random ending of events
jameswilson
Post by jameswilson »
this seems related but tracking isnt turned on
Mar 20 20:25:05 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 18']
Mar 20 20:25:06 localhost zma_m18[27557]: INF [In mode 4/1, warming up]
Mar 20 20:25:10 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 19']
Mar 20 20:25:11 localhost zma_m19[27659]: INF [In mode 4/1, warming up]
Mar 20 20:25:14 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 20']
Mar 20 20:25:14 localhost zma_m20[27725]: INF [In mode 4/1, warming up]
Mar 20 20:25:17 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 21']
Mar 20 20:25:18 localhost zmdc[17139]: WAR [Can't find process with command of 'zma -m 21']
Mar 20 20:25:26 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 22']
Mar 20 20:25:26 localhost zmdc[17139]: WAR [Can't find process with command of 'zma -m 22']
Mar 20 20:25:40 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 23']
Mar 20 20:25:40 localhost zma_m23[28214]: INF [In mode 4/1, warming up]
Mar 20 20:25:44 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 24']
Mar 20 20:25:44 localhost zma_m24[28304]: INF [In mode 4/1, warming up]
Mar 20 20:38:29 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 2']
Mar 20 20:38:30 localhost zma_m2[8001]: INF [In mode 4/1, warming up]
Mar 20 20:38:32 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 3']
Mar 20 20:38:33 localhost zma_m3[8077]: INF [In mode 4/1, warming up]
Mar 20 20:38:36 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 4']
Mar 20 20:38:37 localhost zma_m4[8164]: INF [In mode 4/1, warming up]
Mar 20 20:38:41 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 5']
Mar 20 20:38:41 localhost zma_m5[8253]: INF [In mode 4/1, warming up]
Mar 20 20:38:45 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 6']
Mar 20 20:38:45 localhost zma_m6[8347]: INF [In mode 4/1, warming up]
Mar 20 20:38:48 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 7']
Mar 20 20:38:48 localhost zma_m7[8411]: INF [In mode 4/1, warming up]
Mar 20 20:38:52 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 8']
Mar 20 20:38:53 localhost zma_m8[8506]: INF [In mode 4/1, warming up]
Mar 20 20:39:01 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 9']
Mar 20 20:39:02 localhost zma_m9[8686]: INF [In mode 4/1, warming up]
Mar 20 20:39:11 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 10']
Mar 20 20:39:12 localhost zma_m10[8862]: INF [In mode 4/1, warming up]
Mar 20 20:39:14 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 11']
Mar 20 20:39:15 localhost zma_m11[8938]: INF [In mode 4/1, warming up]
Mar 20 20:39:34 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 12']
Mar 20 20:39:34 localhost zma_m12[9335]: INF [In mode 4/1, warming up]
Mar 20 20:40:01 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 13']
Mar 20 20:40:02 localhost zma_m13[9796]: WAR [Waiting for capture daemon]
Mar 20 20:40:03 localhost zma_m13[9796]: INF [In mode 4/1, warming up]
Mar 20 20:40:06 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 14']
Mar 20 20:40:06 localhost zma_m14[9889]: INF [In mode 4/1, warming up]
Mar 20 20:40:10 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 15']
Mar 20 20:40:11 localhost zma_m15[9993]: INF [In mode 4/1, warming up]
Mar 20 20:40:15 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 16']
Mar 20 20:40:16 localhost zma_m16[10083]: INF [In mode 4/1, warming up]
Mar 20 20:40:20 localhost zmdc[17139]: WAR [Can't find process with command of 'zmtrack.pl -m 17']
Mar 20 20:40:20 localhost zmdc[17139]: WAR [Can't find process with command of 'zma -m 17']
James Wilson
jameswilson
Im wondering as i havnt seen this behaviour before if its possible to downgrade to 1.21.4? or .3? This would also help decided if its 1.22.0 thats the issue or something else. Is anyone else running 1.22.0 with over 20 cams?
James Wilson
jameswilson
Another thing ive just wondered is 1 gig of ram enough? If th system was swapping that would kill performance. Ihave notice that the load is usuaaly around 1-2 but when its creating thousands of events per hour its load is 10-11. I assumed this load increase was due to the fact it was constantly resttarting processes etc but i suppose it could be cos its swapping
James Wilson
jameswilson
No its not swapping! I had started doing it again this moprning so i checked the mem use and is exactly the same as it has been. Im, gonna trawl through syslog and see if i can see when it started
James Wilson
jameswilson
Right more info
I have trawl the logs after finding via zm db that it was perfect til 05:02 this morning basically it was creating new events every 10 mins as expectd at $:40, 4:50, 5:00 as expected
then at 5:02:01 another one was created then 5:02:04 then 05:02:06 etc
I have viewed the syslog from 5:00 to look for error and i cant see any, zm just ends the evnts and starts them again
syslog below !CAUTION this is just 2 mins of log and its massive
[quote]Mar 22 05:00:00 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:00:00 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:00:01 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:00:07 localhost zma_m19[3094]: INF [Cam_18: 145621 - Starting new event 1454575]
Mar 22 05:00:07 localhost zma_m16[3047]: INF [Cam_15: 156690 - Starting new event 1454574]
Mar 22 05:00:07 localhost zma_m21[3124]: INF [Cam_20: 145410 - Starting new event 1454585]
Mar 22 05:00:08 localhost zma_m4[2902]: INF [Cam_3: 163215 - Starting new event 1454573]
Mar 22 05:00:08 localhost zma_m20[3108]: INF [Cam_19: 144860 - Starting new event 1454586]
Mar 22 05:00:08 localhost zma_m10[2972]: INF [Cam_9: 158906 - Starting new event 1454588]
Mar 22 05:00:08 localhost zma_m11[2980]: INF [Cam_10: 158917 - Starting new event 1454582]
Mar 22 05:00:08 localhost zma_m12[2988]: INF [Cam_11: 158958 - Starting new event 1454580]
Mar 22 05:00:08 localhost zma_m13[3000]: INF [Cam_12: 158888 - Starting new event 1454576]
Mar 22 05:00:08 localhost zma_m15[3035]: INF [Cam_14: 156400 - Starting new event 1454587]
Mar 22 05:00:08 localhost zma_m14[3023]: INF [Cam_13: 156796 - Starting new event 1454583]
Mar 22 05:00:09 localhost zmc_dvideo1[2917]: INF [Cam_8: 162000 - Capturing at 2.11 fps]
Mar 22 05:00:09 localhost zma_m22[3142]: INF [Cam_21: 145524 - Starting new event 1454589]
Mar 22 05:00:09 localhost zma_m24[3174]: INF [Cam_23: 145504 - Starting new event 1454593]
Mar 22 05:00:09 localhost zma_m23[3157]: INF [Cam_22: 145497 - Starting new event 1454577]
Mar 22 05:00:09 localhost zma_m2[2873]: INF [Cam_1: 162945 - Starting new event 1454579]
Mar 22 05:00:09 localhost zma_m3[2888]: INF [Cam_2: 163333 - Starting new event 1454590]
Mar 22 05:00:09 localhost zma_m9[2958]: INF [Cam_8: 159200 - Starting new event 1454581]
Mar 22 05:00:09 localhost zma_m8[2944]: INF [Cam_7: 159253 - Starting new event 1454578]
Mar 22 05:00:09 localhost zma_m7[2932]: INF [Cam_6: 159055 - Starting new event 1454584]
Mar 22 05:00:10 localhost zma_m18[3076]: INF [Cam_17: 144135 - Starting new event 1454594]
Mar 22 05:00:10 localhost zma_m5[2912]: INF [Cam_4: 163250 - Starting new event 1454591]
Mar 22 05:00:11 localhost zma_m6[2924]: INF [Cam_5: 159132 - Starting new event 1454592]
Mar 22 05:00:15 localhost zmc_dvideo0[2868]: INF [Cam_4: 166000 - Capturing at 2.11 fps]
Mar 22 05:00:24 localhost zma_m12[2988]: INF [Cam_11: 159000 - Processing at 2.09 fps]
Mar 22 05:00:30 localhost zma_m2[2873]: INF [Cam_1: 163000 - Processing at 2.12 fps]
Mar 22 05:00:34 localhost zmc_dvideo1[2917]: INF [Cam_5: 162000 - Capturing at 2.11 fps]
Mar 22 05:00:37 localhost zmc_dvideo1[2917]: INF [Cam_7: 162000 - Capturing at 2.10 fps]
Mar 22 05:00:38 localhost zmc_dvideo0[2868]: INF [Cam_2: 166000 - Capturing at 2.12 fps]
Mar 22 05:00:43 localhost zma_m11[2980]: INF [Cam_10: 159000 - Processing at 2.08 fps]
Mar 22 05:00:44 localhost zmc_dvideo1[2917]: INF [Cam_6: 162000 - Capturing at 2.11 fps]
Mar 22 05:00:47 localhost zma_m10[2972]: INF [Cam_9: 159000 - Processing at 2.10 fps]
Mar 22 05:00:56 localhost zma_m13[3000]: INF [Cam_12: 159000 - Processing at 2.08 fps]
