No Video (all else is fine) new install
Nerre
Re: No Video (all else is fine) new install
Post by Nerre »
I had similar problems directly after my install (on Debian). I solved it by deleting all events, then new events as well as live video started working... But my guess is that it was a problem with the web browser cache not trying to load the updated content. Try to clear the browsers cache.
ZoneMinder in Puppy Linux Tahr is somewhat tricky, sort of Debian sort of Ubuntu. This problem sometimes occurs, and the fix is to change Web path to zms streaming server PATH_ZMS in Options>Paths from:
/cgi-bin/nph-zms
to:
/cgi-bin/zms
brought the video stream to life.
Hope it helps.
teraquad
Post by teraquad »
Ok,
I disabled the Barn camera and left Driveway on. Actually disabled both and enabled one Driveway
Then i tried to view Driveway a number of times. No results of corse but plenty of errors.
Hope this is what you want.
Date/Time
	Component 	PID 	Level 	Message 	File 	Line
2015-11-24 09:36:09.253787	zma_m4	6103	INF	Driveway: 7000 - Processing at 13.70 fps	zm_monitor.cpp	1160
2015-11-24 09:36:05.230779	zmc_m4	6068	INF	Driveway: 7000 - Capturing at 13.70 fps	zm_monitor.cpp	2907
2015-11-24 09:35:22.033367	zma_m2	6021	INF	Barn: 7000 - Processing at 14.93 fps	zm_monitor.cpp	1160
2015-11-24 09:35:19.515838	zmc_m2	5965	INF	Barn: 7000 - Capturing at 15.15 fps	zm_monitor.cpp	2907
2015-11-24 09:34:56.166720	zma_m4	6103	INF	Driveway: 6000 - Processing at 13.70 fps	zm_monitor.cpp	1160
2015-11-24 09:34:52.625263	zmc_m4	6068	INF	Driveway: 6000 - Capturing at 13.70 fps	zm_monitor.cpp	2907
2015-11-24 09:34:38.605720	web_php	1562	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-262332s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:34:28.478346	web_php	5005	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-262332s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:34:15.672901	zma_m2	6021	INF	Barn: 6000 - Processing at 15.15 fps	zm_monitor.cpp	1160
2015-11-24 09:34:15.003024	web_php	4924	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-262332s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:34:13.473243	zmc_m2	5965	INF	Barn: 6000 - Capturing at 15.15 fps	zm_monitor.cpp	2907
2015-11-24 09:33:43.293827	zma_m4	6103	INF	Driveway: 5000 - Processing at 13.70 fps	zm_monitor.cpp	1160
2015-11-24 09:33:41.706596	web_php	4832	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:33:39.784819	zmc_m4	6068	INF	Driveway: 5000 - Capturing at 13.89 fps	zm_monitor.cpp	2907
2015-11-24 09:33:24.782689	web_php	6881	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:33:11.196369	web_php	5005	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:33:09.557647	zma_m2	6021	INF	Barn: 5000 - Processing at 15.15 fps	zm_monitor.cpp	1160
2015-11-24 09:33:07.597598	zmc_m2	5965	INF	Barn: 5000 - Capturing at 15.15 fps	zm_monitor.cpp	2907
2015-11-24 09:32:57.712201	web_php	5014	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:32:43.074258	web_php	4853	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:32:30.898343	web_php	5008	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:32:30.628499	zma_m4	6103	INF	Driveway: 4000 - Processing at 13.89 fps	zm_monitor.cpp	1160
2015-11-24 09:32:27.389184	zmc_m4	6068	INF	Driveway: 4000 - Capturing at 13.89 fps	zm_monitor.cpp	2907
