How to receive the alerts email (step by step)
Camera login methods
There are two ways too pass login info to the cameras. The way to login is dependant on the method used by the camera.
If when you bring up your camera it pops up a login dialog box then
user:pass@yourcam
youcam being it IP or DNS entry
If you have to login via a url you need to post the info in the path using zm as example:
/cgi-bin/zms?<all the stream settings>&user=myuser&pass=mypass
The exact variables required can be differant depending on the camera. The quick and dirty way is bring up the login page for the camera and veiw the source to see what the variable names are.
Regards,
Cordel
user:pass@yourcam
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
I am using the remote host name:
http://name:passwd@ip.foo
This works from a browser but not from ZM.
Any ideas?
Mike
Any ideas?
Mike