Mar 22 05:01:12 localhost zma_m20[3108]: INF [Cam_19: 145000 - Processing at 2.01 fps]
Mar 22 05:01:12 localhost zmc_m19[3087]: INF [Cam_18: 148000 - Capturing at 2.03 fps]
Mar 22 05:01:24 localhost zmc_dvideo0[2868]: INF [Cam_3: 166000 - Capturing at 2.12 fps]
Mar 22 05:01:27 localhost zmc_m22[3133]: INF [Cam_21: 148000 - Capturing at 2.03 fps]
Mar 22 05:01:34 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:01:35 localhost zma_m22[3142]: INF [Cam_21: 145708 - Starting new event 1454595]
Mar 22 05:01:39 localhost zma_m14[3023]: INF [Cam_13: 157000 - Processing at 2.10 fps]
Mar 22 05:01:53 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:01:53 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:01:55 localhost zma_m19[3094]: INF [Cam_18: 145844 - Starting new event 1454596]
Mar 22 05:01:55 localhost zma_m22[3142]: INF [Cam_21: 145747 - Starting new event 1454597]
Mar 22 05:01:53 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:01:55 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:01:53 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:01:55 localhost zma_m12[2988]: INF [Cam_11: 159187 - Starting new event 1454598]
Mar 22 05:01:55 localhost zma_m18[3076]: INF [Cam_17: 144349 - Starting new event 1454599]
Mar 22 05:01:54 localhost zma_m22[3142]: INF [Cam_21: 145749 - Starting new event 1454601]
Mar 22 05:01:54 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:01:54 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:01:54 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m18[3076]: INF [Cam_17: 144351 - Starting new event 1454603]
Mar 22 05:01:56 localhost zma_m21[3124]: INF [Cam_20: 145626 - Starting new event 1454600]
Mar 22 05:01:56 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:01:54 localhost zma_m13[3000]: INF [Cam_12: 159119 - Starting new event 1454602]
Mar 22 05:01:54 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:01:54 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:01:54 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:01:54 localhost zma_m19[3094]: INF [Cam_18: 145848 - Starting new event 1454606]
Mar 22 05:01:56 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m4[2902]: INF [Cam_3: 163450 - Starting new event 1454604]
Mar 22 05:01:54 localhost zma_m12[2988]: INF [Cam_11: 159189 - Starting new event 1454607]
Mar 22 05:01:56 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:01:54 localhost zma_m24[3174]: INF [Cam_23: 145730 - Starting new event 1454605]
Mar 22 05:01:55 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:01:55 localhost zma_m18[3076]: INF [Cam_17: 144354 - Starting new event 1454611]
Mar 22 05:01:55 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:01:55 localhost zma_m6[2924]: INF [Cam_5: 159360 - Starting new event 1454608]
Mar 22 05:01:57 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:01:55 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m21[3124]: INF [Cam_20: 145631 - Starting new event 1454615]
Mar 22 05:01:57 localhost zma_m8[2944]: INF [Cam_7: 159486 - Starting new event 1454610]
Mar 22 05:01:57 localhost zma_m7[2932]: INF [Cam_6: 159284 - Starting new event 1454609]
Mar 22 05:01:57 localhost zma_m20[3108]: INF [Cam_19: 145086 - Starting new event 1454612]
Mar 22 05:01:57 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:01:55 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m16[3047]: INF [Cam_15: 156925 - Starting new event 1454613]
Mar 22 05:01:56 localhost zma_m23[3157]: INF [Cam_22: 145724 - Starting new event 1454614]
Mar 22 05:01:56 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m8[2944]: INF [Cam_7: 159488 - Starting new event 1454616]
Mar 22 05:01:57 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:01:58 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:01:58 localhost zma_m22[3142]: INF [Cam_21: 145755 - Starting new event 1454617]
Mar 22 05:01:58 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m20[3108]: INF [Cam_19: 145089 - Starting new event 1454620]
Mar 22 05:01:56 localhost zma_m7[2932]: INF [Cam_6: 159287 - Starting new event 1454623]
Mar 22 05:01:58 localhost zma_m24[3174]: INF [Cam_23: 145735 - Starting new event 1454622]
Mar 22 05:01:56 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:01:58 localhost zma_m9[2958]: INF [Cam_8: 159436 - Starting new event 1454618]
Mar 22 05:01:56 localhost zma_m8[2944]: INF [Cam_7: 159490 - Starting new event 1454625]
Mar 22 05:01:56 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m13[3000]: INF [Cam_12: 159125 - Starting new event 1454626]
Mar 22 05:01:56 localhost zma_m6[2924]: INF [Cam_5: 159364 - Starting new event 1454627]
Mar 22 05:01:58 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:01:56 localhost zma_m9[2958]: INF [Cam_8: 159438 - Starting new event 1454629]
Mar 22 05:01:58 localhost zma_m4[2902]: INF [Cam_3: 163455 - Starting new event 1454624]
Mar 22 05:01:57 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:01:58 localhost zma_m5[2912]: INF [Cam_4: 163486 - Starting new event 1454621]
Mar 22 05:01:57 localhost zma_m11[2980]: INF [Cam_10: 159150 - Starting new event 1454619]
Mar 22 05:01:58 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m23[3157]: INF [Cam_22: 145729 - Starting new event 1454630]
Mar 22 05:01:57 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m12[2988]: INF [Cam_11: 159195 - Starting new event 1454632]
Mar 22 05:01:59 localhost zma_m11[2980]: INF [Cam_10: 159152 - Starting new event 1454633]
Mar 22 05:01:57 localhost zma_m21[3124]: INF [Cam_20: 145636 - Starting new event 1454634]
Mar 22 05:01:57 localhost zma_m23[3157]: INF [Cam_22: 145731 - Starting new event 1454635]
Mar 22 05:01:59 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m18[3076]: INF [Cam_17: 144359 - Starting new event 1454631]
Mar 22 05:01:57 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m16[3047]: INF [Cam_15: 156930 - Starting new event 1454636]
Mar 22 05:01:59 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m10[2972]: INF [Cam_9: 159144 - Starting new event 1454628]
Mar 22 05:01:59 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:01:57 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m9[2958]: INF [Cam_8: 159440 - Starting new event 1454637]
Mar 22 05:01:58 localhost zma_m24[3174]: INF [Cam_23: 145739 - Starting new event 1454638]
Mar 22 05:01:59 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:01:58 localhost zma_m21[3124]: INF [Cam_20: 145638 - Starting new event 1454639]
Mar 22 05:01:58 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:01:58 localhost zma_m10[2972]: INF [Cam_9: 159146 - Starting new event 1454640]
Mar 22 05:02:00 localhost zma_m18[3076]: INF [Cam_17: 144362 - Starting new event 1454641]
Mar 22 05:02:00 localhost zma_m11[2980]: INF [Cam_10: 159154 - Starting new event 1454642]
Mar 22 05:02:00 localhost zma_m7[2932]: INF [Cam_6: 159290 - Starting new event 1454643]
Mar 22 05:02:00 localhost zma_m19[3094]: INF [Cam_18: 145856 - Starting new event 1454644]
Mar 22 05:01:58 localhost zma_m8[2944]: INF [Cam_7: 159493 - Starting new event 1454645]
Mar 22 05:02:00 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:01:58 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m9[2958]: INF [Cam_8: 159442 - Starting new event 1454646]
Mar 22 05:02:00 localhost zma_m22[3142]: INF [Cam_21: 145759 - Starting new event 1454647]
Mar 22 05:02:00 localhost zma_m23[3157]: INF [Cam_22: 145734 - Starting new event 1454648]
Mar 22 05:02:00 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m6[2924]: INF [Cam_5: 159367 - Starting new event 1454649]
Mar 22 05:02:00 localhost zma_m16[3047]: INF [Cam_15: 156933 - Starting new event 1454650]
Mar 22 05:02:01 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m24[3174]: INF [Cam_23: 145742 - Starting new event 1454651]
Mar 22 05:01:59 localhost zma_m4[2902]: INF [Cam_3: 163460 - Starting new event 1454652]
Mar 22 05:01:59 localhost zma_m18[3076]: INF [Cam_17: 144365 - Starting new event 1454653]
Mar 22 05:01:59 localhost zma_m22[3142]: INF [Cam_21: 145761 - Starting new event 1454654]