2015-11-24 09:32:20.652991	web_php	1562	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:32:10.492027	web_php	4950	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:32:03.482217	zma_m2	6021	INF	Barn: 4000 - Processing at 15.15 fps	zm_monitor.cpp	1160
2015-11-24 09:32:01.720833	zmc_m2	5965	INF	Barn: 4000 - Capturing at 15.15 fps	zm_monitor.cpp	2907
2015-11-24 09:32:00.331480	web_php	6876	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:31:50.232122	web_php	4825	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:31:40.098706	web_php	4807	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:31:29.907542	web_php	4966	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:31:19.405980	web_php	4796	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:31:18.265652	zma_m4	6103	INF	Driveway: 3000 - Processing at 13.89 fps	zm_monitor.cpp	1160
2015-11-24 09:31:15.170174	zmc_m4	6068	INF	Driveway: 3000 - Capturing at 13.89 fps	zm_monitor.cpp	2907
2015-11-24 09:31:09.209223	web_php	4905	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:30:59.004575	web_php	4845	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:30:57.156175	zma_m2	6021	INF	Barn: 3000 - Processing at 14.93 fps	zm_monitor.cpp	1160
2015-11-24 09:30:55.654919	zmc_m2	5965	INF	Barn: 3000 - Capturing at 15.15 fps	zm_monitor.cpp	2907
2015-11-24 09:30:48.836182	web_php	5005	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:30:38.672087	web_php	4961	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:30:28.530405	web_php	4978	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:30:18.345409	web_php	5014	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:30:07.049387	web_php	5025	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:30:06.392238	zma_m4	6103	INF	Driveway: 2000 - Processing at 13.89 fps	zm_monitor.cpp	1160
2015-11-24 09:30:03.284374	zmc_m4	6068	INF	Driveway: 2000 - Capturing at 13.89 fps	zm_monitor.cpp	2907
2015-11-24 09:30:00.176753	zma_m4	6103	INF	Driveway: 1915 - Opening new event 484, section start	zm_monitor.cpp	1405
2015-11-24 09:30:00.034524	zma_m4	6103	INF	Driveway: 1915 - Closing event 483, section end	zm_monitor.cpp	1385
2015-11-24 09:29:56.938719	web_php	4861	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:29:50.821482	zma_m2	6021	INF	Barn: 2000 - Processing at 15.15 fps	zm_monitor.cpp	1160
2015-11-24 09:29:49.855378	zmc_m2	5965	INF	Barn: 2000 - Capturing at 15.15 fps	zm_monitor.cpp	2907
2015-11-24 09:29:46.844274	web_php	4855	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:29:36.755971	web_php	4970	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:29:26.449654	web_php	4879	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:29:16.304951	web_php	4843	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:29:03.865294	web_php	5010	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:28:54.260918	zma_m4	6103	INF	Driveway: 1000 - Processing at 13.16 fps	zm_monitor.cpp	1160
2015-11-24 09:28:53.764343	web_php	4899	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:28:51.114033	zmc_m4	6068	INF	Driveway: 1000 - Capturing at 13.70 fps	zm_monitor.cpp	2907
2015-11-24 09:28:44.249362	zma_m2	6021	INF	Barn: 1000 - Processing at 14.93 fps	zm_monitor.cpp	1160
2015-11-24 09:28:43.713913	zmc_m2	5965	INF	Barn: 1000 - Capturing at 15.15 fps	zm_monitor.cpp	2907
