Can't view recorded events
if you can get still sthen its not a permission problem. I presume you can cycle thriugh the stills with no problem. I have had issues with mjpeg streaming on ie on larger networks ie with proxy servers for some reason, but i have installed ff and it was ok. When you click on an evenyt and you get the square with an x what does it say about the path?
James Wilson
The easiest way to go after this is to install cambozola.jar in your zm web root directory (Ex. /var/www/html/zm/cambozola.jar), set the checkbox to use it in options and for the path put "cambozola.jar"
Get this working first as it's easy to trouble shoot. Once you get this going you can be sure that zm is setup correctly then focus on getting ffmpeg to work. Going after both is a pain.
Regards,
Corey
Regards,
Corey
How can i troubleshoot Cambozola? Cambozola works with the live view and doesnt with recorded viewcordel wrote:The easiest way to go after this is to install cambozola.jar in your zm web root directory (Ex. /var/www/html/zm/cambozola.jar), set the checkbox to use it in options and for the path put "cambozola.jar"
Regards,
Corey
There is an error that will be logged on the server or will show in the java app on the client machine. You find this and it will be key to resolving the problem. Also be aware that php 5 has not really been thoughly tested. I loaded it back when FC4 released and you have to make ajustments in php for everything to work. It sounds like you have already got them but it's odd that live works and stored don't.
Any paticular reason for Debian?
Ross Makes a great Live CD base on Mandrake, and I put out a single CD installer base on FC3 and am wrapping up a 64 bit version.
Regards,
Cordel
Regards,
Cordel
I dont know what the in-code problem is but i found a solution :
I made a symbolic link in my /zm directory to my /video/images and /video/events.
Then i changed the paths in ZM back to /events and /images and everything works.
Can someone explain me why that is ?
Maybee there is something in the code of the video generation that doesnt detect a directory change in the options menu
- zoneminder
- Site Admin
- Contact:
Were your /video directories under the zm dir before? Currently they must be accessible as a relative path under zmI think so if you set them to /video/events then ZM will look in zm/video/events. This is set to change in the future but otherwise you at least have to have a symbolic link under zm.
Phil
Phil
- zoneminder
- Site Admin
- Contact:
The rpm version we have moved the events directory to /var/lib/zm You can change it it just needs to be changed in the console options under the path tab or done when you run perl zmconfig.pl and it has to be in the web root.
Otherwise (as done in the rpm) you have to setup apache to alias the directory to be in the web root.
Regards,
Corey
Regards,
Corey
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