Mar 22 05:01:59 localhost zma_m20[3108]: INF [Cam_19: 145096 - Starting new event 1454655]
Mar 22 05:02:01 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m21[3124]: INF [Cam_20: 145641 - Starting new event 1454656]
Mar 22 05:02:01 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:01 localhost zma_m16[3047]: INF [Cam_15: 156935 - Starting new event 1454657]
Mar 22 05:02:01 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:01:59 localhost zma_m24[3174]: INF [Cam_23: 145744 - Starting new event 1454658]
Mar 22 05:02:00 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:01 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m18[3076]: INF [Cam_17: 144367 - Starting new event 1454659]
Mar 22 05:02:00 localhost zma_m23[3157]: INF [Cam_22: 145738 - Starting new event 1454660]
Mar 22 05:02:02 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m22[3142]: INF [Cam_21: 145764 - Starting new event 1454661]
Mar 22 05:02:02 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m5[2912]: INF [Cam_4: 163495 - Starting new event 1454662]
Mar 22 05:02:00 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:00 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:01 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:01 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:03 localhost zma_m2[2873]: INF [Cam_1: 163192 - Starting new event 1454663]
Mar 22 05:02:03 localhost zma_m4[2902]: INF [Cam_3: 163464 - Starting new event 1454665]
Mar 22 05:02:03 localhost zma_m3[2888]: INF [Cam_2: 163579 - Starting new event 1454664]
Mar 22 05:02:01 localhost zma_m12[2988]: INF [Cam_11: 159202 - Starting new event 1454667]
Mar 22 05:02:03 localhost zma_m8[2944]: INF [Cam_7: 159498 - Starting new event 1454668]
Mar 22 05:02:01 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:03 localhost zma_m9[2958]: INF [Cam_8: 159447 - Starting new event 1454669]
Mar 22 05:02:01 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:01 localhost zma_m11[2980]: INF [Cam_10: 159159 - Starting new event 1454666]
Mar 22 05:02:01 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:03 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:01 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:01 localhost zma_m19[3094]: INF [Cam_18: 145864 - Starting new event 1454670]
Mar 22 05:02:03 localhost zma_m21[3124]: INF [Cam_20: 145645 - Starting new event 1454671]
Mar 22 05:02:03 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m22[3142]: INF [Cam_21: 145767 - Starting new event 1454672]
Mar 22 05:02:02 localhost zma_m24[3174]: INF [Cam_23: 145749 - Starting new event 1454673]
Mar 22 05:02:04 localhost zma_m10[2972]: INF [Cam_9: 159152 - Starting new event 1454674]
Mar 22 05:02:02 localhost zma_m18[3076]: INF [Cam_17: 144372 - Starting new event 1454675]
Mar 22 05:02:02 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m6[2924]: INF [Cam_5: 159373 - Starting new event 1454676]
Mar 22 05:02:02 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:02 localhost zma_m7[2932]: INF [Cam_6: 159297 - Starting new event 1454677]
Mar 22 05:02:04 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m23[3157]: INF [Cam_22: 145743 - Starting new event 1454678]
Mar 22 05:02:04 localhost zma_m5[2912]: INF [Cam_4: 163499 - Starting new event 1454679]
Mar 22 05:02:04 localhost zma_m2[2873]: INF [Cam_1: 163196 - Starting new event 1454680]
Mar 22 05:02:02 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m8[2944]: INF [Cam_7: 159501 - Starting new event 1454681]
Mar 22 05:02:02 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:03 localhost zma_m16[3047]: INF [Cam_15: 156941 - Starting new event 1454682]
Mar 22 05:02:04 localhost zma_m13[3000]: INF [Cam_12: 159134 - Starting new event 1454683]
Mar 22 05:02:03 localhost zma_m11[2980]: INF [Cam_10: 159161 - Starting new event 1454684]
Mar 22 05:02:03 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m9[2958]: INF [Cam_8: 159449 - Starting new event 1454685]
Mar 22 05:02:05 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:03 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:03 localhost zma_m19[3094]: INF [Cam_18: 145866 - Starting new event 1454686]
Mar 22 05:02:03 localhost zma_m21[3124]: INF [Cam_20: 145648 - Starting new event 1454687]
Mar 22 05:02:05 localhost zma_m24[3174]: INF [Cam_23: 145753 - Starting new event 1454688]
Mar 22 05:02:03 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m22[3142]: INF [Cam_21: 145770 - Starting new event 1454689]
Mar 22 05:02:03 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:03 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m20[3108]: INF [Cam_19: 145104 - Starting new event 1454690]
Mar 22 05:02:04 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m7[2932]: INF [Cam_6: 159300 - Starting new event 1454691]
Mar 22 05:02:06 localhost zma_m23[3157]: INF [Cam_22: 145745 - Starting new event 1454692]
Mar 22 05:02:04 localhost zma_m10[2972]: INF [Cam_9: 159157 - Starting new event 1454693]
Mar 22 05:02:06 localhost zma_m8[2944]: INF [Cam_7: 159504 - Starting new event 1454694]
Mar 22 05:02:04 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m4[2902]: INF [Cam_3: 163470 - Starting new event 1454695]
Mar 22 05:02:04 localhost zma_m11[2980]: INF [Cam_10: 159165 - Starting new event 1454696]
Mar 22 05:02:04 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:04 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m13[3000]: INF [Cam_12: 159136 - Starting new event 1454697]
Mar 22 05:02:05 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m21[3124]: INF [Cam_20: 145651 - Starting new event 1454699]
Mar 22 05:02:06 localhost zma_m18[3076]: INF [Cam_17: 144379 - Starting new event 1454698]
Mar 22 05:02:05 localhost zma_m19[3094]: INF [Cam_18: 145869 - Starting new event 1454700]
Mar 22 05:02:07 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:07 localhost zma_m24[3174]: INF [Cam_23: 145758 - Starting new event 1454701]
Mar 22 05:02:07 localhost zma_m9[2958]: INF [Cam_8: 159453 - Starting new event 1454702]
Mar 22 05:02:07 localhost zma_m5[2912]: INF [Cam_4: 163505 - Starting new event 1454703]
Mar 22 05:02:07 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:07 localhost zma_m22[3142]: INF [Cam_21: 145772 - Starting new event 1454704]
Mar 22 05:02:07 localhost zma_m12[2988]: INF [Cam_11: 159209 - Starting new event 1454705]
Mar 22 05:02:05 localhost zma_m2[2873]: INF [Cam_1: 163201 - Starting new event 1454706]
Mar 22 05:02:05 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:05 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m6[2924]: INF [Cam_5: 159379 - Starting new event 1454707]
Mar 22 05:02:07 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m23[3157]: INF [Cam_22: 145748 - Starting new event 1454708]
Mar 22 05:02:06 localhost zma_m10[2972]: INF [Cam_9: 159161 - Starting new event 1454709]
Mar 22 05:02:08 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m7[2932]: INF [Cam_6: 159304 - Starting new event 1454711]
Mar 22 05:02:06 localhost zma_m8[2944]: INF [Cam_7: 159508 - Starting new event 1454712]
Mar 22 05:02:08 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m16[3047]: INF [Cam_15: 156948 - Starting new event 1454714]
Mar 22 05:02:08 localhost zma_m4[2902]: INF [Cam_3: 163472 - Starting new event 1454715]
Mar 22 05:02:06 localhost zma_m14[3023]: INF [Cam_13: 157050 - Starting new event 1454710]
Mar 22 05:02:08 localhost zma_m20[3108]: INF [Cam_19: 145110 - Starting new event 1454716]
Mar 22 05:02:08 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:06 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m15[3035]: INF [Cam_14: 156652 - Starting new event 1454713]
Mar 22 05:02:08 localhost zma_m3[2888]: INF [Cam_2: 163589 - Starting new event 1454717]
Mar 22 05:02:07 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m13[3000]: INF [Cam_12: 159139 - Starting new event 1454718]
Mar 22 05:02:08 localhost zma_m18[3076]: INF [Cam_17: 144382 - Starting new event 1454719]
Mar 22 05:02:07 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:07 localhost zma_m19[3094]: INF [Cam_18: 145871 - Starting new event 1454720]
