Zoneminder/CTU core CD distro
bjoyce
Post by bjoyce »
Thanks for the reply cordel, sorry about my slow response, I have been away.
regarding running mediacheck, I have SME version of linux based on RH7.3, and SUSE 10.0 but mediacheck is not available.
I tried installing the disk in an ASUS server, dual xeon with 2 x 76GB SATA drives and the same error occurs. Also in a VMware box which I know can run it as it has been running their before but the same error occurs again.
Believing the CD to be faulty I burnt another with a different utility but the same thing happens. Thinking it might be my torrent download is corrupted so I have deleted the iso file and downloading again from the torrent.
I will see how I go. Thanks. Brad
bjoyce
Post by bjoyce »
Sorry to say a redo of the torrent and the cd iso burn on another computer have produced the same error.
The system boots with ferodacore 7 so will use that and try and get zoneminder working.
Brad
jayray
Post by jayray »
any word as to when the update server will be available?
csch999
Can not find zminit
Post by csch999 »
hi folks,
I just installed a brand new FC7 box. installed zoneminder via yum, but I can not find a directory called "/usr/lib/bin"
[root@desmoquattro lib]# cd /usr/lib/bin
-bash: cd: /usr/lib/bin: No such file or directory
I find some "zm***" files here
[root@desmoquattro lib]# zm
zma zmcontrol-pelco-p.pl zmpkg.pl
zmaudit.pl zmcontrol-visca.pl zmtrack.pl
zmc zmdc.pl zmtrigger.pl
zmcontrol-axis-v2.pl zmf zmu
zmcontrol-ncs370.pl zmfilter.pl zmupdate.pl
zmcontrol-panasonic-ip.pl zmfix zmvideo.pl
zmcontrol-pelco-d.pl zmore zmwatch.pl
but no zminit. does anybody have the same problem?
before I tried to create user zmuser with passwd zmuser and database zm manually, but zoneminder did not seem to work.
any help is welcome
thx
christian
