Ubuntu 7.04 (Feisty Fawn) installation walkthrough (kind of)
Lee Sharp
Post by Lee Sharp »
mrd wrote:Ok...got the video working bby following the Ubuntu wiki
http://www.zoneminder.com/wiki/index.php/Ubuntu_7.04
which I didn't find on my inital search here...
"chmod 666 /dev/video0"
worked...
This may fail on reboot. The actual fix is listed by me above.
As to ffmpeg, it is only used if you want to stream mpeg or export mepeg. I don't miss it.
ktheking
Post by ktheking »
Zonerminder version : 1.22.3
Ubuntu 7.10 Feisty : Alternate version (command line) : http://releases.ubuntu.com/7.10/
AMD900 - 320Mb ram - 80Gb sata hd
PV143 - 4 port video card
Updated 26/12/2007
Used guides for install :
ryscar's direction (see this forum thread)
Lee Sharp's directions (see this forum thread)
Most of the zm functions work ,except :
Problems :
1.ffmpeg encoding not working
2.zip creation not working (tar.gz works)
3.when user authenticating enabled ,streaming stops working
Problem 1 :ffmpeg encoding not working : solved
drubort wrote :
workaround/fix
I resolved it with the follow hack:
on line 323 of zmvideo.pl I removed the "&"
http://www.zoneminder.com/forums/viewtopic.php?t=7250
TIP : if you use 'vi' for editing (to show linenumbers type ':set number' ,to hide the number sagain 'set nonumber')
Problem 2 :zip creation not working (tar.gz works)
still searching ...
Problem 3 :when user authenticating enabled ,streaming stops working.
Already discovered this in apache error log ( /var/log/apache/error.log) : Error, unable to authenticate user
It comes down to this : http://www.mail-archive.com/ubuntu-bugs ... 18717.html
So the problem lies in the .deb package made available by Peter Howard (for which many thanks ..). This package needs to be reworked ,so that it incorporates the package 'libssl-dev'. (this might also come from the fact that openssl is installed in one of the packages of the medibuntu ,which was installed after the install of zoneminder).
Got something very strange :
I did a clean install(with rebuild) ,it seemed at first to be solved.
After enabling user authenticating streaming still worked.
But then after enabling the combozola ,adapted the zm script ( according to http://www.zoneminder.com/wiki/index.ph ... Auto-Start and inserting the zoneminder in init.d for autoboot ,and also rebooting the problem re-appeared again ...
Then surprisingly the day after : it worked again ! I suspect not enough cpu time.
I think I'm on to something ...
I've done the clean install as described in http://www.zoneminder.com/forums/viewto ... 09b1e17e8e
For the additional needed perl modules I used this :
http://www.zoneminder.com/wiki/index.ph ... ZoneMinder
But slightly changed (in order to get medibuntu also on it )
Prepare pre-requisites :
debian:~#sudo -i
debian:~#vi /etc/apt/sources.list (remove line with cd)
debian:~#apt-get update
debian:~#apt-get upgrade
debian:~# apt-get install ssh
Here you can connect with ssh client (ex. putty) to your ZM machine
And continue the install on your own pc.
debian:~# apt-get install apache2 mysql-server libmysqlclient15-dev php5 php5-mysql g++ make netpbm libssl-dev libjpeg62-dev libmime-perl libwww-perl libarchive-tar-perl libdate-manip-perl libarchive-zip-perl libmime-lite-perl libdbi-perl libdbd-mysql-perl libpcre3-dev
debian:~# echo kernel.shmmax = 134217728 >> /etc/sysctl.conf
debian:~# echo kernel.shmall = 134217728 >> /etc/sysctl.conf
debian:~# reboot
debian:~# wget -q http://packages.medibuntu.org/medibuntu-key.gpg -O- | apt-key add -
debian:~# wget -q http://www.medibuntu.org/sources.list.d/feisty.list -O /etc/apt/sources.list.d/medibuntu.list
debian:~# wget -q http://wine.budgetdedicated.com/apt/387EE263.gpg -O- | sudo apt-key add -
debian:~# wget http://wine.budgetdedicated.com/apt/sources.list.d/feisty.list -O /etc/apt/sources.list.d/winehq.list
debian:~# apt-get update
debian:~# apt-get install traceroute p7zip unace rar xfonts-intl-european flashplugin-nonfree sun-java5-plugin faad ffmpeg gstreamer0.10-ffmpeg gstreamer0.10-pitfdll gstreamer0.10-plugins-bad gstreamer0.10-plugins-bad-multiverse gstreamer0.10-plugins-ugly gstreamer0.10-plugins-ugly-multiverse lame liba52-0.7.4 libartsc0 libdc1394-13 libdvdread3 libfaac0 libfaad2-0 libgsm1 libid3tag0 libimlib2 liblame0 libmad0 libmjpegtools0c2a libmms0 libmodplug0c2 libmp4v2-0 libmpcdec3 libmpeg2-4 libsidplay1 libswfdec0.3 libxine1-ffmpeg libxvidcore4 libxvmc1 mjpegtools ntp sox vorbis-tools libdvdcss2 w32codecs msttcorefonts ogle-mmx ogle-gui streamtuner streamripper