Mar 22 05:02:09 localhost zma_m24[3174]: INF [Cam_23: 145763 - Starting new event 1454721]
Mar 22 05:02:07 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:07 localhost zma_m9[2958]: INF [Cam_8: 159455 - Starting new event 1454722]
Mar 22 05:02:09 localhost zma_m5[2912]: INF [Cam_4: 163508 - Starting new event 1454723]
Mar 22 05:02:09 localhost zma_m22[3142]: INF [Cam_21: 145775 - Starting new event 1454724]
Mar 22 05:02:07 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m12[2988]: INF [Cam_11: 159213 - Starting new event 1454725]
Mar 22 05:02:07 localhost zma_m11[2980]: INF [Cam_10: 159171 - Starting new event 1454727]
Mar 22 05:02:07 localhost zma_m6[2924]: INF [Cam_5: 159381 - Starting new event 1454726]
Mar 22 05:02:07 localhost zma_m23[3157]: INF [Cam_22: 145752 - Starting new event 1454728]
Mar 22 05:02:09 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m10[2972]: INF [Cam_9: 159165 - Starting new event 1454729]
Mar 22 05:02:09 localhost zma_m2[2873]: INF [Cam_1: 163206 - Starting new event 1454730]
Mar 22 05:02:08 localhost zma_m8[2944]: INF [Cam_7: 159512 - Starting new event 1454731]
Mar 22 05:02:08 localhost zma_m4[2902]: INF [Cam_3: 163474 - Starting new event 1454732]
Mar 22 05:02:10 localhost zma_m16[3047]: INF [Cam_15: 156952 - Starting new event 1454733]
Mar 22 05:02:10 localhost zma_m21[3124]: INF [Cam_20: 145660 - Starting new event 1454734]
Mar 22 05:02:10 localhost zma_m14[3023]: INF [Cam_13: 157054 - Starting new event 1454735]
Mar 22 05:02:10 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m15[3035]: INF [Cam_14: 156656 - Starting new event 1454736]
Mar 22 05:02:10 localhost zma_m20[3108]: INF [Cam_19: 145114 - Starting new event 1454737]
Mar 22 05:02:10 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:08 localhost zma_m3[2888]: INF [Cam_2: 163591 - Starting new event 1454738]
Mar 22 05:02:10 localhost zma_m13[3000]: INF [Cam_12: 159142 - Starting new event 1454739]
Mar 22 05:02:08 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m18[3076]: INF [Cam_17: 144384 - Starting new event 1454740]
Mar 22 05:02:08 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m19[3094]: INF [Cam_18: 145873 - Starting new event 1454741]
Mar 22 05:02:10 localhost zma_m9[2958]: INF [Cam_8: 159459 - Starting new event 1454742]
Mar 22 05:02:08 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m24[3174]: INF [Cam_23: 145765 - Starting new event 1454743]
Mar 22 05:02:10 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m5[2912]: INF [Cam_4: 163510 - Starting new event 1454744]
Mar 22 05:02:08 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m6[2924]: INF [Cam_5: 159385 - Starting new event 1454745]
Mar 22 05:02:09 localhost zma_m22[3142]: INF [Cam_21: 145781 - Starting new event 1454746]
Mar 22 05:02:10 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m23[3157]: INF [Cam_22: 145754 - Starting new event 1454747]
Mar 22 05:02:09 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m11[2980]: INF [Cam_10: 159175 - Starting new event 1454748]
Mar 22 05:02:09 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m4[2902]: INF [Cam_3: 163476 - Starting new event 1454749]
Mar 22 05:02:11 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m16[3047]: INF [Cam_15: 156955 - Starting new event 1454750]
Mar 22 05:02:09 localhost zma_m14[3023]: INF [Cam_13: 157057 - Starting new event 1454751]
Mar 22 05:02:11 localhost zma_m8[2944]: INF [Cam_7: 159515 - Starting new event 1454752]
Mar 22 05:02:09 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m12[2988]: INF [Cam_11: 159218 - Starting new event 1454753]
Mar 22 05:02:11 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m20[3108]: INF [Cam_19: 145117 - Starting new event 1454755]
Mar 22 05:02:11 localhost zma_m15[3035]: INF [Cam_14: 156659 - Starting new event 1454754]
Mar 22 05:02:09 localhost zma_m3[2888]: INF [Cam_2: 163593 - Starting new event 1454756]
Mar 22 05:02:11 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:09 localhost zma_m13[3000]: INF [Cam_12: 159147 - Starting new event 1454757]
Mar 22 05:02:09 localhost zma_m10[2972]: INF [Cam_9: 159170 - Starting new event 1454758]
Mar 22 05:02:09 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m9[2958]: INF [Cam_8: 159461 - Starting new event 1454759]
Mar 22 05:02:09 localhost zma_m7[2932]: INF [Cam_6: 159312 - Starting new event 1454760]
Mar 22 05:02:11 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m19[3094]: INF [Cam_18: 145880 - Starting new event 1454761]
Mar 22 05:02:10 localhost zma_m24[3174]: INF [Cam_23: 145769 - Starting new event 1454762]
Mar 22 05:02:11 localhost zma_m5[2912]: INF [Cam_4: 163514 - Starting new event 1454763]
Mar 22 05:02:10 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m6[2924]: INF [Cam_5: 159389 - Starting new event 1454764]
Mar 22 05:02:10 localhost zma_m21[3124]: INF [Cam_20: 145666 - Starting new event 1454765]
Mar 22 05:02:10 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m23[3157]: INF [Cam_22: 145756 - Starting new event 1454766]
Mar 22 05:02:12 localhost zma_m4[2902]: INF [Cam_3: 163478 - Starting new event 1454767]
Mar 22 05:02:12 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m14[3023]: INF [Cam_13: 157059 - Starting new event 1454768]
Mar 22 05:02:12 localhost zma_m8[2944]: INF [Cam_7: 159517 - Starting new event 1454769]
Mar 22 05:02:10 localhost zma_m2[2873]: INF [Cam_1: 163213 - Starting new event 1454770]
Mar 22 05:02:12 localhost zma_m22[3142]: INF [Cam_21: 145788 - Starting new event 1454771]
Mar 22 05:02:10 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m15[3035]: INF [Cam_14: 156661 - Starting new event 1454772]
Mar 22 05:02:12 localhost zma_m20[3108]: INF [Cam_19: 145120 - Starting new event 1454774]
Mar 22 05:02:10 localhost zma_m16[3047]: INF [Cam_15: 156959 - Starting new event 1454773]
Mar 22 05:02:12 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:10 localhost zma_m3[2888]: INF [Cam_2: 163595 - Starting new event 1454775]
Mar 22 05:02:10 localhost zma_m9[2958]: INF [Cam_8: 159464 - Starting new event 1454776]
Mar 22 05:02:12 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m13[3000]: INF [Cam_12: 159150 - Starting new event 1454777]
Mar 22 05:02:10 localhost zma_m10[2972]: INF [Cam_9: 159173 - Starting new event 1454778]
Mar 22 05:02:12 localhost zma_m24[3174]: INF [Cam_23: 145772 - Starting new event 1454779]
Mar 22 05:02:11 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m19[3094]: INF [Cam_18: 145883 - Starting new event 1454780]
Mar 22 05:02:11 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m5[2912]: INF [Cam_4: 163517 - Starting new event 1454781]
Mar 22 05:02:12 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m11[2980]: INF [Cam_10: 159179 - Starting new event 1454782]
Mar 22 05:02:11 localhost zma_m21[3124]: INF [Cam_20: 145669 - Starting new event 1454783]
Mar 22 05:02:11 localhost zma_m12[2988]: INF [Cam_11: 159222 - Starting new event 1454784]
Mar 22 05:02:13 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m4[2902]: INF [Cam_3: 163481 - Starting new event 1454785]
Mar 22 05:02:11 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m18[3076]: INF [Cam_17: 144393 - Starting new event 1454786]
Mar 22 05:02:11 localhost zma_m2[2873]: INF [Cam_1: 163215 - Starting new event 1454787]
Mar 22 05:02:11 localhost zma_m14[3023]: INF [Cam_13: 157062 - Starting new event 1454788]
Mar 22 05:02:13 localhost zma_m15[3035]: INF [Cam_14: 156663 - Starting new event 1454789]
Mar 22 05:02:13 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:11 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m20[3108]: INF [Cam_19: 145124 - Starting new event 1454790]
Mar 22 05:02:11 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m24[3174]: INF [Cam_23: 145776 - Starting new event 1454791]
Mar 22 05:02:13 localhost zma_m13[3000]: INF [Cam_12: 159152 - Starting new event 1454792]
Mar 22 05:02:11 localhost zma_m10[2972]: INF [Cam_9: 159175 - Starting new event 1454793]
Mar 22 05:02:13 localhost zma_m8[2944]: INF [Cam_7: 159521 - Starting new event 1454794]