2015-11-24 09:28:43.652756	web_php	5001	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:28:32.445342	web_php	4798	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:28:22.266149	web_php	4903	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:28:12.165510	web_php	4424	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:28:00.980347	web_php	4837	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:27:47.457289	web_php	4916	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:27:43.598910	zmwatch	6261	INF	Watchdog pausing for 30 seconds	zmwatch.pl
2015-11-24 09:27:43.388050	zmwatch	6261	INF	Watchdog starting	zmwatch.pl
2015-11-24 09:27:43.328090	zmdc	5761	INF	'zmupdate.pl -c' starting at 15/11/24 09:27:43, pid = 6517	zmdc.pl
2015-11-24 09:27:43.324900	zmdc	6517	INF	'zmupdate.pl -c' started at 15/11/24 09:27:43	zmdc.pl
2015-11-24 09:27:42.790460	zma_m4	6103	INF	Driveway: 026 - Opening new event 483, section start	zm_monitor.cpp	1405
2015-11-24 09:27:40.906440	zmfilter	6153	INF	Scanning for events	zmfilter.pl
2015-11-24 09:27:40.358490	zmdc	6261	INF	'zmwatch.pl' started at 15/11/24 09:27:40	zmdc.pl
2015-11-24 09:27:40.337420	zmdc	5761	INF	'zmwatch.pl' starting at 15/11/24 09:27:40, pid = 6261	zmdc.pl
2015-11-24 09:27:39.506270	zmdc	6202	INF	'zmaudit.pl -c' started at 15/11/24 09:27:39	zmdc.pl
2015-11-24 09:27:39.503530	zmdc	5761	INF	'zmaudit.pl -c' starting at 15/11/24 09:27:39, pid = 6202	zmdc.pl
2015-11-24 09:27:38.834080	zmdc	6153	INF	'zmfilter.pl' started at 15/11/24 09:27:38	zmdc.pl
2015-11-24 09:27:38.829810	zmdc	5761	INF	'zmfilter.pl' starting at 15/11/24 09:27:38, pid = 6153	zmdc.pl
2015-11-24 09:27:38.429462	zma_m4	6103	INF	In mode 5/1, warming up	zma.cpp	105
2015-11-24 09:27:38.277690	zmdc	6103	INF	'zma -m 4' started at 15/11/24 09:27:38	zmdc.pl
2015-11-24 09:27:38.272010	zmdc	5761	INF	'zma -m 4' starting at 15/11/24 09:27:38, pid = 6103	zmdc.pl
2015-11-24 09:27:38.255220	zmc_m4	6068	INF	Starting Capture	zmc.cpp	195
2015-11-24 09:27:37.903950	zmdc	6068	INF	'zmc -m 4' started at 15/11/24 09:27:37	zmdc.pl
2015-11-24 09:27:37.898290	zmdc	5761	INF	'zmc -m 4' starting at 15/11/24 09:27:37, pid = 6068	zmdc.pl
2015-11-24 09:27:37.836480	zmdc	5761	INF	Starting pending process, zmc -m 4	zmdc.pl
2015-11-24 09:27:37.702820	zmdc	5761	ERR	'zmc -m 4' exited abnormally, exit status 255	zmdc.pl
2015-11-24 09:27:37.623706	zma_m2	6021	INF	In mode 5/0, warming up	zma.cpp	105
2015-11-24 09:27:37.567500	zmdc	5761	INF	'zmc -m 4' starting at 15/11/24 09:27:37, pid = 6034	zmdc.pl
2015-11-24 09:27:37.565100	zmdc	6034	INF	'zmc -m 4' started at 15/11/24 09:27:37	zmdc.pl
2015-11-24 09:27:37.460700	zmdc	6021	INF	'zma -m 2' started at 15/11/24 09:27:37	zmdc.pl
2015-11-24 09:27:37.447210	zmdc	5761	INF	'zma -m 2' starting at 15/11/24 09:27:37, pid = 6021	zmdc.pl
2015-11-24 09:27:37.366795	zmc_m2	5965	INF	Starting Capture	zmc.cpp	195
2015-11-24 09:27:37.343260	zmdc	5761	INF	Starting pending process, zma -m 2	zmdc.pl
2015-11-24 09:27:37.269540	zmdc	5761	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2015-11-24 09:27:37.139187	zma_m2	5974	ERR	Shared data not initialised by capture daemon for monitor Barn	zm_monitor.cpp	421
2015-11-24 09:27:37.121655	web_php	4928	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:27:36.896420	zmdc	5761	INF	'zma -m 2' starting at 15/11/24 09:27:36, pid = 5974	zmdc.pl
