need help with fedora install
darkpaw
Fedora
Post by darkpaw »
I chose Fedora because of being able to install ZM from RPMs. :) No compiling needed...badda-boom, badda-bing.
Pierre Albarede
zoneminder is already In Fedora 7
Post by Pierre Albarede »
All this mess for nothing?
Application Menu
Get software
Search and install zoneminder 1.22.3-7.fc7.i386
GMartin
Post by GMartin »
"AmmarossDana wrote:
The zm_mpeg.h is from the zoneminder package, and this compiling error only happens in FC6 so far as I've heard.["
Your fix is also required for Slackware 12.0 and possibly earlier versions of Slackware as well. Thanks!
Ruler
Post by Ruler »
This problem is also in evidence on Slackware 12.0 Adding the 3 lines above fixed the problem without difficulty though. (The only difficulty was the stress I put myself under between the time the compile failed and I came here to check for a solution. ;) :lol: )
This message is made up of not less than 90% recycled electrons.
khar
Post by khar »
GMartin wrote: ...
No need to patch with Slackware 11.0
