No they are just text files but if you don't maintain them and clear them out (like use logrotate) they do continue to grow.
Regards,
Cordel
ZM-1.21.3-1 Fedora Core 3 Rpm up for test!
- krzys31337
Quick wget+mc on your rpm for FC3 has no /var/lib/zm/{events,images}.
Maybe you could give src.rpm of this?
(taken from ftp://download.computerntelecom.com/pub ... t.i386.rpm)
Cordel, I am now trying 'the hard way' with a fc3 dvd i have. I have fc3 running and tvtime etc works. but when i try and install zm from rpm it fails due to dependacies. I understand why it does this and why it needs them, but i cant find where to get them. In live cd mandrake you can just add packages. I cant see where to do this in fc3. I have googled for the packages and i found lame, but not the others, or the others failed other depandancies etc etc. Dont suppose you have a list of depandancies and where to get them order of install etc. I have tried installing 'everything' in the hope it would get me going but alas it was just wishful dreaming lol. I am going to install again a lighter version (as light as possible as its gonna be running on an old katmai 600). Any pointers would be really well recieved. Cheers mate hope the job huntings going well!!!
Regards James
Regards James