2015-11-24 09:27:36.896400	zmdc	5974	INF	'zma -m 2' started at 15/11/24 09:27:36	zmdc.pl
2015-11-24 09:27:36.841710	zmdc	5965	INF	'zmc -m 2' started at 15/11/24 09:27:36	zmdc.pl
2015-11-24 09:27:36.827410	zmdc	5761	INF	'zmc -m 2' starting at 15/11/24 09:27:36, pid = 5965	zmdc.pl
2015-11-24 09:27:36.748740	zmdc	5761	INF	Starting pending process, zmc -m 2	zmdc.pl
2015-11-24 09:27:36.698790	zmdc	5761	ERR	'zmc -m 2' exited abnormally, exit status 255	zmdc.pl
2015-11-24 09:27:36.375670	zmdc	5921	INF	'zmc -m 2' started at 15/11/24 09:27:36	zmdc.pl
2015-11-24 09:27:36.373830	zmdc	5761	INF	'zmc -m 2' starting at 15/11/24 09:27:36, pid = 5921	zmdc.pl
2015-11-24 09:27:33.012880	zmdc	5761	INF	Server starting at 15/11/24 09:27:33	zmdc.pl
2015-11-24 09:27:30.229250	zmpkg	5466	INF	Command: start	zmpkg.pl
2015-11-24 09:27:26.983348	web_php	4805	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:27:24.366730	zmdc	3427	INF	Server shutdown at 15/11/24 09:27:24	zmdc.pl
2015-11-24 09:27:16.892617	web_php	4992	ERR	socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2330
2015-11-24 09:27:13.990070	zmdc	3427	INF	'zmfilter.pl ' exited, signal 14	zmdc.pl
2015-11-24 09:27:13.926710	zmdc	3427	INF	'zmfilter.pl ' stopping at 15/11/24 09:27:13	zmdc.pl
2015-11-24 09:27:13.853190	zmdc	3427	INF	'zmc -m 2' exited normally	zmdc.pl
2015-11-24 09:27:13.818537	zmc_m2	4460	INF	Terminating Logger	zm_logger.cpp	236
2015-11-24 09:27:13.759318	zmc_m2	4460	ERR	Unable to get response	zm_remote_camera_http.cpp	1176
2015-11-24 09:27:13.717414	zmc_m2	4460	ERR	Unable to read header	zm_remote_camera_http.cpp	650
2015-11-24 09:27:13.683933	zmc_m2	4460	ERR	Select error: Interrupted system call	zm_remote_camera_http.cpp	163
2015-11-24 09:27:13.650507	zmc_m2	4460	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2015-11-24 09:27:13.600490	zmdc	3427	INF	'zmc -m 2' stopping at 15/11/24 09:27:13	zmdc.pl
2015-11-24 09:27:13.551970	zmdc	3427	INF	'zma -m 4' exited normally	zmdc.pl
Thanks! George....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
You have a configuration problem, but so far I have been unable to find it.
Report the following:
rpm -qi zoneminder
Make sure you've put PATH_ZMS back to /cgi-bin/zm/nph-zms and the ZoneMinder Apache ScriptAlias matches that.
And have you completed this step from /usr/share/doc/zoneminder/README.Fedora:
7. IMPORTANT: Edit /etc/httpd/conf.d/zoneminder.conf and/or
/etc/httpd/conf/httpd.conf.
The httpd.conf file included with this version of Fedora processes the conf.d
folder after the default ScriptAlias directive in the httpd.conf file.
Previously, the conf.d folder was processed before the default ScriptAlias
directive. This causes a ScriptAlias overlap and breaks Zoneminder's
streaming abilities.
Reference: http://httpd.apache.org/docs/2.4/mod/mo ... html#order
Bug Report: https://bugzilla.redhat.com/show_bug.cgi?id=973067
WORKAROUND #1
If you are running zoneminder on a dedicated server then the simplest
solution may be to simply comment out the line in httpd.conf that reads:
WORKAROUND #2
If you need both the default cgi-bin folder & the zoneminder cgi-bin folder
then a solution might be to move the following line before the default
ScriptAlias directive in the httpd.conf file:
IncludeOptional conf.d/*.conf
teraquad
Post by teraquad »
Here is the first part:
It will take me a while on the rest.
