KMC4400R 4 chip - 16 input card problems getting to camera 5
technicavolous
Post by technicavolous »
I've been trying to get a picture of this card since Dec 29 - lol you'd think a video guy could take a freakin picture?? LOL!
Anyway in the mean time I had another issue come up with these cards that has convinced me you just can't use 'em for 16 cams but they work great in a pair. The trick is you have to define all the monitors, all 32, but you only activate and use 16 of 'em.
See
http://www.zoneminder.com/forums/viewtopic.php?t=10913
Here is a truth chart that I made to help myself map out the ports. As you know, the connector number doesn't correspond with the port number in software.
I use 'code' so it is monospaaaced ...
A= Monitor Number
B= Device Path
C= Device Channel
D= Translated C for second card to make setting up all 32 monitors in zm more clear
E= Color I assign to that monitor number for timeline
 Card 1              Card 2
 A  B           C    A  B           C   D     E
 1  /dev/video0 0    17 /dev/video4 0   16
 2  /dev/video0 1    18 /dev/video4 1   17
 3  /dev/video0 2    19 /dev/video4 2   18
 4  /dev/video0 3    20 /dev/video4 3   19
 5  /dev/video1 4    21 /dev/video5 4   20
 6  /dev/video1 5    22 /dev/video5 5   21
 7  /dev/video1 8    23 /dev/video5 8   24
 8  /dev/video1 9    24 /dev/video5 9   25
 9  /dev/video2 10   25 /dev/video6 10  26
 10 /dev/video2 11   26 /dev/video6 11  27
 11 /dev/video2 12   27 /dev/video6 12  28
 12 /dev/video2 13   28 /dev/video6 13  29
 13 /dev/video3 6    29 /dev/video7 6   22
 14 /dev/video3 7    30 /dev/video7 7   23
 15 /dev/video3 14   31 /dev/video7 14  30
 16 /dev/video3 15   32 /dev/video7 15  31
Rearranging for a little different logic, I get this -
 Card 1              Card 2
 A  B           C    A  B           C   D     E
 1  /dev/video0 0    17 /dev/video4 0   16    brown
 2  /dev/video0 1    18 /dev/video4 1   17    red
 3  /dev/video0 2    19 /dev/video4 2   18    orange
 4  /dev/video0 3    20 /dev/video4 3   19    yellow
 5  /dev/video1 4    21 /dev/video5 4   20    green
 6  /dev/video1 5    22 /dev/video5 5   21    blue
 7  /dev/video3 6    23 /dev/video7 6   22    violet
 8  /dev/video3 7    24 /dev/video7 7   23    gray
 9  /dev/video1 8    25 /dev/video5 8   24    tan
 10 /dev/video1 9    26 /dev/video5 9   25    black
 11 /dev/video2 10   27 /dev/video6 10  26    maroon
 12 /dev/video2 11   28 /dev/video6 11  27    crimson
 13 /dev/video2 12   29 /dev/video6 12  28    gold
 14 /dev/video2 13   30 /dev/video6 13  29    goldenrod
 15 /dev/video3 14   31 /dev/video7 14  30    olive
 16 /dev/video3 15   32 /dev/video7 15  31    purple
I activate these (modect, enabled)
 Card 1              Card 2
 A  B           C    A  B           C   D     E
 1  /dev/video0 0    18 /dev/video4 1   17
 3  /dev/video0 2    20 /dev/video4 3   19
 5  /dev/video1 4    22 /dev/video5 5   21
 7  /dev/video1 8    24 /dev/video5 9   25
 9  /dev/video2 10   26 /dev/video6 11  27
 11 /dev/video2 12   28 /dev/video6 13  29
 13 /dev/video3 6    30 /dev/video7 7   23
 15 /dev/video3 14   32 /dev/video7 15  31
And then set up a Monitor Group of only the activated monitors and apply it. Viola, 16 monitors that work, make sense and are easily managable.
Works for me ...
Tracy Markham
alecano23
Post by alecano23 »
Hello everybody, I am reading all the forum since monday to find a FINAL SOLUTION to the problem that KMC 4400 has to enable more than 4 cams??? How to configure?? I have set
/dev/video0 0
/dev/video1 1
/dev/video2 2
/dev/video3 3
For the first four, but want to add 2 more and I cant..
please help me
technicavolous
You're using just the first port off of each channel on the card. The card has four channels (chips) with four ports each.
Try setting up for EIGHT cameras and only connect / activate six. Use the chart from the first page of this topic.
Something like
/dev/video0 0
/dev/video0 1
/dev/video1 2
/dev/video1 3
/dev/video2 4
/dev/video2 5
/dev/video3 6
/dev/video3 7
Try that or some variation - remember the physical connectors aren't in the order you think they might be. Study the charts on this post you'll figure it out! ;]
Tracy Markham
If you take the path of least resistance, you're probably on a downhill journey ...
Skid
Re: KMC4400R 4 chip - 16 input card problems getting to came
Post by Skid »
@technicavolous
Did you install the first expansor (for cameras 5,6,7,8) at the SECOND 4 pairs of pins starting left?
technicavolous
God it's been a long time ... but on that version of the card I believe you are correct. I do remember that they didn't seem to be in a logical order; we discovered by poking around the ports with a couple of cameras. Trial and error, more error than success until we finally got it. I believe there is a better explanation on one of the V4L forums but I don't recall where.
Tracy Markham
