Zoneminder 1.30.2 not working with Amcrest IP2M-842E/ RTP/RTSP missing from Source/Remote Method dropdown
scott.borisch
Re: Zoneminder 1.30.2 not working with Amcrest IP2M-842E/ RTP/RTSP missing from Source/Remote Method dropdown
Post by scott.borisch »
So it would appear that:
Options => Paths => DIR_IMAGES
is where images are recorded when the zoneminder function is set to "record".
http://zoneminder.readthedocs.io/en/lat ... paths.html
On my system, this is "images". Presumably this is the path relative to the web root? Where is this?
It wouldn't appear to be /var/www, as there is not /var/www/images folder.
I can't seem to find anything in
http://zoneminder.readthedocs.io/en/lat ... index.html
that describes where to find this.
additionally, searching
sudo ls -ltr /zm/cgi-bin # I sued the PATH_ZMS because it had fewer false hits compared with images
sudo ls -ltr /*/zm/cgi-bin
sudo ls -ltr /*/*/zm/cgi-bin
finds nothing (to several levels of /*).
How do I locate the web root so I can find my recordings?
Thanks.
the events, images and temp directories are in Ubuntu type setups in /var/cache/zoneminder. This directory must belong to the user ZoneMinder runs under. These are usually symlinked to /usr/share/zoneminder/www
You may want to start over and use these install instructions:
scott.borisch
OK, now that I have the record feature enabled, I see that the webpage with the live camera feed now has events with:
ID Name Time Secs Frames Score
and clicking on the event takes me to the archived video.
So I'll just need to figure out how to configure for the desired number of hours of footage to keep, and I think I will have all I want.
scott.borisch
I'll try this if I need to star over for some reason, but at this point, I believe everything I need is working.
scott.borisch
/var/cache/zoneminder/events/2/17/04/29/08/00/05/
yes I see captured jpgs here. Thanks.
scott.borisch
It looks like:
http://zoneminder.readthedocs.io/en/latest/faq.html
describes how to limit amount of stored video (images), so looks like I am good on this.
scott.borisch
I ended up installing zoneminder on a different PC so I had more disk space, so I used:
and can confirm this worked for me.
It avoided the file permission issues I had with
http://zoneminder.readthedocs.io/en/lat ... untu-16-04
scott.borisch
Seems to work fine.
Consider this thread closed.
