `MD5_DIGEST_LENGTH' undeclared (first use this function)zm_user.cpp:187: error: (Each undeclared identifier is reported only once for each function it appears in.)
zm_user.cpp:207: error: `md5sum' undeclared (first use this function)
zm_user.cpp:207: error: `MD5' undeclared (first use this function)
make[2]: *** [zm_user.o] Error 1
make[2]: Leaving directory `/usr/src/redhat/BUILD/zm-1.20.1/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/redhat/BUILD/zm-1.20.1'
make: *** [all] Error 2
error: Bad exit status from /usr/src/redhat/rpm-tmp.92249 (%build)
Release Canidate 2 rpm is up for testing
I have the Release canidate two up for testing.
I had to change the decleration in zm-user.cpp to get it to build. It didn't like the if statement for some reason.
Cheers,
Cordel
Cheers,
Cordel
- zoneminder
- Site Admin
- Contact:
hello everybody
Result for PHP : I compile ZM on SME (RH7.3) with PHP 4.1.2 modif version after (not 4.3.8 , oops) =>
zm 1.19.5 without patch OK, work correctly
ZM1.19.5 + patch for RPM => can't acces to login panel. and i have some errors like
zm_config.php =
i change to fgets ($cfg , 100) => works, i can access to login and zm work correctly with some errors
the second parameter of fget( x,x ) is not necessary for recent version of php....
an another error :
in zm_actions :
FOR ZM 1.20 :I have the same errors and i can't login. I can acces to the login panel, i put my login and password , i access to the central console ~0.5s and i return directly to the panel login.
with patch : it doing the same thing.
So, I decide to pass to PHP 4.3.9 and actually, it run with some little errors....but it run
constant errors :
in zm_html_view
Cordel I think you use recent version of PHP for testing ....
but there are prbs with old version
If this infos can help you .....
Good job all
PHP Warning: Wrong parameter count for fgets() in .../zm_config.php on on line 31
$cfg = fopen( ZM_CONFIG, "r") or die("Could not open config file.");
while ( !feof($cfg) )
$str = fgets( $cfg );
if ( preg_match( '/^\s*$/', $str )) { continue; }
an another error :
PHP Warning: Wrong parameter count for mkdir() in ../zm_actions.php on line 252
die( mysql_error() );
//$view = 'none';
mkdir( ZM_DIR_EVENTS."/".$mid );
constant errors :
PHP Warning: Invalid argument supplied for foreach() in /html/zm_html_view_state.php on line 148
in zm_html_view
foreach ( $states as $state )
Good job all
oooops, i'm sorry but i speak english like as spanish cow...
Yes chaapaï you would be correct in assumeing that I am useing a more recent version of PHP and all your troubles look to be php related. As of recently I also beleive that the php script has been updated to support the newer fuctions of the more recent php and that is why you have these errors.
The php web pages are not constructed through the RPMBUILD process though and are for the most part static and just copied into the rpm.
My build machine is Fedora Core 3 and I beleve that my current version of PHP is 4.3.10-3.2 You may have to update your PHP to get things working or modifiy the pages to work with the version of php you have.
Cheers,
Cordel
Cheers,
Cordel
- zoneminder
- Site Admin
- Contact:
I installed zm-1.20.1-RC3.FC3.i386.rpm on my FC3 system all the dependencies and stuff - restarted apache and I get when pointing to it:
Thanks.
Karen
http://scootgirl.com/
Obviously I need to setup a mysql user/password, dbase, etc., but is there directions as to what dbase to make, etc.?Could not connect to database: Access denied for user: 'ZM_DB_USER@localhost' (Using password: YES)
Thanks.
Karen
Karen,
With the RPM you need to edit the /etc/zm.conf
Add a username and password (anything you please) this will be used by ZM only
Make sure you have mysql running (I set chkconfig 2345 mysql on and same for httpd)
Then you need to execute
/usr/lib/zm/bin/zminit
It will ask you for a admin user type root and unless you gave root a password for the password leave it blank.
Your Database is now set up.
That should do it, If not I would guess you missing a package that you require.
If you post some of the errors ifrom your logs we can give you more definative help.
Cheers,
Cordel
Cheers,
Cordel
zm-1.20.0-3.FC3.i386.rpm and MySQL-4.1.9-0
Just wondering if someone had the same problem:
I could not get the zm rpm install to work with MySQL-4.1.9-0 even though I reocmpiled my php.