Mar 22 05:02:13 localhost zma_m22[3142]: INF [Cam_21: 145792 - Starting new event 1454795]
Mar 22 05:02:13 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m5[2912]: INF [Cam_4: 163519 - Starting new event 1454796]
Mar 22 05:02:13 localhost zma_m11[2980]: INF [Cam_10: 159181 - Starting new event 1454797]
Mar 22 05:02:12 localhost zma_m9[2958]: INF [Cam_8: 159469 - Starting new event 1454798]
Mar 22 05:02:12 localhost zma_m23[3157]: INF [Cam_22: 145763 - Starting new event 1454799]
Mar 22 05:02:14 localhost zma_m16[3047]: INF [Cam_15: 156962 - Starting new event 1454800]
Mar 22 05:02:12 localhost zma_m21[3124]: INF [Cam_20: 145672 - Starting new event 1454801]
Mar 22 05:02:14 localhost zma_m19[3094]: INF [Cam_18: 145887 - Starting new event 1454802]
Mar 22 05:02:14 localhost zma_m6[2924]: INF [Cam_5: 159394 - Starting new event 1454803]
Mar 22 05:02:12 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m15[3035]: INF [Cam_14: 156666 - Starting new event 1454804]
Mar 22 05:02:14 localhost zma_m14[3023]: INF [Cam_13: 157065 - Starting new event 1454805]
Mar 22 05:02:12 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m7[2932]: INF [Cam_6: 159317 - Starting new event 1454806]
Mar 22 05:02:14 localhost zma_m18[3076]: INF [Cam_17: 144396 - Starting new event 1454807]
Mar 22 05:02:14 localhost zma_m20[3108]: INF [Cam_19: 145126 - Starting new event 1454808]
Mar 22 05:02:14 localhost zma_m24[3174]: INF [Cam_23: 145779 - Starting new event 1454809]
Mar 22 05:02:12 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:14 localhost zma_m13[3000]: INF [Cam_12: 159154 - Starting new event 1454810]
Mar 22 05:02:12 localhost zma_m16[3047]: INF [Cam_15: 156964 - Starting new event 1454811]
Mar 22 05:02:14 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:14 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:12 localhost zma_m11[2980]: INF [Cam_10: 159183 - Starting new event 1454812]
Mar 22 05:02:12 localhost zma_m12[2988]: INF [Cam_11: 159226 - Starting new event 1454813]
Mar 22 05:02:14 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:14 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:14 localhost zma_m22[3142]: INF [Cam_21: 145797 - Starting new event 1454814]
Mar 22 05:02:13 localhost zma_m2[2873]: INF [Cam_1: 163219 - Starting new event 1454815]
Mar 22 05:02:13 localhost zma_m20[3108]: INF [Cam_19: 145129 - Starting new event 1454816]
Mar 22 05:02:13 localhost zma_m13[3000]: INF [Cam_12: 159156 - Starting new event 1454818]
Mar 22 05:02:14 localhost zma_m24[3174]: INF [Cam_23: 145781 - Starting new event 1454817]
Mar 22 05:02:13 localhost zma_m16[3047]: INF [Cam_15: 156966 - Starting new event 1454819]
Mar 22 05:02:14 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:13 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:14 localhost zma_m19[3094]: INF [Cam_18: 145892 - Starting new event 1454820]
Mar 22 05:02:16 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m14[3023]: INF [Cam_13: 157068 - Starting new event 1454821]
Mar 22 05:02:14 localhost zma_m3[2888]: INF [Cam_2: 163607 - Starting new event 1454822]
Mar 22 05:02:16 localhost zma_m4[2902]: INF [Cam_3: 163489 - Starting new event 1454823]
Mar 22 05:02:16 localhost zma_m24[3174]: INF [Cam_23: 145783 - Starting new event 1454824]
Mar 22 05:02:14 localhost zma_m5[2912]: INF [Cam_4: 163526 - Starting new event 1454825]
Mar 22 05:02:16 localhost zma_m8[2944]: INF [Cam_7: 159526 - Starting new event 1454826]
Mar 22 05:02:16 localhost zma_m23[3157]: INF [Cam_22: 145768 - Starting new event 1454827]
Mar 22 05:02:14 localhost zma_m9[2958]: INF [Cam_8: 159474 - Starting new event 1454828]
Mar 22 05:02:16 localhost zma_m13[3000]: INF [Cam_12: 159158 - Starting new event 1454829]
Mar 22 05:02:14 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:14 localhost zmc_m24[3165]: INF [Cam_23: 148000 - Capturing at 2.09 fps]
Mar 22 05:02:14 localhost zma_m2[2873]: INF [Cam_1: 163221 - Starting new event 1454830]
Mar 22 05:02:16 localhost zma_m6[2924]: INF [Cam_5: 159399 - Starting new event 1454831]
Mar 22 05:02:16 localhost zma_m20[3108]: INF [Cam_19: 145134 - Starting new event 1454833]
Mar 22 05:02:16 localhost zma_m7[2932]: INF [Cam_6: 159321 - Starting new event 1454832]
Mar 22 05:02:14 localhost zma_m21[3124]: INF [Cam_20: 145678 - Starting new event 1454834]
Mar 22 05:02:16 localhost zma_m16[3047]: INF [Cam_15: 156969 - Starting new event 1454835]
Mar 22 05:02:16 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m5[2912]: INF [Cam_4: 163528 - Starting new event 1454836]
Mar 22 05:02:14 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m24[3174]: INF [Cam_23: 145785 - Starting new event 1454837]
Mar 22 05:02:16 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m4[2902]: INF [Cam_3: 163492 - Starting new event 1454838]
Mar 22 05:02:15 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m3[2888]: INF [Cam_2: 163610 - Starting new event 1454839]
Mar 22 05:02:16 localhost zma_m6[2924]: INF [Cam_5: 159402 - Starting new event 1454841]
Mar 22 05:02:15 localhost zma_m2[2873]: INF [Cam_1: 163223 - Starting new event 1454840]
Mar 22 05:02:16 localhost zma_m22[3142]: INF [Cam_21: 145803 - Starting new event 1454842]
Mar 22 05:02:16 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m7[2932]: INF [Cam_6: 159324 - Starting new event 1454843]
Mar 22 05:02:16 localhost zma_m23[3157]: INF [Cam_22: 145772 - Starting new event 1454844]
Mar 22 05:02:15 localhost zma_m24[3174]: INF [Cam_23: 145787 - Starting new event 1454845]
Mar 22 05:02:15 localhost zma_m8[2944]: INF [Cam_7: 159529 - Starting new event 1454846]
Mar 22 05:02:15 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m10[2972]: INF [Cam_9: 159183 - Starting new event 1454847]
Mar 22 05:02:17 localhost zma_m9[2958]: INF [Cam_8: 159477 - Starting new event 1454848]
Mar 22 05:02:15 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m11[2980]: INF [Cam_10: 159189 - Starting new event 1454849]
Mar 22 05:02:15 localhost zma_m12[2988]: INF [Cam_11: 159232 - Starting new event 1454850]
Mar 22 05:02:17 localhost zma_m14[3023]: INF [Cam_13: 157073 - Starting new event 1454851]
Mar 22 05:02:15 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m24[3174]: INF [Cam_23: 145789 - Starting new event 1454852]
Mar 22 05:02:15 localhost zma_m19[3094]: INF [Cam_18: 145898 - Starting new event 1454853]
Mar 22 05:02:17 localhost zma_m2[2873]: INF [Cam_1: 163226 - Starting new event 1454854]
Mar 22 05:02:15 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m18[3076]: INF [Cam_17: 144405 - Starting new event 1454855]
Mar 22 05:02:15 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:15 localhost zma_m3[2888]: INF [Cam_2: 163613 - Starting new event 1454856]
Mar 22 05:02:16 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m4[2902]: INF [Cam_3: 163495 - Starting new event 1454857]
Mar 22 05:02:17 localhost zma_m13[3000]: INF [Cam_12: 159163 - Starting new event 1454858]
Mar 22 05:02:16 localhost zma_m21[3124]: INF [Cam_20: 145684 - Starting new event 1454859]
Mar 22 05:02:16 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m5[2912]: INF [Cam_4: 163532 - Starting new event 1454860]
Mar 22 05:02:17 localhost zma_m10[2972]: INF [Cam_9: 159185 - Starting new event 1454861]
Mar 22 05:02:18 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m11[2980]: INF [Cam_10: 159191 - Starting new event 1454862]
Mar 22 05:02:16 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m7[2932]: INF [Cam_6: 159327 - Starting new event 1454863]
Mar 22 05:02:18 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:18 localhost zma_m24[3174]: INF [Cam_23: 145795 - Starting new event 1454864]
Mar 22 05:02:18 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:18 localhost zma_m8[2944]: INF [Cam_7: 159532 - Starting new event 1454865]
Mar 22 05:02:16 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:16 localhost zma_m19[3094]: INF [Cam_18: 145902 - Starting new event 1454866]
Mar 22 05:02:18 localhost zma_m16[3047]: INF [Cam_15: 156975 - Starting new event 1454867]
