Zoneminder/CTU core CD distro
Same error
This is all step :
Upgrading all packages with command yum -y update ..
Setting up Update Process
Setting up Repos
Reading repository metadata in from local files
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package curl.i386 0:7.12.3-4.fc3 set to be updated
---> Package cups.i386 1:1.1.22-0.rc1.8.7 set to be updated
---> Package httpd.i386 0:2.0.53-3.3 set to be updated
---> Package php-pear.i386 0:4.3.11-2.8 set to be updated
---> Package slocate.i386 0:2.7-12.fc3.1 set to be updated
---> Package util-linux.i386 0:2.12a-24.5 set to be updated
---> Package termcap.noarch 1:5.4-4fc3 set to be updated
---> Package kernel.i686 0:2.6.12-1.1381_FC3 set to be installed
---> Package rp-pppoe.i386 0:3.5-22.1 set to be updated
---> Package glibc-common.i386 0:2.3.6-0.fc3.1 set to be updated
---> Package php.i386 0:4.3.11-2.8 set to be updated
---> Package xorg-x11-Mesa-libGL.i386 0:6.8.2-1.FC3.45.2 set to be updated
---> Package openssl.i686 0:0.9.7a-42.2 set to be updated
---> Package openssh-server.i386 0:3.9p1-8.0.3 set to be updated
---> Package mkinitrd.i386 0:4.1.18.1-1 set to be updated
---> Package ffmpeg.i386 0:0.4.9-0.3.20051207.2.fc3.CTU set to be updated
---> Package perl.i386 3:5.8.5-20.FC3 set to be updated
---> Package xorg-x11-libs.i386 0:6.8.2-1.FC3.45.2 set to be updated
---> Package pcre.i386 0:4.5-3.1.1.fc3 set to be updated
---> Package openssh-clients.i386 0:3.9p1-8.0.3 set to be updated
---> Package dhcpv6_client.i386 0:0.10-14_FC3 set to be updated
---> Package gnupg.i386 0:1.2.7-1 set to be updated
---> Package eject.i386 0:2.1.1-0.fc3.2 set to be updated
---> Package httpd-suexec.i386 0:2.0.53-3.3 set to be updated
---> Package glibc.i686 0:2.3.6-0.fc3.1 set to be updated
---> Package pyOpenSSL.i386 0:0.6-1.p23.1.fc3 set to be updated
---> Package MyODBC.i386 0:2.50.39-25.FC3.1 set to be updated
---> Package php-mysql.i386 0:4.3.11-2.8 set to be updated
---> Package mod_ssl.i386 1:2.0.53-3.3 set to be updated
---> Package perl-Compress-Zlib.i386 0:1.37-1.fc3 set to be updated
---> Package pam.i386 0:0.77-66.2.13 set to be updated
---> Package hwdata.noarch 0:0.146.1-1 set to be updated
---> Package e2fsprogs.i386 0:1.38-0.FC3.1 set to be updated
---> Package libgcc.i386 0:3.4.4-2.fc3 set to be updated
---> Package unzip.i386 0:5.51-4.fc3 set to be updated
---> Package zm.i386 0:1.22.2-0.2.fc.root set to be updated
---> Package info.i386 0:4.8-2.2 set to be updated
---> Package cups-libs.i386 1:1.1.22-0.rc1.8.7 set to be updated
---> Package openssh.i386 0:3.9p1-8.0.3 set to be updated
---> Package tzdata.noarch 0:2005m-1.fc3 set to be updated
---> Package wget.i386 0:1.10.2-0.fc3 set to be updated
---> Package perl-DBI.i386 0:1.40-6.fc3 set to be updated
---> Package udev.i386 0:039-10.FC3.8 set to be updated
--> Running transaction check
--> Processing Dependency: perl-X10 for package: zm
--> Processing Dependency: libtheora.so.0 for package: ffmpeg
--> Processing Dependency: perl(X10::ActiveHome) for package: zm
--> Processing Dependency: libpostproc.so.0.0.1 for package: ffmpeg
--> Restarting Dependency Resolution with new changes.
