Can't get shared memory id '7a6d2001' in zmwatch.log
PacoLM
Post by PacoLM »
edgar5 wrote:I`ve the same situation as You. Have you got any solution of this problem??
I`ve still error:
01/24/11 23:10:30.161890 zmwatch[6157].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
01/24/11 23:10:40.164153 zmwatch[6157].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
01/24/11 23:10:50.166431 zmwatch[6157].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
01/24/11 23:11:00.168746 zmwatch[6157].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
01/24/11 23:11:10.170985 zmwatch[6157].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
01/24/11 23:11:20.173289 zmwatch[6157].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
01/24/11 23:11:30.175591 zmwatch[6157].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
Try to setup your system with only one camera enabled, set to the lower resolution that support (for instance 320x240). Check the values of kernel.shmmax and kernel.shmall in your /etc/systcl.conf file. Then restart the system and see what happens.
Hope it helps,
PacoLM