Mar 22 05:02:18 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:18 localhost zma_m2[2873]: INF [Cam_1: 163229 - Starting new event 1454868]
Mar 22 05:02:19 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m23[3157]: INF [Cam_22: 145777 - Starting new event 1454869]
Mar 22 05:02:19 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m24[3174]: INF [Cam_23: 145798 - Starting new event 1454870]
Mar 22 05:02:17 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m7[2932]: INF [Cam_6: 159329 - Starting new event 1454871]
Mar 22 05:02:19 localhost zma_m23[3157]: INF [Cam_22: 145779 - Starting new event 1454872]
Mar 22 05:02:17 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m14[3023]: INF [Cam_13: 157078 - Starting new event 1454873]
Mar 22 05:02:17 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:17 localhost zma_m9[2958]: INF [Cam_8: 159482 - Starting new event 1454874]
Mar 22 05:02:18 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:18 localhost zma_m18[3076]: INF [Cam_17: 144411 - Starting new event 1454875]
Mar 22 05:02:19 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m19[3094]: INF [Cam_18: 145906 - Starting new event 1454876]
Mar 22 05:02:18 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:18 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m5[2912]: INF [Cam_4: 163536 - Starting new event 1454877]
Mar 22 05:02:18 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m6[2924]: INF [Cam_5: 159409 - Starting new event 1454879]
Mar 22 05:02:18 localhost zma_m15[3035]: INF [Cam_14: 156681 - Starting new event 1454878]
Mar 22 05:02:18 localhost zma_m16[3047]: INF [Cam_15: 156978 - Starting new event 1454880]
Mar 22 05:02:18 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m4[2902]: INF [Cam_3: 163500 - Starting new event 1454881]
Mar 22 05:02:18 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:18 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:18 localhost zma_m5[2912]: INF [Cam_4: 163538 - Starting new event 1454882]
Mar 22 05:02:18 localhost zma_m19[3094]: INF [Cam_18: 145909 - Starting new event 1454883]
Mar 22 05:02:20 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m13[3000]: INF [Cam_12: 159169 - Starting new event 1454884]
Mar 22 05:02:18 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:19 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m20[3108]: INF [Cam_19: 145146 - Starting new event 1454885]
Mar 22 05:02:21 localhost zma_m10[2972]: INF [Cam_9: 159191 - Starting new event 1454886]
Mar 22 05:02:19 localhost zma_m22[3142]: INF [Cam_21: 145813 - Starting new event 1454887]
Mar 22 05:02:19 localhost zma_m11[2980]: INF [Cam_10: 159197 - Starting new event 1454888]
Mar 22 05:02:19 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m2[2873]: INF [Cam_1: 163235 - Starting new event 1454889]
Mar 22 05:02:20 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m4[2902]: INF [Cam_3: 163503 - Starting new event 1454890]
Mar 22 05:02:20 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m23[3157]: INF [Cam_22: 145786 - Starting new event 1454891]
Mar 22 05:02:20 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m12[2988]: INF [Cam_11: 159242 - Starting new event 1454892]
Mar 22 05:02:20 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m5[2912]: INF [Cam_4: 163541 - Starting new event 1454893]
Mar 22 05:02:22 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m2[2873]: INF [Cam_1: 163237 - Starting new event 1454894]
Mar 22 05:02:20 localhost zma_m15[3035]: INF [Cam_14: 156685 - Starting new event 1454895]
Mar 22 05:02:22 localhost zma_m3[2888]: INF [Cam_2: 163623 - Starting new event 1454898]
Mar 22 05:02:22 localhost zma_m18[3076]: INF [Cam_17: 144416 - Starting new event 1454899]
Mar 22 05:02:22 localhost zma_m19[3094]: INF [Cam_18: 145913 - Starting new event 1454897]
Mar 22 05:02:22 localhost zma_m22[3142]: INF [Cam_21: 145817 - Starting new event 1454900]
Mar 22 05:02:20 localhost zma_m16[3047]: INF [Cam_15: 156982 - Starting new event 1454896]
Mar 22 05:02:20 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:20 localhost zma_m14[3023]: INF [Cam_13: 157084 - Starting new event 1454901]
Mar 22 05:02:20 localhost zma_m23[3157]: INF [Cam_22: 145788 - Starting new event 1454902]
Mar 22 05:02:22 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m22[3142]: INF [Cam_21: 145820 - Starting new event 1454903]
Mar 22 05:02:21 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m21[3124]: INF [Cam_20: 145696 - Starting new event 1454904]
Mar 22 05:02:21 localhost zma_m8[2944]: INF [Cam_7: 159541 - Starting new event 1454905]
Mar 22 05:02:21 localhost zma_m5[2912]: INF [Cam_4: 163544 - Starting new event 1454906]
Mar 22 05:02:21 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m13[3000]: INF [Cam_12: 159174 - Starting new event 1454907]
Mar 22 05:02:21 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m24[3174]: INF [Cam_23: 145808 - Starting new event 1454908]
Mar 22 05:02:23 localhost zma_m18[3076]: INF [Cam_17: 144420 - Starting new event 1454909]
Mar 22 05:02:21 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:21 localhost zma_m11[2980]: INF [Cam_10: 159203 - Starting new event 1454910]
Mar 22 05:02:21 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m16[3047]: INF [Cam_15: 156985 - Starting new event 1454911]
Mar 22 05:02:22 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m19[3094]: INF [Cam_18: 145918 - Starting new event 1454912]
Mar 22 05:02:22 localhost zma_m14[3023]: INF [Cam_13: 157087 - Starting new event 1454913]
Mar 22 05:02:23 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m23[3157]: INF [Cam_22: 145793 - Starting new event 1454914]
Mar 22 05:02:22 localhost zma_m18[3076]: INF [Cam_17: 144422 - Starting new event 1454915]
Mar 22 05:02:22 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:24 localhost zma_m15[3035]: INF [Cam_14: 156689 - Starting new event 1454916]
Mar 22 05:02:22 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:24 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:24 localhost zma_m21[3124]: INF [Cam_20: 145699 - Starting new event 1454917]
Mar 22 05:02:24 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m20[3108]: INF [Cam_19: 145154 - Starting new event 1454918]
Mar 22 05:02:22 localhost zma_m4[2902]: INF [Cam_3: 163508 - Starting new event 1454919]
Mar 22 05:02:24 localhost zma_m19[3094]: INF [Cam_18: 145920 - Starting new event 1454920]
Mar 22 05:02:24 localhost zma_m22[3142]: INF [Cam_21: 145824 - Starting new event 1454921]
Mar 22 05:02:22 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:22 localhost zma_m7[2932]: INF [Cam_6: 159340 - Starting new event 1454922]
Mar 22 05:02:22 localhost zma_m13[3000]: INF [Cam_12: 159176 - Starting new event 1454923]
Mar 22 05:02:22 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:24 localhost zma_m10[2972]: INF [Cam_9: 159198 - Starting new event 1454924]
Mar 22 05:02:23 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m3[2888]: INF [Cam_2: 163628 - Starting new event 1454925]
Mar 22 05:02:23 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m19[3094]: INF [Cam_18: 145923 - Starting new event 1454927]
Mar 22 05:02:23 localhost zma_m14[3023]: INF [Cam_13: 157089 - Starting new event 1454928]
Mar 22 05:02:23 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m9[2958]: INF [Cam_8: 159493 - Starting new event 1454926]
Mar 22 05:02:25 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m6[2924]: INF [Cam_5: 159419 - Starting new event 1454929]
Mar 22 05:02:23 localhost zma_m7[2932]: INF [Cam_6: 159342 - Starting new event 1454930]
Mar 22 05:02:25 localhost zma_m15[3035]: INF [Cam_14: 156691 - Starting new event 1454931]
Mar 22 05:02:23 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m16[3047]: INF [Cam_15: 156988 - Starting new event 1454932]
Mar 22 05:02:25 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m8[2944]: INF [Cam_7: 159546 - Starting new event 1454933]
Mar 22 05:02:23 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m24[3174]: INF [Cam_23: 145812 - Starting new event 1454934]