Prepare mail capabilities :
Prepare cpan usage :
apt-get install unzip lynx ncftp
during this phase,the newest pre-requisites for cpan install are installed.This is needed for following module installs :
    debian:~#perl -MCPAN -e shell
    >cpan : install Bundle::CPAN   (just press 'return' on all questions)
    >cpan : reload
    >cpan : quit
Install sendmail components :
    apt-get install postfix       (=> choose 'internet' during install , choose your own local domain name or make one up , ex. atmyplace.net)
Get needed perl modules :
    >cpan : install MIME::Tools
    >cpan : install MIME::Lite
    quit
Prepare extra capabilities (X10,serialport)
   >cpan : reload CPAN
   >cpan : install Archive::Tar (seems to be optional => depend on the way you install yourdistro)
   >cpan : install Archive::Zip (seems to be optional => depend on the way you install yourdistro)
   >cpan : install DateTime
   >cpan : install Date::Manip updated 2006-03-04 thanx to mickecarlsson
   >cpan : install Bundle::libnet
   >cpan : install Device::SerialPort
   >cpan : install Astro::SunTime Updated 2006 03 24 correct spelling error on SunTime (thanx to mickecarlsson)
   >cpan : install X10
   >cpan : quit
Do ZM install :
debian:~# wget http://freshmeat.net/redir/zoneminder/33246/url_tgz/ZoneMinder-1.22.3.tar.gz
debian:~# tar -xvzf ZoneMinder-1.22.3.tar.gz
debian:~# cd ZoneMinder-1.22.3
debian:~/ZoneMinder-1.22.3# ./configure  --with-lame=/usr/bin --with-ffmpeg=/usr/bin --with-mysql=/usr/bin --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data
debian:~/ZoneMinder-1.22.3# mysql mysql < db/zm_create.sql
mysql> grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
mysql> quit
debian:~/ZoneMinder-1.22.3# mysqladmin reload
debian:~/ZoneMinder-1.22.3# make install
correct the error : sh: Syntax error: Bad fd number
debian:~/ZoneMinder-1.22.3#dpkg-reconfigure dash
==> Here respond to 'NO'
configure the autostart :
Froml this point on ,the start of ZM has been done ,and you can access it.
correct some path vars :
-connect to http://debian/zm and change this options ...
Paths/ZM_PATH_ZMS - /cgi-bin/zms
enable and correct the authenticating problem :
debian:~#vi /usr/local/bin/zmvideo.pl
type ':set number' to view the linenumbers
go to line '323' and remove the "&" (press x to remove).
type ':wq!' to save
(if you made an error ,type ":q!" to exit vi)
Now go to ZM gui : http://debian/zm ,and enable user authenticating.
Next add your users and passwords in the gui.
gui=Graphical User Interface
Fill in 'ZM_AUTH_HASH_SECRET' field with some custom chosen hash code (ex. abc123)
set field 'ZM_OPT_USE_AUTH' Authenticate user logins to ZoneMinder : enabled
restart ZM (click on 'Running in GUI')
Login field now appears :
the default login is : admin
password : admin
Next change this password ,and add new users if needed.
=> Options => Users
Next reboot the machine (not sure if this is needed ,but I do it anyway..)
Clear cache from your firefox (not sure if this is needed ,but I do it anyway..)
Remove any create monitor instances (not sure if this is needed ,but I do it anyway..)
Check you streaming. (create new monitor ,set to 'monitor' and click 'new')
Install cambozola for IExplore streaming :
debian:~#cd /usr/local/src
  debian:~#wget http://www.charliemouse.com/code/cambozola/cambozola-latest.tar.gz
  debian:~#tar xvfz cambozola-latest.tar.gz
  debian:~#cp /usr/local/src/cambozola-0.68/dist/cambozola.jar /var/www/zm
  debian:~#chmod 775 /var/www/zm/cambozola.jar
Enable now cambozola in the GUI
Options => Images => ZM_OPT_CAMBOZOLA => enable
zmfilter.pl : Fix background filters , for filter with "Name" set with operator "matches". 26/12/2007 update
source : http://www.zoneminder.com/forums/viewtopic.php?t=10815
line 378: single quotes missing
   $filter_sql .= " not regexp $value";
    needs to be changed to
   $filter_sql .= " not regexp '$value'";
line 374 : single quotes missing
   $filter_sql .= " regexp $value";
   $filter_sql .= " regexp '$value'";
Extra features that I want to work as well :
1. DYNDNS :
I've added a tool (ddclient) for dyndns update ,so that the machine is reachable from a fixed url name.
