edimax IC-1500Wg
Error: Frame signature incorrect
I got an error when I first run this script: I could resolved by installing "pear" on my linux ubuntu workstation via synaptic. Then I set "safe_mode = Off" and "upload_tmp_dir=./home/{user}/" in php.ini
Voila - no errors. BUT
When I run this script now, I got the following result
(i reactivated echo-comments):
login request sent! login reply received! OK! get frame request sent! Frame signature incorrect!
What does that mean - is there a solution for that?
Will I ever get a Still-Picture out of my webcam?
@roby - the link to darkwet is very interesting, thank you!
they show a long description of commands and cgi-urls for the hawk webcam. unfortunately they don't work on a logilink wc0002... does anybody know, where such an information for wc0002 can be found?
Linux Ubuntu Feisty 7.04
Local Apache Webserver, php5
Logilink wc0002 IP WLAN Camera
Hello!
echo("login request sent!");, echo("OK");, etc lines are commented out in my code, with // . Didn't you erased the comments?
"Frame signature incorrect" is harder problem. Try comment out the following lines:[/url][/list]
$sig = unpack("H*", $ret);
if ($sig[1] != "000700060000") {
error("Frame signature incorrect");
hi again,
@sala2001: no i didn't erase the comments, i just deleted the "//" before the commands. i tried what you said. the result of the former frame signature incorrect error is now:
login request sent! login reply received! OK! get frame request sent! frame signature ok! frame_size = 38513!
Warning: Cannot modify header information - headers already sent by (output started at /var/www/webcam.php:57) in /var/www/webcam.php on line 105
After i erased all "echo"-command before line 105 IT WORKED!!!
The current image is shown in the browser. i replaced
> echo($ret)
with
> dump($ret, "/home/{user}/webcam.jpg")
at the end of the php script.
it works-> when i call http://localhost/webcam.php the webcam.jpg is created. cool!
Now i created a bash command script file ("wcupl.sh"):
And a crontab file (wcupl.cron) containing:
In the Terminal i run
crontab -u {user} wcupl.cron
Now the "last question": Which command opens http://localhost/webcam.php from bash command line (it should replace >???< above)?
Thanks for help.
> echo($ret)
with
#!/bin/sh
cd /home/{user}
ftp -n myhost.com <<EOT
user ftpuser ftppass
quit
EOT
*/30 * * * * wcupl.sh
Thanks for help.
wget http://localhost/webcam.php
periodic ftp-upload of single webcam jpeg *resolved*
thank you. i have now a working system on my linux system, uploading a single image from the webcam every 30 minutes.
i am currently programming an additional php file for timestamping the webcam.jpg. I post it when finished.
besides, there is no way to get out an uncompressed frame from the webcam, isn't it? in my opinion i don't think that this is possible because of the mjpeg stream, but maybe the manufacturer will provide a better firmware and image quality settings in future, who knows...
but the real question is: does anyone know, why cheaper network webcams don't come out with this essential function "periodic ftp upload of single jpeg file"?
timestamping webcam image
okay, here the final result:
I created a directory /webcam with rights for "root" and "www" to read and write.
ins salas script i added/replaced the following lines:
The Crontab File (wcupl.cron) contains:
The wcupl.sh file contains:
It is a little hack, because of a some-seconds-delay between creating the jpeg and ftp-uploading, which causes the script not running correctly. so i just reversed it: First upload the "latest" webcam image, then enough time to create an new one for the next upload. not very clean, i know, but for me it works!
header("Content-Type: image/jpeg");
//header("Content-Length: $frame_size"); <-comment out, causes error
//header("Content-Disposition: inline; filename=current.jpg"); <- comment out, is not needed
dump($ret,'current.jpg');
fclose($sock);
//Timestamping current Webcam Image
$img = ImageCreateFromJPEG('current.jpg');
$timestamp = time();
$text = date("d.m.Y H:i",$timestamp);
$ttf = $_SERVER['DOCUMENT_ROOT'].'FreeSans.ttf';
$ttfsize = 11;
$angle = 0;
$text_x = 5;
$text_y = 15;
$color1 = ImageColorAllocate($img,0,0,0);
$color2 = ImageColorAllocate($img,255,255,255);
imagettftext($img,$ttfsize,$angle,$text_x,$text_y,$color1,$ttf,$text);
imagettftext($img,$ttfsize,$angle,$text_x-1,$text_y-1,$color2,$ttf,$text);
imagejpeg($img);
imagedestroy($img);
*/15 * * * * /webcam/wcupl.sh
#!/bin/sh
cd /webcam
user login pass
quit
EOT
Excellent work
Sala,
Fantastic bit of work. I picked this cam up for £54 - thanks for investing your time...