Mar 22 05:02:25 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m21[3124]: INF [Cam_20: 145703 - Starting new event 1454935]
Mar 22 05:02:25 localhost zma_m3[2888]: INF [Cam_2: 163630 - Starting new event 1454936]
Mar 22 05:02:25 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m4[2902]: INF [Cam_3: 163511 - Starting new event 1454937]
Mar 22 05:02:25 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:23 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m5[2912]: INF [Cam_4: 163551 - Starting new event 1454938]
Mar 22 05:02:24 localhost zma_m19[3094]: INF [Cam_18: 145926 - Starting new event 1454939]
Mar 22 05:02:25 localhost zma_m14[3023]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:25 localhost zmc_m23[3148]: INF [Cam_22: 148000 - Capturing at 2.09 fps]
Mar 22 05:02:25 localhost zma_m2[2873]: INF [Cam_1: 163244 - Starting new event 1454940]
Mar 22 05:02:24 localhost zma_m14[3023]: INF [Cam_13: 157091 - Starting new event 1454941]
Mar 22 05:02:24 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m15[3035]: INF [Cam_14: 156693 - Starting new event 1454942]
Mar 22 05:02:24 localhost zma_m19[3094]: INF [Cam_18: 145928 - Starting new event 1454943]
Mar 22 05:02:24 localhost zma_m16[3047]: INF [Ended event]
Mar 22 05:02:24 localhost zma_m16[3047]: INF [Cam_15: 156991 - Starting new event 1454944]
Mar 22 05:02:26 localhost zma_m23[3157]: INF [Ended event]
Mar 22 05:02:24 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m23[3157]: INF [Cam_22: 145799 - Starting new event 1454945]
Mar 22 05:02:24 localhost zma_m10[2972]: INF [Cam_9: 159202 - Starting new event 1454946]
Mar 22 05:02:26 localhost zma_m11[2980]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m11[2980]: INF [Cam_10: 159210 - Starting new event 1454947]
Mar 22 05:02:26 localhost zma_m5[2912]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m5[2912]: INF [Cam_4: 163553 - Starting new event 1454948]
Mar 22 05:02:26 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:24 localhost zma_m2[2873]: INF [Cam_1: 163246 - Starting new event 1454949]
Mar 22 05:02:26 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m24[3174]: INF [Cam_23: 145817 - Starting new event 1454950]
Mar 22 05:02:27 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:27 localhost zma_m21[3124]: INF [Cam_20: 145707 - Starting new event 1454951]
Mar 22 05:02:25 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m19[3094]: INF [Cam_18: 145932 - Starting new event 1454952]
Mar 22 05:02:25 localhost zma_m7[2932]: INF [Cam_6: 159347 - Starting new event 1454953]
Mar 22 05:02:25 localhost zma_m5[2912]: INF [Cam_4: 163555 - Starting new event 1454954]
Mar 22 05:02:27 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m8[2944]: INF [Cam_7: 159551 - Starting new event 1454955]
Mar 22 05:02:27 localhost zma_m2[2873]: INF [Ended event]
Mar 22 05:02:25 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:27 localhost zma_m2[2873]: INF [Cam_1: 163248 - Starting new event 1454956]
Mar 22 05:02:25 localhost zma_m20[3108]: INF [Cam_19: 145162 - Starting new event 1454957]
Mar 22 05:02:25 localhost zma_m9[2958]: INF [Ended event]
Mar 22 05:02:27 localhost zma_m9[2958]: INF [Cam_8: 159499 - Starting new event 1454958]
Mar 22 05:02:25 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:27 localhost zma_m3[2888]: INF [Cam_2: 163635 - Starting new event 1454959]
Mar 22 05:02:26 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:27 localhost zma_m15[3035]: INF [Cam_14: 156697 - Starting new event 1454961]
Mar 22 05:02:26 localhost zma_m14[3023]: INF [Cam_13: 157095 - Starting new event 1454960]
Mar 22 05:02:26 localhost zma_m4[2902]: INF [Cam_3: 163515 - Starting new event 1454963]
Mar 22 05:02:27 localhost zma_m6[2924]: INF [Cam_5: 159425 - Starting new event 1454962]
Mar 22 05:02:26 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:27 localhost zma_m22[3142]: INF [Cam_21: 145832 - Starting new event 1454964]
Mar 22 05:02:26 localhost zma_m11[2980]: INF [Cam_10: 159213 - Starting new event 1454965]
Mar 22 05:02:28 localhost zma_m18[3076]: INF [Cam_17: 144431 - Starting new event 1454966]
Mar 22 05:02:26 localhost zma_m12[2988]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m12[2988]: INF [Cam_11: 159255 - Starting new event 1454967]
Mar 22 05:02:26 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m13[3000]: INF [Cam_12: 159183 - Starting new event 1454968]
Mar 22 05:02:28 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m10[2972]: INF [Cam_9: 159206 - Starting new event 1454969]
Mar 22 05:02:26 localhost zma_m7[2932]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m7[2932]: INF [Cam_6: 159349 - Starting new event 1454970]
Mar 22 05:02:26 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m21[3124]: INF [Cam_20: 145711 - Starting new event 1454971]
Mar 22 05:02:26 localhost zma_m2[2873]: INF [Cam_1: 163250 - Starting new event 1454972]
Mar 22 05:02:28 localhost zma_m8[2944]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m8[2944]: INF [Cam_7: 159553 - Starting new event 1454973]
Mar 22 05:02:26 localhost zma_m3[2888]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m3[2888]: INF [Cam_2: 163637 - Starting new event 1454974]
Mar 22 05:02:28 localhost zma_m4[2902]: INF [Ended event]
Mar 22 05:02:26 localhost zma_m4[2902]: INF [Cam_3: 163517 - Starting new event 1454975]
Mar 22 05:02:27 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:27 localhost zma_m24[3174]: INF [Cam_23: 145823 - Starting new event 1454976]
Mar 22 05:02:29 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:29 localhost zma_m22[3142]: INF [Cam_21: 145836 - Starting new event 1454977]
Mar 22 05:02:27 localhost zma_m8[2944]: INF [Cam_7: 159555 - Starting new event 1454978]
Mar 22 05:02:27 localhost zma_m22[3142]: INF [Cam_21: 145838 - Starting new event 1454979]
Mar 22 05:02:29 localhost zma_m24[3174]: INF [Cam_23: 145825 - Starting new event 1454980]
Mar 22 05:02:29 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:29 localhost zma_m24[3174]: INF [Cam_23: 145827 - Starting new event 1454981]
Mar 22 05:02:29 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:29 localhost zma_m13[3000]: INF [Cam_12: 159186 - Starting new event 1454982]
Mar 22 05:02:28 localhost zma_m19[3094]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m19[3094]: INF [Cam_18: 145939 - Starting new event 1454983]
Mar 22 05:02:28 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m22[3142]: INF [Cam_21: 145841 - Starting new event 1454984]
Mar 22 05:02:28 localhost zma_m20[3108]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m20[3108]: INF [Cam_19: 145168 - Starting new event 1454985]
Mar 22 05:02:30 localhost zma_m22[3142]: INF [Ended event]
Mar 22 05:02:30 localhost zma_m16[3047]: INF [Cam_15: 157000 - Processing at 2.08 fps]
Mar 22 05:02:30 localhost zma_m24[3174]: INF [Ended event]
Mar 22 05:02:28 localhost zma_m18[3076]: INF [Ended event]
Mar 22 05:02:30 localhost zma_m6[2924]: INF [Ended event]
Mar 22 05:02:30 localhost zma_m22[3142]: INF [Cam_21: 145843 - Starting new event 1454986]
Mar 22 05:02:30 localhost zma_m24[3174]: INF [Cam_23: 145830 - Starting new event 1454987]
Mar 22 05:02:30 localhost zma_m18[3076]: INF [Cam_17: 144437 - Starting new event 1454988]
Mar 22 05:02:28 localhost zma_m6[2924]: INF [Cam_5: 159431 - Starting new event 1454989]
Mar 22 05:02:28 localhost zma_m15[3035]: INF [Ended event]
Mar 22 05:02:29 localhost zma_m15[3035]: INF [Cam_14: 156703 - Starting new event 1454990]
Mar 22 05:02:29 localhost zma_m21[3124]: INF [Ended event]
Mar 22 05:02:29 localhost zma_m21[3124]: INF [Cam_20: 145716 - Starting new event 1454991]
Mar 22 05:02:30 localhost zma_m13[3000]: INF [Ended event]
Mar 22 05:02:30 localhost zma_m13[3000]: INF [Cam_12: 159189 - Starting new event 1454992]
Mar 22 05:02:31 localhost zma_m10[2972]: INF [Ended event]
Mar 22 05:02:31 localhost zma_m8[2944]: I
James Wilson
jameswilson
Post by jameswilson »
I have also checked the zmdc and zmwatch log and all thats in there is deamon restsrts after the directory breaks 32000 items and it cant write to disk, once the folder count drops this stops.