I got install instructions here : http://ubuntuguide.org/wiki/Ubuntu:Feisty (search for ddclient)
Dyndns config-guide : http://www.dyndns.com/support/kb/using_ ... vices.html
2. Firewall : still need to do
3. Remote ssh (over wan) :
24/10/2007 update :
My main problem was : How to get trough the proxy (which uses NTLM authenticating). In order to be able to connect to the ZM machine from ANYWHERE.
These steps were needed :
-configure firewall of the router to which zoneminder is connected ,in order to do port forwarding :
WAN : 443 => 192.168.xxx.xxx (zm ip adress) : 22
-install 'NTLM Authorization Proxy Server' on client pc. , then just connect your client terminal (ex. putty) from whatever wan adress to the wan address of your zm installation ON PORT 443 !
This is the package you need : http://ntlmaps.sourceforge.net/
4. Alarm reporting over cellphone (sms),or regular 56k modem : still need to do :
27/12/2007 update :
Found it : I'm gonna use gnokii : http://www.gnokii.org/
More details will follow for install guidelines and usage ...
06/01/2008 update :
More details here :
http://www.zoneminder.com/forums/viewtopic.php?t=10976
5. Motion detection input from external motion detectors (X10) : still need to do
6. https enabling ... (I'd prefer all of this would work over an secured http connection)
7. Alarm triggering towards an external source (relay,alarm central,etc.)
26/12/2007 update :
Found a controller board which might enable me to achieve this : Arduino
More details in this thread : http://www.zoneminder.com/forums/viewto ... f9b88250fd
8. Audio recording : this could be achieved using feature 7 ,here above.
31/10/2007 update :
Here are already some of my findings ,on how get audio streaming+recording started : http://www.zoneminder.com/forums/viewtopic.php?t=10607
9. Webalizer for web site statistics
install webalizer : sudo apt-get install webalizer
add webalizer to crontab :
sudo crontab -e
0 * * * *  webalizer -t TEST -o /var/www/webalizer /var/log/apache2/access.log
Now you can access the statistics on you zoneminder access on http://hostname/webalizer (were hostname is you ip adress ,or hostname of your zoneminder machine)
more on webalizer :
http://fontignie.blogspot.com/2006/04/i ... er-on.html
http://linux.die.net/man/1/webalizer
10. setup smtp server for sending mails trough zoneminder
24/10/2007 update :
Tried to install estmp ,to use gmail smtp server ,but can't get the darn stuff working. I must face it : I'm a noob in linux mail setup. :oops: . I would appreciate some help on setting up email from scratch on ubuntu.
Used this guide : http://ubuntu-tutorials.com/2007/07/08/ ... mta-esmtp/
27/10/2007 update :
Forget about the estmp stuff ... I forgot the most important rule in IT : simplicity
I just had to fill in trough the GUI ,in the field ZM_EMAIL_HOST (options,email) the name of my provider's smtp server (smtp.xxxx.xxx) .
And in the field ZM_FROM_EMAIL ,an email adress ending with my provider's location ( blablabla@xxxxxxx.xxx ).
26/12/2007 update :HOWEVER , postfix should be installed
11. System monitoring : very important for first installs,to see if your system can coop with the load.
27/10/2007 update :
Munin : http://www.ubuntugeek.com/monitoring-se ... buntu.html
Straight forward install ,just follow the guidelines in this link here above.
It can monitor :
cpu,eth,disk,mysql and much more ...
12. Get mpeg streaming to work : (just for finishing touch ,not really needed)
03/11/2007 update :
on ./configure some libraries seem to be missing :
WARNING: libavutil.a may be required for MPEG streaming
Those might be needed if accessing from a flash client.
13. [New 26/12/2007 update :] : Backup,Restore,Redundancy,UPS
UPS : http://www.zoneminder.com/forums/viewtopic.php?t=10897
I'll create a new thread for this one ...
I'll keep you posted about my findings ..
Kind regards,
K. :lol: :lol:
PeterHoward
Post by PeterHoward »
ktheking wrote:Zonerminder version : 1.22.3
One of these days I'll actually have funds to get my main server going
again and I can chase down this #$@#$!@#$%!!! authentication bug :?