Thanks! George....
[george@tera-two Desktop]$ su -l
Password:
[root@tera-two ~]# systemctl start zoneminder
[root@tera-two ~]# rpm -qi zoneminder
Version     : 1.28.1
Release     : 4.fc23
Architecture: x86_64
Install Date: Wed 18 Nov 2015 08:34:22 AM EST
Group       : System Environment/Daemons
License     : GPLv2+ and LGPLv2+ and MIT
Signature   : RSA/SHA256, Tue 23 Jun 2015 05:03:32 PM EDT, Key ID 32474cf834ec9cba
Source RPM  : zoneminder-1.28.1-4.fc23.src.rpm
Build Date  : Fri 19 Jun 2015 01:46:29 AM EDT
Build Host  : buildhw-11.phx2.fedoraproject.org
Relocations : (not relocatable)
Packager    : Fedora Project
Vendor      : Fedora Project
URL         : http://www.zoneminder.com/
Summary     : A camera monitoring and analysis tool
Description :
ZoneMinder is a set of applications which is intended to provide a complete
solution allowing you to capture, analyse, record and monitor any cameras you
have attached to a Linux based machine. It is designed to run on kernels which
support the Video For Linux (V4L) interface and has been tested with cameras
attached to BTTV cards, various USB cameras and IP network cameras. It is
designed to support as many cameras as you can attach to your computer without
too much degradation of performance.
[root@tera-two ~]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
Okay, that answers it. You are using a zoneminder rpm from Fedora, rather than the rpm packaged by us.
The package from Fedora does not have ffmpeg or vlc support, which is needed in many cases.
You should completely uninstall the version of ZoneMinder you have.
Once you do that, go here, select Fedora 23 as your distro, and take care to follow the instructions exactly:
http://zmrepo.zoneminder.com/
Don't forget to add "exclude=zoneminder*" to your fedora.repo file so you don't end up with Fedora's rpm again.
teraquad
Post by teraquad »
Wow,
Thanks! I added the zoneminder repo and assumed all was well because i thought fedora was using an old version like f22 or 21. Guess assuming isn'r the way to go.
In any event thank you very much. It will take a little while but you can bet i'll be back.
Thanks! George....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
teraquad
Post by teraquad »
Just for my own curiosity how can i be certian i have the ZM REPO version of zoneminder?
Sure would hate to do this again!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
Perform another "rpm -qi zoneminder" and compare the differences between this output and what you posted previously.
The Signature is not mine.
The Packager says Fedora, instead of me, Andrew Bauer
The Build Host shows a machine name that is part of Fedora
glenm
Post by glenm »
You're not using the same distro as me, and probably followed different setup instructions, so this might not help you.
I had a similar problem that stemmed from following instructions without thinking. :) I wrote about it in the Gentoo Zoneminder wiki, cuz those were the wrong instructions I had followed at the time. Copying my text from there ...
The symptoms for me were a) a 404 in apache logs, couldn't find zms or nph_zms;
[Tue Oct 27 10:38:55.754977 2015] [cgi:error] [pid 29986] [client 192.168.0.9:54882] AH02811: script not found or unable to stat: /var/www/localhost/cgi-bin/nph-zms, .. blah blah
192.168.0.9 - - [27/Oct/2015:10:38:55 -0700] "GET /cgi-bin/nph-zms?source=event&mode=jpeg&event=5&frame=1&scale=50&rate=100&maxfps=30&replay=single&connkey=313914&rand=1445967535 HTTP/1.1" 404 274
and b) apparent missing socket in the zonemaster logs.
ERR [socket_sendto( /var/run/zm/zms-264615s.sock ) failed: No such file or directory]
I read http://httpd.apache.org/docs/2.2/howto/cgi.html, to remind myself how ScriptAlias is supposed to work. In particular, it points to a directory, not to a file.