I have tried restarting zm when this occurs and it doesnt help i need to resrt the whole machine.
Im looking for any ideas at all here please!!!!
James Wilson
jameswilson
BTW i have only checked the syslog as i assume if its a linux issue it will be in here?
James Wilson
jameswilson
Mar 22 04:16:03 localhost zmc_dvideo2[2965]: INF [Cam_11: 156000 - Capturing at 2.07 fps]
Mar 22 04:16:08 localhost zma_m15[3035]: INF [Cam_14: 151000 - Processing at 2.11 fps]
Mar 22 04:16:14 localhost zmc_dvideo2[2965]: INF [Cam_10: 156000 - Capturing at 2.07 fps]
Mar 22 04:16:15 localhost zmc_dvideo3[3014]: INF [Cam_13: 154000 - Capturing at 2.11 fps]
Mar 22 04:16:16 localhost zmc_dvideo2[2965]: INF [Cam_9: 156000 - Capturing at 2.09 fps]
Mar 22 04:16:48 localhost zmc_dvideo2[2965]: INF [Cam_12: 156000 - Capturing at 2.07 fps]
Mar 22 04:16:50 localhost zmc_dvideo3[3014]: INF [Cam_15: 154000 - Capturing at 2.12 fps]
Mar 22 04:17:12 localhost zmc_dvideo3[3014]: INF [Cam_16: 154000 - Capturing at 2.13 fps]
Mar 22 04:17:27 localhost zma_m3[2888]: INF [Cam_2: 158000 - Processing at 2.12 fps]
Mar 22 04:17:41 localhost zma_m5[2912]: INF [Cam_4: 158000 - Processing at 2.11 fps]
Mar 22 04:18:01 localhost zma_m8[2944]: INF [Cam_7: 154000 - Processing at 2.15 fps]
Mar 22 04:18:19 localhost zmc_dvideo1[2917]: WAR [Buffer overrun at index 1, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:19 localhost zmc_dvideo3[3014]: WAR [Buffer overrun at index 46, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:21 localhost zmc_dvideo0[2868]: WAR [Buffer overrun at index 22, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:22 localhost zmc_dvideo0[2868]: WAR [Buffer overrun at index 43, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:22 localhost zmc_dvideo3[3014]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:23 localhost zmc_dvideo3[3014]: WAR [Buffer overrun at index 22, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:24 localhost zmc_m18[8139]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:24 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 38, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:25 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 29, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:25 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 1, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:25 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 31, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:30 localhost zma_m4[2902]: INF [Cam_3: 158000 - Processing at 2.13 fps]
Mar 22 04:18:31 localhost zmc_dvideo3[3014]: INF [Cam_14: 154000 - Capturing at 2.10 fps]
Mar 22 04:18:39 localhost zmc_m22[3133]: WAR [Buffer overrun at index 57, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:42 localhost zmc_m19[3087]: WAR [Buffer overrun at index 51, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:42 localhost zmc_m24[3165]: WAR [Buffer overrun at index 28, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:46 localhost zmc_dvideo3[3014]: WAR [Buffer overrun at index 46, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:47 localhost zmc_m20[8140]: WAR [Buffer overrun at index 25, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:47 localhost zmc_m23[3148]: WAR [Buffer overrun at index 7, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:48 localhost zmc_dvideo1[2917]: WAR [Buffer overrun at index 1, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:49 localhost zmc_dvideo3[3014]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:49 localhost zmc_dvideo0[2868]: WAR [Buffer overrun at index 22, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:50 localhost zmc_dvideo0[2868]: WAR [Buffer overrun at index 43, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:50 localhost zmc_dvideo3[3014]: WAR [Buffer overrun at index 22, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:52 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 38, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:52 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 1, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:53 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 31, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:53 localhost zmc_dvideo2[2965]: WAR [Buffer overrun at index 29, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:18:55 localhost zmc_m18[8139]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:19:00 localhost zmc_dvideo1[2917]: WAR [Buffer overrun at index 50, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:19:01 localhost zmc_dvideo1[2917]: WAR [Buffer overrun at index 56, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:19:01 localhost zmc_dvideo0[2868]: WAR [Buffer overrun at index 33, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:19:04 localhost zmc_dvideo1[2917]: WAR [Buffer overrun at index 34, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:19:06 localhost zmc_dvideo0[2868]: WAR [Buffer overrun at index 66, slow down capture, speed up analysis or increase ring buffer size]
Mar 22 04:19:08 localhost zma_m9[2958]: INF [Cam_8: 154000 - Processing at 1.99 fps]
Mar 22 04:19:27 localhost zma_m6[2924]: INF [Cam_5: 154000 - Processing at 2.01 fps]
Mar 22 04:19:34 localhost zma_m20[3108]: INF [Cam_19: 140000 - Processing at 1.86 fps]
Mar 22 04:19:56 localhost zmc_m19[3087]: INF [Cam_18: 143000 - Capturing at 2.01 fps]
Mar 22 04:19:59 localhost zma_m4[2902]: INF [Ended event]
Mar 22 04:20:00 localhost zma_m3[2888]: INF [Ended event]
Mar 22 04:20:00 localhost zma_m6[2924]: INF [Ended event]
Mar 22 04:20:00 localhost zma_m12[2988]: INF [Ended event]
Mar 22 04:20:00 localhost zma_m5[2912]: INF [Ended event]
Just trawled some more and i can find these underruns before the event,but it like 40 mins before the wierdness starts
James Wilson
victor_diago
Post by victor_diago »
Hi James Wilson.
Have you fixed it ?
i had a lot of problems like this too, mainly the "caannot find directory" one.
I think it could be a bug in ZM, since old version seems to be bugless.
Victor Diago
jameswilson
no victor as yet i havnt, i am restarting every day at the moment. Do you know if i can downgrade easily to see if that helps. I only have webmin acces to this server and its a long way away
James Wilson
wmoore
Post by wmoore »
For what its worth...
The buffer issue : WAR [Buffer overrun at index 25, slow down capture, speed up analysis or increase ring buffer size] also accompanies my "garbeled images" issue.
See :http://www.zoneminder.com/forums/viewtopic.php?t=5776
-WAM
jameswilson
it seems im only getting garbled on the ip cams not the local cams but i may be wrong. The event ending issue seems to be worse on the ip cams as they start to end events before the composites do. I am out of ideas apart from a zm downgrade to see if that changes anything. Im assuming it isnt zm but i cant see its hardware as its fine for 48hrs after a restart
Note my garbleds are mainly purple in colur but soemtimes appear 'out of sync' and the preious image and next image are perfect. I also note the alarm score is usually 99 but i suppose thats to be expected.
Also when the ip cams start to end events at strange time there is no 'dead' time ie from the time the last mage and the first image is as expected no gaps
James Wilson
wmoore
Post by wmoore »
My hardware did not change. I did do a fresh install as opposed to to an upgrade, but the previous version(s) have been rock solid. I also get the 'Signal' events on my system, and I only have IP cams, so I think there is something going on in zm in the network camera area on 1.22.0...
Interesting, the 'Signal' events are all dated 12/31 19:00:00 and event lengths are either 0:00 or somthing crazy like -16149970.15
-WAM
wmoore
Post by wmoore »
Just a guess, but I would think you would have issues with the DB. If you were willing to chuck the DB and re-install..but thats not really a down grade.
Maybe if you did a compare of the DB structures you could mock up a downgrade script, but that would likely be alot of work.
-WAM
zoneminder
Site Admin
Post by zoneminder »
Can you check to see if the event names have an (r) appended?
Phil
