Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
wa4bro
Post by wa4bro »
jameswilson wrote:Dan id love to have images there instead of basic text but i have been and still unable to find anythign suitable. I can find images that would be perfect but when scaled down from low quality web grabs they look poor. I need seperate image files for pause, play etc and the pause still forward and reverse. I tried creating some before but they looked (shi...) not very good either. Ideaaly all i want is the arrows etc if the backgrounds arnt transparent i can fix that.
James
No problem James, The buttons are fine as long as we can get some direction on them. I tell ya, I hardly go back to the standard ZM interface except to delete events or make camera adjustments now! The viewer is much easier and actually flows smoother! Great App!
A couple more obs.
It would be nice if the player control buttons were moved up just a little bit from the bottom of the screen. When you enlarge it they are so close to the task bar that if you have a pop up task bar (like me) you tend to let the pointer stray just enough to make the task bar pop up when trying to jump between buttons.
Event progress bar. It would be nice to have an even progress bar just below the image that progresses as the event is played. Long events sometime look stalled unless you are really watching the clock and it would be nice to see how much time is left in the event playing. Bar/ Clock/countdown or something would solve this.
Dan
jameswilson
Post by jameswilson »
ok will do
I agree good idea
If anyone has or can get some suitable images this would be a great help. And thankyou very much Dan, (i love praise lol) its getting there, its got the bulk of the key features i think, but certain areas still need improving (images for buttons lol)
James Wilson
jameswilson
lol this is getting silly
alpha update
added progress through video thingy to bottom of screen, works in normal payback and revers and motion only
added new name to top of playback screens hows current event being played back and still image number if applicable
moved buttons up to prevent autohide problem.
Will replace beta with next alpha once you can see button names again. Are they still funny or what dan
James
James Wilson
jameswilson
I have just installed the alpha on an xp machione and i see the button problem lol. i will fix it
regarding the speech the l and h engines are poo, for devepoipng io used the ms voices, ms sam i think is in xp by default. There are some much better voices that can be added but you have to pay for the good ones, sam does a pretty good job though
James Wilson
jameswilson
update
zm4ms beta now has fixed alpha code and will be main beta from now on (i will delete alpha in a couple of days)
fixed button colour issue and beta has everything alpha had.
James
James Wilson
wa4bro
Post by wa4bro »
jameswilson wrote:update
James
Button Labels Good <G>
LOVE the progress bar..... Works like a champ!
Good work James
Dan
jameswilson
cheers matey
James Wilson
jameswilson
Dan i just tried installing the new alpha beta thingy and had an error about stdole, i assume you didnt have this?
James Wilson
wa4bro
Post by wa4bro »
jameswilson wrote:Dan i just tried installing the new alpha beta thingy and had an error about stdole, i assume you didnt have this?
Did not have any errors on install. "stdole" Not even sure I have seen one.
Installed it yesterday at home. No time to play here at work today.
Dan
jameswilson
ok i will have a look into this maybe its an error on the clients machine
James Wilson
jameswilson
Update to beta
Fixed stdole bug as above
Added another custom view
chnaged how custom viwes are saved
added default veiw selection
added another custom view (ie custom 1 and 2)
added timed change of views for both custom views
added enduser settings
settings now called setup (admin)
added multievent export allowing all curently archived events for selected camera to be exported as 1 video
still have the ffmpeg issue with media player as laways if you know a player that doesnt do this or how to use 0.4.9 from the command line then we can fix it
fixed some of the clean up code that didnt always delete the jpegs after video creation
Fixed some of the speech issues with ms SAM
Let me know of any problems
James
James Wilson
wa4bro
Post by wa4bro »
jameswilson wrote:Update to beta
James
Custom views apppear ok James.
Was unable ti check archived events. I had none so of course errors.
Sam sounds better.
Just another though for a view.
Say have a "swap" button for like in quad view. Hitting swap, would bring next 4 cameras up in quad view ( The larger windows) hitting swap would again rotate int he next 4 cameras etc. As long as they were defined cams etc. Could even maybe also have a timed swap to quad view. Like cycle but cycle in 4 cams in quad view replaced the current quad views in cycle until stopped. Just a thought... the larger picture views look better to the old eyes too. <g>
Dan
jameswilson
yeah i see what your saying, trouble is would be hard to impliment but i will have a think. btw problem with timed changevof view, it does it on the minutes every hour, i have fixed this and will post a new Beta
James Wilson
jameswilson
Beta Update
Fixed problem wit hauto swiutch of custom views occuring at the minulte selected not the time delected
features added
When clicking on views 2-16 repeatedly the next set of cams will open
ie click 4 and get cam 1-4 press again get 5-8, again get 9-12 etc etc
not enabled on the bigger views as i cant see the point
Added a checkbox in menu, which allows views to change as above as per the cycle timer in setup.
Added quality trackbar in menu to have greater flaxabilty than low med, high
removed (until edit db is written) archive only in playabck (used for joining events together)
In the usual place
James Wilson
wa4bro
Post by wa4bro »
Bingo James!
The cycling on re-clicking on a view works great!
Just what I was looking for too!
The cycle timer also works as advertised. All else loads and looks good!
Dan
