Fresh install of 1.22.2 gives perminent login screen
zoneminder
Site Admin
Post by zoneminder »
If you go to the ZM web dir and type
patch -p0 <patch file>
it should work.
If you want to it manually then lines without a + or - at the front are just so you find where to do the changes (called context). Add lines with a + and delete any with a -, though there are none to delete in the above patch. Lines with *** or --- etc are just indicating which file to patch etc.
Phil