---> Package perl-X10.noarch 0:0.03-1 set to be updated
---> Package ffmpeg-libpostproc.i386 0:0.4.9-0.3.20051207.2.fc3.CTU set to be updated
---> Package libtheora.i386 0:1.0alpha3-5 set to be updated
--> Processing Dependency: perl(Time::ParseDate) for package: perl-X10
--> Processing Dependency: perl(Astro::SunTime) for package: perl-X10
---> Package perl-Time-modules.noarch 0:2003.1126-1 set to be updated
---> Package perl-Astro-SunTime.noarch 0:0.01-FC3 set to be updated
Dependencies Resolved
Transaction Listing:
Install: kernel.i686 0:2.6.12-1.1381_FC3 - ctu-updates-released
Update: MyODBC.i386 0:2.50.39-25.FC3.1 - ctu-updates-released
Update: cups.i386 1:1.1.22-0.rc1.8.7 - ctu-updates-released
Update: cups-libs.i386 1:1.1.22-0.rc1.warning: rpmts_HdrFromFdno: V3 DSA signature: NOKEY, key ID 4f2a6fd2
The GPG key at ftp://download.computerntelecom.com/pub/RPM-GPG-KEY-CTU (0x475C5926)
is already installed but is not the correct key for this package.
Check that this is the correct key for the "CTU Core 3 - i386 - Base" repository.
Update: curl.i386 0:7.12.3-4.fc3 - ctu-updates-released
Update: dhcpv6_client.i386 0:0.10-14_FC3 - ctu-updates-released
Update: e2fsprogs.i386 0:1.38-0.FC3.1 - ctu-updates-released
Update: eject.i386 0:2.1.1-0.fc3.2 - ctu-updates-released
Update: ffmpeg.i386 0:0.4.9-0.3.20051207.2.fc3.CTU - ctu-updates-released
Update: glibc.i686 0:2.3.6-0.fc3.1 - ctu-updates-released
Update: glibc-common.i386 0:2.3.6-0.fc3.1 - ctu-updates-released
Update: gnupg.i386 0:1.2.7-1 - ctu-updates-released
Update: httpd.i386 0:2.0.53-3.3 - ctu-updates-released
Update: httpd-suexec.i386 0:2.0.53-3.3 - ctu-updates-released
Update: hwdata.noarch 0:0.146.1-1 - ctu-updates-released
Update: info.i386 0:4.8-2.2 - ctu-updates-released
Update: libgcc.i386 0:3.4.4-2.fc3 - ctu-updates-released
Update: mkinitrd.i386 0:4.1.18.1-1 - ctu-updates-released
Update: mod_ssl.i386 1:2.0.53-3.3 - ctu-updates-released
Update: openssh.i386 0:3.9p1-8.0.3 - ctu-updates-released
Update: openssh-clients.i386 0:3.9p1-8.0.3 - ctu-updates-released
Update: openssh-server.i386 0:3.9p1-8.0.3 - ctu-updates-released
Update: openssl.i686 0:0.9.7a-42.2 - ctu-updates-released
Update: pam.i386 0:0.77-66.2.13 - ctu-updates-released
Update: pcre.i386 0:4.5-3.1.1.fc3 - ctu-updates-released
Update: perl.i386 3:5.8.5-20.FC3 - ctu-updates-released
Update: perl-Compress-Zlib.i386 0:1.37-1.fc3 - ctu-updates-released
Update: perl-DBI.i386 0:1.40-6.fc3 - ctu-updates-released
Update: php.i386 0:4.3.11-2.8 - ctu-updates-released
Update: php-mysql.i386 0:4.3.11-2.8 - ctu-updates-released
Update: php-pear.i386 0:4.3.11-2.8 - ctu-updates-released
Update: pyOpenSSL.i386 0:0.6-1.p23.1.fc3 - ctu-updates-released
Update: rp-pppoe.i386 0:3.5-22.1 - ctu-updates-released
Update: slocate.i386 0:2.7-12.fc3.1 - ctu-updates-released
Update: termcap.noarch 1:5.4-4fc3 - ctu-updates-released
Update: tzdata.noarch 0:2005m-1.fc3 - ctu-updates-released
Update: udev.i386 0:039-10.FC3.8 - ctu-updates-released
Update: unzip.i386 0:5.51-4.fc3 - ctu-updates-released
Update: util-linux.i386 0:2.12a-24.5 - ctu-updates-released
Update: wget.i386 0:1.10.2-0.fc3 - ctu-updates-released
Update: xorg-x11-Mesa-libGL.i386 0:6.8.2-1.FC3.45.2 - ctu-updates-released
Update: xorg-x11-libs.i386 0:6.8.2-1.FC3.45.2 - ctu-updates-released
Update: zm.i386 0:1.22.2-0.2.fc.root - ctu-updates-released
Performing the following to resolve dependencies:
Install: ffmpeg-libpostproc.i386 0:0.4.9-0.3.20051207.2.fc3.CTU - ctu-updates-released
Install: libtheora.i386 0:1.0alpha3-5 - ctu-base
Install: perl-Astro-SunTime.noarch 0:0.01-FC3 - ctu-base
Install: perl-Time-modules.noarch 0:2003.1126-1 - ctu-base
Install: perl-X10.noarch 0:0.03-1 - ctu-base
Total download size: 71 M
Downloading Packages:
public key not available for libtheora-1.0alpha3-5.i386.rpm
Retrieving GPG key from ftp://download.computerntelecom.com/pub/RPM-GPG-KEY-CTU
.. upgrade failed!
