help zma has deleted all the db
Corey, do i install this myadmin the same way as sysinfo with webmin and file upload or is this one more involved?
James Wilson
If your mean the phpmyadmin to manage the DB you have to upload it just like I showed you using webmin to somewhere in the web root (/var/www/html/myadmin) Then you have to edit the config file for it to have access to the database. I don't know if phpmyadmin has a login screen through, I might be able to walk you through how to password protect that directory though like on my now "demo server"
Corey
Corey
im gonna call it a night tonight 1:41 here and have a look later tomorrow. I have done the upload thing through webmin nd read some of the docs and found the setup script, but im thinking i need ssh access as scripts dont run in webmin command prompt
cheers mate
cheers mate
James Wilson
could it be that zmaudit is taking longer than 900 seconds to process and more keep spawning?
James Wilson
- zoneminder
- Site Admin
- Contact:
its not that then lol
damn hoped i was onto something there.
James
James
James Wilson
