Logout after Login (can't enter the zm site)
DiegoLima
Post by DiegoLima »
Hogface wrote:Check to see if you have free drive space on your data volume...with a df command.
Yes, I do. I have over 6gb of free space
zoneminder
Site Admin
Post by zoneminder »
There is an issue with newer versions of mysql using a different password encryption method. I don't know if this thread might help at all?
Phil
DiegoLima
Post by DiegoLima »
The thread didn't help me out much :? I'm going to get a new box and do a clean Fedora Core 5 install on it along with a clean Ubuntu install and check out ZM on both. Then I'll tell the results...
Thanks for your patience :)
