zm-1.21 RPM Problems
sgtdawg
Post by sgtdawg »
new rpm installed without any trouble
# rpm -Uvh zm-1.21.0-10.FC3.SEL.CTU.i386.rpm
Preparing... ########################################### [100%]
1:zm ########################################### [100%]
# service zm start
Upgrade ZoneMinder database: Loading config from 'zmconfig.txt'
Loading config from '/etc/zm.conf'
Loading config from DB
Saving config to DB                            [ OK ]
Starting ZoneMinder:                           [ OK ]
Now if I can only get mySQL working correctly....
Thanks for the fix!
cordel
Post by cordel »
Looks nlike mysql is working if it loaded the database.
New package loaded to the updates repo.
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
