Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
there are checkboxes marked url per cam in zm4ms settings
James Wilson
lol you havnt entered the path in cam 1 you need to enter that path the http://etc all of it where you currently have the ip
James Wilson
You need to use the other path
mode=single
mode=single
James Wilson
i changed the path from:
http://192.168.178.20/cgi-bin/zms?mode=jpeg&monitor=1&scale=100&maxfps=5&rand=1155413298
to
http://192.168.178.20/cgi-bin/zms?mode=single&monitor=1&scale=100&maxfps=5&rand=1155413298
and voila --> the first time i can see a picture.
So fare, so good. Do you think we have the prerequisite now to persuade zm4ms for correct working?
to
yes, the only thing i can think is thats its an authentication issue, try turning auth on in zm and creating a user that can view cameras, then add this user to zm4ms and login with those details
James Wilson
r2 the playback tab is purly playback auth into mysql not for setting anything to do with streaming!
You need to create your user in 'users'If you have left the default admin password at admin and this is still the admin password for zm then you dont need to do anything. eg
create a user in zm called viewer and password of viewer and enable all views
create user 1 in users tab in zm4ms called viewer with password of viewer.
log out of zm4ms and log back in. You should get images. I can only sugggest that you enable rdp for your machine or vnc and i will have a look if the above doesnt work. We must be missing something little somewhere
James Wilson
I noticed on your settings that your ip began
192.168.x.x
but in your settings you had
192.167.x.x
Its working now and i have left it running on you machine mate
192.168.x.x
192.167.x.x
James Wilson
wow.....
This was EXPRESS-HELP.
1000 times thanks
now i will test it and post the results.
btw: if plan a multilanguage Version i can translate it to german
cu
R2D2
1000 times thanks
cu
R2D2
lol mate i knew it would be something silly!
I havnt planned a language version but if demand is there i could though
James Wilson
Noiw it works fine, but whene i click on the green button (Playback) i get the following Error message:
by clicking <OK> a message appears:
An here is the complete Message:
Do you know what this mean
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Argument 'Prompt' cannot be converted to type 'String'.
at Microsoft.VisualBasic.Interaction.MsgBox(Object Prompt, MsgBoxStyle Buttons, Object Title)
at ViseonViewer2.mysql.Button1_Click_1(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.PerformClick()
at ViseonViewer2.Cam1.PlayBut_Click(Object sender, EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.26 (RTM.050727-2600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ViseonViewer2
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Dokumente%20und%20Einstellungen/foo%20foo/Lokale%20Einstellungen/Apps/2.0/Y8TDZT2Y.NWC/OEB2CZAC.ZQ6/vise..tion_84f1c4803f9b5668_0001.0000_49fd59ba2f26e245/ViseonViewer2.exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.26 (RTM.050727-2600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
MySql.Data
Assembly Version: 1.0.7.30072
Win32 Version: 1.0.7.30072
CodeBase: file:///C:/Dokumente%20und%20Einstellungen/foo%20foo/Lokale%20Einstellungen/Apps/2.0/Y8TDZT2Y.NWC/OEB2CZAC.ZQ6/vise..tion_84f1c4803f9b5668_0001.0000_49fd59ba2f26e245/MySql.Data.DLL
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
you need to allow mysql to accept connection from the network on port 3306. I think someone put this in the wiki on how to do it on debian. You need to edit the conf file for mysql and reboot
James Wilson
