Make error
nero2k3
Hmm
Post by nero2k3 »
Ok, it now loads the java applet :)
But i get this:
I take it that i have some problem with the access to the cgi-bin, i might have an idea why, will check my idea out and get back
cordel
Post by cordel »
unless you have dns or hosts set and the machine is named angel...
That would most likely be you issue.
On your windows machine you could edit the host file and add angel to it just for testing.
Check your apache and network setting as well. Some where it is getting angel.
nero2k3
YAY :)
Post by nero2k3 »
WooHoo...
It works.. Thanks for all the help :)
nero2k3
Just about the hostname thing...
Post by nero2k3 »
Yeah that is all kool, i run a network of about 30 linux pcs, we are experimenting with cctv on it now and this looks to be the best :)
Thanks[/i]
cordel
Post by cordel »
Glad you got it.
Have fun :D
Regards,
cordel
nero2k3
Oops
Post by nero2k3 »
Lol, i just deleted the screen size lol, what is the default?
cordel
Post by cordel »
If you mean for the source camera the typical settings are 640x480 or 320x240 for NTSC
PAL I'm not sure as I don't use that format.
nero2k3
Got it back
Post by nero2k3 »
Thanks i have it working again.. time to play :)
