can't get streaming images
i am tailing it all the time but no error
just the usual output:
[Fri Jun 9 09:45:21 2006] [notice] caught SIGTERM, shutting down
[Fri Jun 9 09:47:27 2006] [notice] Apache/1.3.33 (Unix) Streaming/0.4 PHP/5.0.5 configured -- resuming normal operations
[Fri Jun 9 09:47:27 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
Respect,
Dr.Septimiu Suciu
Dr.Septimiu Suciu
just a wild stab in the dark, you can configure ff to report itself as a different browser, you havnt turned this on have you??
James Wilson
There is some thing off in your config (In zm, apache, or permisions) for zms.
I can pull stills and see your blue shirt
Make sure that in your apache config, that cgi can be executed under the path you have installed. I forgot to check and see if you used the default path so I'm just mentioning it.
Your problem is with zms though as stills are sent just fine.
Corey
Corey
stills are ok
zms is under /var/www/cgi-bin (the default apache cgi-bin dir)
user & group are set at compile time to nobody.nogroup (same as default apache user)
root@cabinet:~# ls -la /var/www/cgi-bin/|grep zms
-rwxr-xr-x 2 nobody nogroup 1180215 2006-06-07 12:11 nph-zms*
-rwxr-xr-x 2 nobody nogroup 1180215 2006-06-07 12:11 zms*
are executables
are executables
Respect,
Dr.Septimiu Suciu
Dr.Septimiu Suciu
well done Corey i knew you would know!
James Wilson
