Done, but zm4ms works still not yet.jameswilson wrote:ok go into settings in zm4ms clcik the paths tab and remove nph- from the live view path setting. You should be done then
Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
ok then i need to see a screen shot of your monitor settings in zm and in zm4ms
James Wilson
ah just noticed a couple of things
monitor 2 has 2.. in the address remove 1
and you need to add a ':' infront of the port number if using anything other than 80, if using 80 then leave blank or insert :80
James Wilson
ok then im starting to run out of ideas, i can only assume you have your monitor numbers mixed up. Can you post a screenshot of your console
James Wilson
ok then i cant see anything obvious here either.
I will need to see a full path, remember eairlier how you git a path to the image eg http://1.1.1.1/zms?etcetc.
get that path and put in a browser and check you get an image, if you do post that complete path so i can see what it looks like
James Wilson
Is it this what you mean?
When i type:
http://192.168.178.20/cgi-bin/zms?mode= ... 1155363699
in the Adressline of my Browser i can see the Picture.
btw: i have installed Cambozola, works fine.
When i type:
can you post your zm4ms live view path
becaus ethat should work
James Wilson
im lost then im afraid. I have never tried without aut and can only assume thats the issue.
If you put the whole path from the p[revious post "the one you put in a browser) and enable url mode that will work for live view
James Wilson
you enable it in zm. I have never tested but before you do that check my previous suggestion of running zm4ms in url mode, just to check all is working before you enable auth. Maybe someone else has tried zm4ms without auth?
James Wilson
