Live video streaming problem (but works with replays)
SyRenity
Post by SyRenity »
Hello.
Phil - thank you for the explanation, it makes things much clear.
Cordel - please do, I will very appreciate it. Could you tell the exact path to the testing directory on your FTP?
BTW, I just although about a possible solution - if ZM uses the binary for the video generation from events, why just not keep the old version of FFMPEG (0.4.8 ) somewhere in the system, and set the ZM use it as the encoding tool? That way, ZM will stream the live video through the libs it is linked against, but will generate the video using the working, previous, version. Not a perfect solution, but it may be used until the FFMPEG developers sort the bugs out in the 0.4.9 version.
What do you think?