I made the following changes in my config. In /etc/apache2/vhosts.d/10_zoneminder.conf:
# ScriptAlias /cgi-bin/zms "/usr/libexec/zoneminder/cgi-bin/zms"
# ScriptAlias /cgi-bin/nph-zms "/usr/libexec/zoneminder/cgi-bin/nph-zms"
ScriptAlias /zm/cgi-bin/ "/usr/libexec/zoneminder/cgi-bin/"
In zm web UI, set
Options -> Paths -> PATH_ZMS = /zm/cgi-bin/zms
After a restart of zm and apache, I am now able to see streamed images.
HTH, and good luck.
glen
stevewrightnz1
Post by stevewrightnz1 »
I have exactly the same issue on an ubuntu install - nothing here seemed to help
Steve
Mines all fixed by upgrading to 1.2.109 :) :D
Last edited by stevewrightnz1 on Fri Nov 27, 2015 9:39 pm, edited 1 time in total.
Guys,
The issue here was Fedora silently released their own ZoneMinder 1.28.1 rpm without our knowledge. The problem with that is Fedora will not build ZoneMinder with ffmpeg or vlc support. It is against their policy, apparently. Unfortunately, most modern cameras need ffmpeg or vlc in one form or another to work. Adding ffmpeg and vlc after the fact will not solve the problem. ZoneMinder has to be built with vlc and ffmpeg development libraries pre-installed on the build host.
This means that anyone who installs Fedora's ZoneMinder package will not be able to achieve a working system, unless they are using capture cards or really old mjpeg ip cameras.
The steps to get (our) ZoneMinder working on Fedora our fully documented on the zmrepo site.
This is not a Gentoo problem, nor is is an Ubuntu problem, nor does it relate to any other distro. If you are not using Fedora, then you should look elsewhere.
teraquad
Post by teraquad »
As you can see, IT WORKS! It was quite an effort but IT WORKS! The editing and switching from one document to the next was tough for me. But quite a lot better than it was working it the first time. The readme was very helpful. I fear though that i must have typo'ed or left out something as i am getting continuous errors. I see 10-20 FPS on 3 cameras. i can only imagine what it will do once this small problem is worked out.
Thank You all Very much for the help. it has been a lifesaver.
I bought a network dvr but it is incompatible with all my cameras if my setup is even right. The poor info on both the cameras and the DVR is scarce. Zoneminder Has it beat hands down..
Thanks again!
george....
Date/Time
2015-11-27 10:18:07.553904	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:07.518573	zma_m3	3589	INF	Driveway: 13327 - Closing event 951, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:07.478202	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:07.409309	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:07.341682	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:07.274514	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:07.166533	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:07.073519	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.996906	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.930043	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.861743	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.781356	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.709638	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.642314	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.574745	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.506560	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.439796	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.405616	zma_m3	3589	INF	Driveway: 13313 - Opening new event 951, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:18:06.371720	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.287811	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.212005	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.180766	zma_m3	3589	INF	Driveway: 13313 - Closing event 950, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:06.144555	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.074809	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:06.007177	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.939698	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.872483	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.739193	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.512297	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.443991	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.376442	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.308354	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.240709	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.173658	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.106196	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:05.022158	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.946409	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.860589	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.827234	zma_m3	3589	INF	Driveway: 13298 - Opening new event 950, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:18:04.793404	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.726763	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.658355	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.626578	zma_m3	3589	INF	Driveway: 13298 - Closing event 949, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:04.589623	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.513786	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.430626	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.396512	zma_m3	3589	INF	Driveway: 13296 - Opening new event 949, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:18:04.362048	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.294514	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.227396	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.197058	zma_m3	3589	INF	Driveway: 13296 - Closing event 948, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:04.164466	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:04.083590	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.931473	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.797451	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.729859	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.661944	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.659405	zmc_m2	3556	INF	Living-Room: 19000 - Capturing at 13.70 fps	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	2907
2015-11-27 10:18:03.629076	zma_m3	3589	INF	Driveway: 13291 - Opening new event 948, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:18:03.595557	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.527933	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.451431	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.422005	zma_m3	3589	INF	Driveway: 13291 - Closing event 947, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:03.384077	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.316600	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.247736	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.180486	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.112902	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:03.036961	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.971196	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.902857	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.834818	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.771310	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.699817	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.624007	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.514039	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.438049	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.403910	zma_m3	3589	INF	Driveway: 13278 - Opening new event 947, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:18:02.362635	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.286419	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.177475	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:02.046162	zma_m3	3589	INF	Driveway: 13278 - Closing event 946, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:01.976468	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.800616	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.716495	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.647483	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.580034	