Video Crds (Input)
im glad a mind better than mine said that lol. Thanks for looking. Do you have any ideas?. Would it help if you got into the fc3 box that it works on or i post some output from it? Problem i have is that i have got quite used to mandrake now and in fc everything has moved.
Regards James
edit** sure hang on
Regards James
edit** sure hang on
Linux version 2.6.12-1.1372_FC3 (bhcompile@tweety.build.redhat.com) (gcc version 3.4.3 20050227 (Red Hat 3.4.3-22)) #1 Fri Jul 15 00:59:10 EDT 2005
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff3000 (ACPI NVS)
BIOS-e820: 000000000fff3000 - 0000000010000000 (ACPI data)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
255MB LOWMEM available.
Using x86 segment limits to approximate NX protection
On node 0 totalpages: 65520
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 61424 pages, LIFO batch:31
HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 ABIT ) @ 0x000f6e60
ACPI: RSDT (v001 AWARD AWRDACPI 0x30302e31 AWRD 0x00000000) @ 0x0fff3000
ACPI: FADT (v001 AWARD AWRDACPI 0x30302e31 AWRD 0x00000000) @ 0x0fff3040
ACPI: BOOT (v001 AWARD 0x00000000 0x00000000) @ 0x0fff5200
ACPI: DSDT (v001 ABIT AWRDACPI 0x00001000 MSFT 0x0100000a) @ 0x00000000
ACPI: BIOS age (1999) fails cutoff (2001), acpi=force is required to enable ACPI
ACPI: Disabling ACPI support
Allocating PCI resources starting at 10000000 (gap: 10000000:efff0000)
Built 1 zonelists
Kernel command line: ro root=/dev/VolGroup00/LogVol00 rhgb quiet
Initializing CPU#0
CPU 0 irqstacks, hard=c0443000 soft=c0442000
PID hash table entries: 1024 (order: 10, 16384 bytes)
Detected 618.877 MHz processor.
Using tsc for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 254332k/262080k available (2441k kernel code, 7116k reserved, 687k data, 180k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 1220.60 BogoMIPS (lpj=610304)
Security Framework v1.0.0 initialized
SELinux: Initializing.
SELinux: Starting in permissive mode
selinux_register_security: Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 0000000000000000 00000000
CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 512K
CPU: After all inits, caps: 0383f1ff 00000000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel Pentium III (Katmai) stepping 03
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
checking if image is initramfs... it is
Freeing initrd memory: 959k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfb440, last bus=2
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20050309
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI: disabled
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:01:00.0
PCI: Using IRQ router PIIX/ICH [8086/7110] at 0000:00:07.0
Simple Boot Flag at 0x34 set to 0x1
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
audit: initializing netlink socket (disabled)
audit(1123630707.360:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux: Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key D06D4AA4577B751B
- User ID: Red Hat, Inc. (Kernel Module GPG key)
Limiting direct PCI/PCI transfers.
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel 440BX Chipset.
agpgart: AGP aperture is 64M @ 0xe0000000
PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 76 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller at PCI slot 0000:00:07.1
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:pio, hdd:pio
Probing IDE interface ide0...
hda: LITE-ON CD-RW SOHR-5238S, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
HPT366: onboard version of chipset, pin1=1 pin2=2
HPT366: IDE controller at PCI slot 0000:00:13.0
PCI: Enabling device 0000:00:13.0 (0005 -> 0007)
PCI: Found IRQ 11 for device 0000:00:13.0
PCI: Sharing IRQ 11 with 0000:00:13.1
HPT366: chipset revision 1
HPT366: 100% native mode on irq 11
ide2: BM-DMA at 0xe000-0xe007, BIOS settings: hde:DMA, hdf:pio
PCI: Found IRQ 11 for device 0000:00:13.1
PCI: Sharing IRQ 11 with 0000:00:13.0
ide3: BM-DMA at 0xec00-0xec07, BIOS settings: hdg:pio, hdh:pio
Probing IDE interface ide2...
hde: HDS728080PLAT20, ATA DISK drive
ide2 at 0xd800-0xd807,0xdc02 on irq 11
Probing IDE interface ide3...