However . . .
One of the constraints on the .deb is that it needs to be suitable for Debian as well as Ubuntu (so I don't have to manage 2 variants). As far as Debian is concerned there a licensing issues with OpenSSL, hence Zoneminder depending on gnutls instead.
(http://en.wikipedia.org/wiki/OpenSSL#Li ... tibilities gives an overview of the issue)
I've looked back through my email archive and found I had questions back about how the authentication in ZM works wrt SSL authentication back in Feb, which I never followed up. I.e. if someone were to ask me how the authentication stuff works, my answer would begin with "um, . . . " and end pretty soon after.
Which means the answer for the package isn't quite as simple as (re-) linking against openssl. However, given I never chased this in the first place the answer may be pretty simple once I do look at it.
cordel
Post by cordel »
Peter, You might check and see what provides the md5.h file for the Apache build, you should be able to link to the same file as well and simplify the build so that you are not adding another requirement.
ktheking
Post by ktheking »
mrd
Post by mrd »
Did the authentication issue ever get resolved?
Just curious...
MRD
ktheking
Post by ktheking »
Yes. With installing the ZM from scratch did indeed resolved it.
However a collegue of mine did also an ZM install based on the .deb guidelines in some previous posts of this forum thread .
BUT : He didn't followed part2 of the guidelines of Lee Sharp.
And for him this worked prefectly !
Sooo : In one of the procedures of the step 2 ,there is an update done of the OpenSSL which is included in the .deb package. This is messing up the SSL.
conclusion : Do not update openssl once ZM is installed. (so closely check if when installing new packages if openssl update is included). -please correct me if I'm wrong -
Surely there must be a way to re-configure ZM to use the new SSL ,but I can't tell you how . :oops: (If anyone knows ,please be my guest to add a little description on how to ...)
K.
mbinstok
Post by mbinstok »
Hi, I'm having the same problem with user authentication !
When I enable ZM_OPT_USE_AUTH, I'm not able to see the video streaming anymore. If I disable it it works fine..
Also noticed the:
in:
/var/log/apache2/error.log
The configuration here is an Ubuntu 7.10 Server configured as per:
http://www.howtoforge.com/video_surveil ... der_ubuntu
I need to make user authentication work...
Is there anything I can try ?
Thanks a lot for your help !!
Mike
Buenos Aires - Argentina
mrd
Post by mrd »
I'm having trouble getting ZM to stream using swf. I've matched my settings from an older install from a liveCD and still can't get it to work. I'm thinking it has somehting to do with ffmpeg? I see that it's there, but is it really installed and working?
root@system-z:~# ls -l /usr/bin/ffmpeg
-rwxr-xr-x 1 root root 74012 2007-01-28 17:48 /usr/bin/ffmpeg
I've also been having trouble with authentication. I did the install as instructed in the original post wihtout any of the directions from Lee Sharp and experianced the issue. I'll try another install without the aptitude update and see what happens.
Any help would be great.
MRD
ktheking
Post by ktheking »
Better check these threads :
Flash/SWF generation to view events :
http://www.zoneminder.com/forums/viewtopic.php?t=8071
Flash streaming with live cd :
http://www.zoneminder.com/forums/viewtopic.php?t=7041
mrd
Post by mrd »
Unfortunatly, both of those posts are full or replies from me, so they aren't any help. I've had swf streaming working on my other systems, but there just seems to be something missing with ffmpeg in the ubuntu package.
MRD
PeterHoward
mrd wrote: I've had swf streaming working on my other systems, but there just seems to be something missing with ffmpeg in the ubuntu package.
Yep. The package, as I built it, does not have ffmpeg support. I suspect I've put something in which makes it look like it is, but it isn't.
As to authentication, yep again; I stuffed it in the original packaging process. Unfortunately fixing it (and still not using openssl libraries for licensing reasons) is non-trivial. I've started dealing with it but it will take time.
PJH
mrd
Post by mrd »
I'm sure everyone is glad to hear you are starting to work on it. I just wish I could help :-)
Having an Ubuntu package to install a full ZoneMinder system is absolutely priceless!
Thank you so much for your work on this.
P.S. I can certainly be a tester if you need someone to try out installs.
MRD
ktheking
Post by ktheking »
Beofres
Post by Beofres »
I followed ktheking's guide to install ZM on 7.10 Alternate, and it works perfectly on Xubuntu 7.10 Desktop.
Mpeg streaming doesn't work though, and hashed http authentication was finicky for the first hour, but *seems* to be working now.
Hope this helps.
