I might be able to sed the proper values into the sql file, I just have never tried as I'd hate to buger that up
under paths:
ZM_PATH_ZMS -> /cgi-bin/zm/nph-zms
ZM_PATH_SOCKS -> /var/lib/zm
ZM_PATH_LOGS -> /var/log/zm
under web:
ZM_WEB_ALARM_SOUND -> redalert.wav
ZM_WEB_SOUND_ON_ALARM -> checked (of course these two for sound are not required)
ZM_WEB_LIST_THUMBS -> checked (also not required but I normaly set for the rpms)
ZM_WEB_MONTAGE_WIDTH ->320
ZM_WEB_MONTAGE_HEIGHT -> 240
under tools:
ZM_OPT_CAMBOZOLA -> checked
ZM_OPT_MPEG -> ffmpeg
ZM_OPT_NETPBM -> checked (required for the package to install)
under Debug:
ZM_EXTRA_DEBUG_LOG -> /var/log/zm/zm_debug.log+
Where are your ffmpeg shared libraries?pcalleros wrote:Feb 4 00:20:21 ICS-ZM zm: /usr/lib/zm/bin/zmfix: error while loading shared libraries: libavformat.so: cannot open shared object file: No such file or directory
error: Failed dependencies:
perl(X10::ActiveHome) is needed by zm-1.22.0-1.7.fc.root.i386