hde: max request size: 1024KiB
hde: 160836480 sectors (82348 MB) w/1719KiB Cache, CHS=16383/255/63, UDMA(33)
hde: cache flushes supported
hde: hde1 hde2
hda: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ide-floppy driver 0.99.newide
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
mice: PS/2 mouse device common for all mice
md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 16Kbytes
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 6, 458752 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
Initializing IPsec netlink socket
NET: Registered protocol family 17
Freeing unused kernel memory: 180k freed
input: AT Translated Set 2 keyboard on isa0060/serio0
device-mapper: 4.4.0-ioctl (2005-01-12) initialised: dm-devel@redhat.com
input: PS/2 Generic Mouse on isa0060/serio1
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
floppy0: no floppy controllers found
PCI: Found IRQ 10 for device 0000:00:0d.0
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
0000:00:0d.0: 3Com PCI 3cSOHO100-TX Hurricane at 0xd400. Vers LK1.1.19
piix4_smbus 0000:00:07.3: Found 0000:00:07.3 device
ip_tables: (C) 2000-2002 Netfilter core team
Linux video capture interface: v1.00
saa7130/34: v4l2 driver version 0.2.12 loaded
saa7130[0]: quirk: PCIPCI_NATOMA
saa7130[0]: found at 0000:02:0c.0, rev: 1, irq: 9, latency: 32, mmio: 0xea000000
saa7130[0]: subsystem: 1131:0000, board: Sabrent SBT-TVFM (saa7130) [card=42,autodetected]
saa7130[0]: board init: gpio is 1fcff
saa7130[0]: Huh, no eeprom present (err=-5)?
saa7130[0]: registered device video0 [v4l2]
saa7130[0]: registered device vbi0
saa7130[0]: registered device radio0
saa7130[1]: quirk: PCIPCI_NATOMA
saa7130[1]: found at 0000:02:0d.0, rev: 1, irq: 5, latency: 32, mmio: 0xea001000
saa7130[1]: subsystem: 1131:0000, board: Sabrent SBT-TVFM (saa7130) [card=42,autodetected]
saa7130[1]: board init: gpio is 10000
saa7130[1]: Huh, no eeprom present (err=-5)?
saa7130[1]: registered device video1 [v4l2]
saa7130[1]: registered device vbi1
saa7130[1]: registered device radio1
saa7130[2]: quirk: PCIPCI_NATOMA
saa7130[2]: found at 0000:02:0e.0, rev: 1, irq: 10, latency: 32, mmio: 0xea002000
saa7130[2]: subsystem: 1131:0000, board: Sabrent SBT-TVFM (saa7130) [card=42,autodetected]
saa7130[2]: board init: gpio is 10000
saa7130[2]: Huh, no eeprom present (err=-5)?
saa7130[2]: registered device video2 [v4l2]
saa7130[2]: registered device vbi2
saa7130[2]: registered device radio2
saa7130[3]: quirk: PCIPCI_NATOMA
saa7130[3]: found at 0000:02:0f.0, rev: 1, irq: 11, latency: 32, mmio: 0xea003000
saa7130[3]: subsystem: 1131:0000, board: Sabrent SBT-TVFM (saa7130) [card=42,autodetected]
saa7130[3]: board init: gpio is 10000
saa7130[3]: Huh, no eeprom present (err=-5)?
saa7130[3]: registered device video3 [v4l2]
saa7130[3]: registered device vbi3
saa7130[3]: registered device radio3
USB Universal Host Controller Interface driver v2.2
PCI: Found IRQ 9 for device 0000:00:07.2
uhci_hcd 0000:00:07.2: UHCI Host Controller
uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:07.2: irq 9, io base 0x0000d000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
NET: Registered protocol family 10
Disabled Privacy Extensions on device c03d2f00(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
EXT3 FS on dm-0, internal journal
EXT3 FS on hde1, internal journal
Adding 524280k swap on /dev/VolGroup00/LogVol01. Priority:-1 extents:1
parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
parport0: irq 7 detected
ieee1394: Initialized config rom entry `ip1394'
ip_conntrack version 2.1 (2047 buckets, 16376 max) - 272 bytes per conntrack
lp0: using parport0 (polling).
lp0: console ready
I know its a lot but didnt want to take anything out that might be relevant
Regards James
DMI 2.3 present.
Built 1 zonelists
Initializing CPU#0
CPU: L2 cache: 512K
Loading keyring
hde: hde1 hde2
md: autorun ...
lp0: console ready
Regards James
Ross I have another card i mentioned earlier on. I wont work on my current rig cos its to old i think, and it needs bus mastering. It doesnt even show up as hardware. I have found that there is a new bttv driver that lists a cs16 but i cant find a picture of this cs16 anywhere. If your doing a kernal update do you think this one will start to work too?
Regards James
Regards James