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.512596	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.478693	zma_m3	3589	INF	Driveway: 13273 - Opening new event 946, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:18:01.444920	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.377609	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.310454	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.279579	zma_m3	3589	INF	Driveway: 13273 - Closing event 945, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:01.216371	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.108486	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:01.031559	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.998395	zma_m3	3589	INF	Driveway: 13271 - Opening new event 945, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:18:00.963051	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.895662	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.828220	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.797237	zma_m3	3589	INF	Driveway: 13271 - Closing event 944, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:18:00.535747	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.459825	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.392305	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.324229	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.256556	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.190998	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.104724	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.070992	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:18:00.027727	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.960275	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.884427	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.808537	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.732627	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.657606	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.623565	zma_m3	3589	INF	Driveway: 13259 - Opening new event 944, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:59.590113	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.522398	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.454088	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.423239	zma_m3	3589	INF	Driveway: 13259 - Closing event 943, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:59.386422	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.310856	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.234614	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.200945	zma_m3	3589	INF	Driveway: 13257 - Opening new event 943, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:59.167671	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.098937	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.031708	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:59.001839	zma_m3	3589	INF	Driveway: 13257 - Closing event 942, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:58.963994	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.896720	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.827556	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.786205	zma_m3	3589	INF	Driveway: 13255 - Opening new event 942, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:58.743477	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.676030	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.612080	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.551755	zma_m3	3589	INF	Driveway: 13255 - Closing event 941, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:58.507674	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.409530	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.302115	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.199250	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.138780	zma_m3	3589	INF	Driveway: 13252 - Opening new event 941, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:58.104325	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:58.037852	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.968117	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.937887	zma_m3	3589	INF	Driveway: 13252 - Closing event 940, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:57.900844	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.833490	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.765384	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.732481	zma_m3	3589	INF	Driveway: 13250 - Opening new event 940, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:57.698026	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.630809	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.563817	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.533355	zma_m3	3589	INF	Driveway: 13250 - Closing event 939, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:57.487637	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.411796	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.302014	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.217225	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.141385	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.107925	zma_m3	3589	INF	Driveway: 13246 - Opening new event 939, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:57.075038	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:57.006559	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.939245	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.913468	zma_m3	3589	INF	Driveway: 13246 - Closing event 938, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:56.839396	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.737273	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.661824	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.584142	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.550448	zma_m3	3589	INF	Driveway: 13243 - Opening new event 938, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:56.516626	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.448811	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.382052	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.351518	zma_m3	3589	INF	Driveway: 13243 - Closing event 937, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:56.306206	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.222047	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.129582	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:56.028267	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.960877	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.893488	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.824784	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.755250	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.464629	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.422237	zma_m3	3589	INF	Driveway: 13235 - Opening new event 937, section start	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1405
2015-11-27 10:17:55.380695	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.312890	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.196140	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.175094	zma_m3	3589	INF	Driveway: 13235 - Closing event 936, section end	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp	1385
2015-11-27 10:17:55.119193	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:55.051577	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.934673	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.864868	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.788949	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.713211	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.637599	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.569767	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.502274	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.435118	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.365970	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.298317	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.205806	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
2015-11-27 10:17:54.138160	zmc_dvideo0	3424	ERR	Attempt to assign buffer from a NULL pointer	/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp	417
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
Hmmm... Still not too late to switch to Ubuntu (poke!) :wink:
bb
