lol i found that too.
The only way to do it would be to capture the input with ffmpeg and then deinterlace it then give it to zm, how i dont know
Also the new hd std has 1080i so its still interlaced as it uses half the bandwidth of 1080p
Deinterlacing with ffmpeg?
James Wilson
720p would be the ideal resolution really as its progressive without too much bandwidth. There are lots of programs that would capture the input and de-interlace it but I dont think you could get proper status reports from it which is probably why a custom capture program was written.
With regards to the original question in this forum. While researching I found out if you want to de-interlace clips when exporting, ffmpeg wont do it (as you found out)
but mencoder will using the following command
Where
filename.jpg = the jpg file you want to convert (can use *.jpg to convert an entire event)
w= width in pixels
h= height in pixels
fps = the fps rate of your camera
-vf lavcdeint is the deinterlacing filter (read the man as there are quite a few deinterlacing filters)
dunno if that helps but after a quick test I got a working video file of an event that was fully deinterlaced.
mencoder mf://filename.jpg -mf w=720:h=576:fps=10:type=jpg -vf lavcdeint -ovc lavc -lavcopts vcodec=mpeg4 -ofps 25 -oac copy -o output.avi
w= width in pixels
h= height in pixels