Always got the error:
Could not connect to database: Client does not support authentication protocol requested by server; consider upgrading MySQL client.
Works fine though with MySQL-4.0.23
P.S. I did not try to install zm 1.20 without the rpm and MySQL-4.1.9-0 so I don't know if those two just don't get along
Try ftp://oskin.ru/pub/linux/RedHat/MyRPMS/ ... 3.i386.rpm , it is compiled with mysql-4.1.9. Other packages compiled with mysql-4.1.* (perl-DBD-MySQL, php, etc.) lay in the same directory.
Problem installing RPMs on a fresh, full, FC3 installation
Hi everyone. I'm new here... I just "discovered" ZoneMinder a few days ago and would like to give it a try. I installed Fedora Core 3 (all packages and all released updates) on some old hardware I had lying around. I downloaded all of the RPMs from cordel's directory and got these errors when trying to install them. I've been using Linux (RedHat and Fedora) for several years, so I'm pretty familar with it... but mostly from a "server" side (web server, mail server, DB server, etc.) and have not delved into the world of trying to make something like video4linux, webcam, etc work.
Here are the RPMs I installed, and the error message. (Never mind the host name, it really is FC3) Thanks in advance for your help!
[root@fedora1 zm]# ls
a52dec-0.7.4-6.rhfc3.at.i386.rpm
faac-1.24-1.1.fc3.rf.i386.rpm
faad2-2.0-2.rhfc3.at.i386.rpm
ffmpeg-0.4.8-4.rhfc3.at.i386.rpm
imlib2-1.1.2-3.rhfc3.at.i386.rpm
libxvidcore4-1.0.2-6.rhfc3.at.i386.rpm
perl-Archive-Zip-1.14-FC3.noarch.rpm
perl-Astro-SunTime-0.01-FC3.noarch.rpm
perl-Compress-Zlib-1.33-1.i386.rpm
perl-Date-Manip-5.42-1.noarch.rpm
perl-Device-SerialPort-1.002-1.i386.rpm
perl-IO-stringy-2.109-FC3.noarch.rpm
perl-MailTools-1.66-1.noarch.rpm
perl-MIME-tools-5.417-1.noarch.rpm
perl-Net_SSLeay.pm-1.25-1.i386.rpm
perl-Time-modules-2003.1126-1.noarch.rpm
perl-Unicode-Map-0.112-1.i386.rpm
perl-Unicode-String-2.07-1.i386.rpm
perl-X10-0.03-1-FC3.noarch.rpm
zm-1.20.1-RC4.FC3.i386.rpm
zm-X10-1.20.1-RC4.FC3.i386.rpm
[root@fedora1 zm]# rpm -ivh *.rpm
warning: a52dec-0.7.4-6.rhfc3.at.i386.rpm: V3 DSA signature: NOKEY, key ID 66534c2b
warning: faac-1.24-1.1.fc3.rf.i386.rpm: V3 DSA signature: NOKEY, key ID 6b8d79e6
warning: perl-Archive-Zip-1.14-FC3.noarch.rpm: V3 DSA signature: NOKEY, key ID 20fd877a
error: Failed dependencies:
liba52.so.0 is needed by a52dec-0.7.4-6.rhfc3.at.i386
liba52_0 = 0.7.4 is needed by a52dec-0.7.4-6.rhfc3.at.i386
lame is needed by ffmpeg-0.4.8-4.rhfc3.at.i386
libmp3lame.so.0 is needed by ffmpeg-0.4.8-4.rhfc3.at.i386
perl(Convert::BinHex) is needed by perl-MIME-tools-5.417-1.noarch
lame is needed by zm-1.20.1-RC4.FC3.i386
libmp3lame.so.0 is needed by zm-1.20.1-RC4.FC3.i386
Steve Houchen
You need to install the lame package from your FC3 Disc set and just in case you do need the devels for those packages I put them on the ftp. Those normally are not required. You should not need perl-SSLeay either, thats there for something else I'm working on but it don't hert to install.
It appears that you are missing a perl module as well but I'm not sure which package provides convert::binhex. The files on my ftp under fedora/3/RPMS should be all the files you need in addition to CD set as far as I'm aware. No one else had said anything otherwise.
Cheers,
Cordel
Cheers,
Cordel