This is all step :
Setting up Repos
.. upgrade failed!
cant get updates working
Hello all I am using Cordel's FC3 v1.21.3 and I would like to install the updates. I used yum update and this is the result
Does this just mean the server is down and I should try again another time?
I have read the last three pages of this thread and tried most of the suggestions. Is there a detailed step by step how to someplace? Thanks in advance
[root@watcher]# yum update
Setting up Repos
http://download.computerntelecom.com/pub/linux/zoneminder/fedora/core/updates/3/i386/repodata/repomd.xml: [Errno 4] IOError: HTTP Error 404: Not Found
Trying other mirror.
Cannot open/read repomd.xml file for repository: ctu-updates-released
failure: repodata/repomd.xml from ctu-updates-released: [Errno 256] No more mirrors to try.
[root@watcher]
I just checked the server and that directory is missing
It also appears that a lot of the updated packages for that repo are also MIA
I'm not sure if the drive is failing but I see allot of suspicious activity in the access logs
I guess I'll be rebuilding this next weekend on a new system. I wasn't really ready to do this and am currently researching the best way to run several VM's using a shared data volume on the host and haven't really found a good way to do this yet. Maybe I'll just give running nfs on the host a shot and see what happens
I still haven't got to replace that server. Parts are on order and one of them should be arriving today. This just leaves me waiting for the PSU as I was not aware of the new EPS12v standard, so when I ordered my 3U case it was ordered with a ATX PSU
and because it's a 3U, I had to special order one for the I-Star case
and am still waiting for it to ship
I'lll be calling them shortly to find status.
Alright, every thing is in, together, and I have spent fifty hours this last week getting all the base stuff setup. So the OS's are installed and the server(s) are running and I'll be getting them configured over the next few weeks. I ran out of cash so I didn't get everything I had hoped for. I sacificed 2GB of Ram, got almost the cheapest Opteron F socket proc and didn't populate the other socket, and sacraficed the 3ware raid card and the cheaper rocket raid that I was looking at ( That's okay I'll wait for the 3ware card I think
. But thats okay as these can be added over time (besides it would be killer to get a couple quad cores when they come out
But that would just be playing now wouldn't it
). But, over all is seems to be performing better than I had anticipated and worst case I'll have to pick up another pair of ecc reg ram.
The urls are still the same and the packages are still in the same place but some where lost in the drive corruption but I moved what was left to the new system. I'm going to attempt to recover the drive from the build machine that blew up last year and get the rest of the packages and rebuild the repo.
If anyone would like to give me ssh access to their system (Has to be CTU core Distro) would be great and I could just pull the packages out of the cache and would be helpfull, time saving, and get me going forward a bit faster rather than working on data recovery
Also on the todo list is I'm going to setup a Trac site. every one will be able to use this to report bugs in the RPM's and of course get support for the rpm packages. This may expand to supporting other packages as well if the need arrises and I might add apt update support as well if the demand is there.
I'll keep everyone posted on this thread at least till I get the web frontend put back into place.
There still is alot to do and many weeks worth of configuration and testing to be done but anyway it's finaly started. And yes I have the server on a ups and an iso bar
Kernel Panic on new install
I have a second hand server, Dell Poweredge 2600 with 3 scsi disks in a raid 5 arrangement. The SCSI card is a PERC 4/Di ver 2.27
The CTU image was downloaded last night and boots fine. Goes through the install process with no errors evident until the reboot at the end.
It detects the SCSI controller and has this message on the boot screen and hangs.
SCSI0 Adaptec AIC7xxx esia/vlb/pci scsi hba driver, rev 6.2.36
mount: error 19 mounting ext3
mount: error 2 mounting none
switchroot: mount failed:22
umount /initrd/dev failed:2
Kernel Panic - not syncing: Attempted to kill init.
[<a whole bunch of numbers>] panic +4x42/0x1ca
similar line with profile task exit
similar line with do exit
similar line with syscall call
Then nothing, HELP!!!!
Regards Brad
Regards Brad
That's a bit odd as the driver from the image to install the CD is basically the same as the one installed. Since you were able to make it through the install, and setup the disks, I would be looking at the possibility of corruption in the ISO download concerning the kernel.
you can try putting the install CD back in and at the Linux prompt, type in mediacheck and this will allow you to check that the burn was good.
