Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
if your not useing auth on the web interface then its a path problem.
Can you login to zm and get a live view of your first camera up
change to stills
right click on the image and post the path here
change to stills
James Wilson
done, but no new result..............voronwe wrote:Hi R2D2
1. Make sure that the user name and password you use to log into zm4ms are a user that is configured in you ZM configuration, if this is not the case then that is your frst problem.
2. When that is done you can play around with the events palyback, witch the mysql username and password are used for, an easy way to do this is to use phpMyAdmin to create a new user that have access from everywhere / your computer.
r2d2 i think your path is different from a stock install i need to know your path to zms
James Wilson
jameswilson wrote:if your not useing auth on the web interface then its a path problem.
change to stills
Path to zms is:r2d2 i think your path is different from a stock install i need to know your path to zms
/usr/lib/cgi-bin/zms
ok nearly there. On the live view window you should have a link called 'stills' in english
click on that, you will then get a still image of your monitor
Then right click that image and you will get a path
eg http://192.168.0.1/zm/etc etc
let me know that path. I think we need to change it in settings but i need to know what to change it to
James Wilson
oh yeah, mmm thats strange i have stills on mine. Oh well if your using cambazola hoer over to the righjt of the image and you will see an 'i' in a round box press that and that will give you a path, ill use that one!
James Wilson
no you dont need to. So that image you are showing is not a stream?
if not right clcik on it and let me know the path of that image
James Wilson
usualy you can right click on the image and select properties and it will show the http path.
I need to know the http path to zms to modify the setting in zm4ms. Is this box public?
James Wilson
did you have to modify your zms path in options to remove the nph- from it?
If so goto paths in zm4ms settings and remove the nph- from the path. that should sort it. I assume this is on debian or slackware
James Wilson
ok go into settings in zm4ms clcik the paths tab and remove nph- from the live view path setting. You should be done then
James Wilson