stu
stu
URLs
I emailed the tech support at Edimax. The camera does provide direct JPG url.
http://ip.address/snapshot.jpg
http://ip.address/snapshot.cgi
I have configured the jpg link in ZM. Just include the login credentials as described in the zoneminder tutorial. I am managing to get 8 or 9 fps on a P900. Quite impressive for a £50 cam.
stu
stu
Password:
Hello, what about login/password? In my case login:password@server/snapshot.jpg does not work in MS IE. If I try, i get "Access Denied". I hope that its MSIE problem, not camera (LCS 717 with 1.29 fw).
Did they sent any info about snapshot.cgi, parameters or something ?
Sorry for my english.
Dave
Dave
IC-1500 camera config
Finally got this working so here is my camera config.
ICS-1500 IP 192.168.1.2, port 80, username admin, password 1234
Changes only shown to each tab setting :-
General
Name IC1500
Source type remote
Max FPS 1.00
alarm max FPS 1.00
Source
Remote host name admin:1234@192.168.1.2
Remote host port 80
Remote host path /snapshot.jpg
Capture width 640 (same as set in admin on the IC-1500)
Capture height 480
Buffers
Image buffer size 10
warmup 1
Pre event image 10
Post event image 10
If you want to test the camera prior to this set up use
wget --user admin --password 1234 192.168.1.2/snapshot.jpg
Output should be
--14:35:15-- http://192.168.1.2/snapshot.jpg
=> `snapshot.jpg'
Connecting to 192.168.1.2:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 29,439 (29K) [image/jpeg]
100%[====================================>] 29,439 --.--K/s
14:35:15 (374.41 KB/s) - `snapshot.jpg' saved [29439/29439]
General
Name IC1500
Source type remote
Max FPS 1.00
alarm max FPS 1.00
Source
Remote host port 80
Capture height 480
Buffers
warmup 1
Pre event image 10
Post event image 10
Output should be
=> `snapshot.jpg'
Ic-1500 Linux Source Code
Here is the URL from the EDIMax website:
http://www.edimax.com/images/Image/Open ... 65X.tar.gz
Enjoy!
Enjoy!
Config with HTML strings
Well, after a bit of hacking around with page source on the camera, I put together a string that let me change the settings using the Safari browser or FireFox:
http://admin:1234@192.168.2.3/form/came ... a_left.asp
Options are as follows:
Resolution:
0 = 640x480
Quality:
3 = Highest
Frame Rate:
30 = 30 frames per second (FPS)
25 = 25 FPS
20 = 20 FPS
15
10
5
3
1
Frequency:
60 = 60hz
50 = 50 hz
0 = "Outdoor" mode
Auto Exposure:
ON /OFF
Others are Black, White, Brightness - defaults *should* work ok, but you can tweak for your environment. For me, the defaults worked ok.
I hope this is helpful.
Anyhow, this thing is Linux based, we ought to be able to make a new firmware and Open Source it, RIGHT? The reason I am asking you all about this is because I have problems with my camera freezing after about 14 hours every day. The ethernet works, but the camera stops producing JPG images. VERY STRANGE. Anyone else having this problem? Have you found a fix to it besides power cycling? Firmware is already the latest version. Thanks in advance.
-TechMundial
Resolution:
0 = 640x480
Quality:
3 = Highest
Frame Rate:
25 = 25 FPS
20 = 20 FPS
15
10
5
3
1
Frequency:
60 = 60hz
50 = 50 hz
0 = "Outdoor" mode
Auto Exposure:
ON /OFF
-TechMundial
Thats is awesome, Thanks for taking a poke, I'm sure several people will be happy with this.
You might take a peek at a suggestion by another forum user that I'm considering:
http://www.zoneminder.com/forums/viewtopic.php?t=11122
new wiki about IC-1500 EdiMax IP camera
I just opened up a wiki about the EdiMax IC-1500 IP camera if anyone is interested. We plan on getting other users to help develop a firmware or custom OS to go on it. We hope this will stop the camera from freezing and give us some extra features:
http://ic1500.wikispaces.com
8)
8)
