jameswilson wrote:you have very slow or high latency upstream mate.
your achieving about 64 k a second maximum. Id chack what else is using that link and do a speed test on it if nothing else is. It just keep pausing and i think its a link issue not a zm issue. It certainly isnt a zm4ms or firefox issue
I have downloaded Zm4Ms from James' site. On initial execution of the app, the main window appears. At this point, if I do absolutely nothing for approximately 30 seconds the app wil crash with a dialog box indicating that Viseon Viewer has encounter a problem and needs to close.
Also, when the main window appears and I immediately attempt to go to settings and change the IP address for my one camera, the app will crash after 30 seconds. I just don't get enough time to save my settings.
It seems as though the app crashes about 30 seconds after it has been executed.
thats bizarre!
do me a favour and nce the app is opened close it properly so it will check its defaults. Then reopen. But i have never seen that before. What does the eroor say
I have logged out of the and exited and restarted an the error still appears.
The dialog box states:
Viseon viewer 2 has encountered a problem and needs to close. We are sorry for the inconvience.
If you were in the middle of something, the information you were working on might be lost.
Please tell microsoft about this problem.
We have created an error report that you can send to help us improve Viseon Viewer 2. We will treat this report as confidential and anonymous
It has a couple of links for a more detailed description of this message and
finally three button options appear: debug, send report and don't send report
ah that is probably assuming then you have a debug environment dont worry.
I can only assume there is a conflict somewhere.
What os is it on, what version of the framwork did you install, and is it up to date. What language are you set to and anything wierd with your time zones or formats. The only thing i can think is that every 30 seconds it checks if it should change the view.
So load the app and next to the main admin settings is a 'user' settings icon. This will load a smallwindow about default view and timer chnage views check enter a valid time in both but dont enable either of them at this point.
James,
OS: XP Professional Version 2002 SP2
Framework version 2.0
Language: English (United States)
Time Zone: GMT-05:00 Eastern Time (US and Canada)
I believe framework was automatically installed by a software package that used a little while back. Also, Dell connects to my machine and occassionally downloads updates to it.
The user dialog:
Startup view 4
Auto switch enabled is UNCHECKED
Custom 1 time is 12:00:00 AM and enabled is UNCHECKED
Custom 2 time is 12:00:00 AM and enabled is UNCHECKED
can you change both times to say 13:00 just for giggles. If that doesnt do it then im at a bit of a loss really, can you have a look in the system application log and see if anything interesting is there
bob im afraid i have no idea then. Do other .net apps function ok. Maybe you could uninstall the framework and the app and resinstall. Do you have another machine to test on
I have one other Net app call Paint.Net. This is a freeware paint program from Microsoft. I believe it's primary purpose is to promote Net. The Paint.Net program works fine. This is the app that migrated me from 1.1 to Net 2.0.
I have an older Windows 2K box but ZM4MS won't install until I upgrade to SP3. I'll download the SP which is 124MB and install it. Then I'll give ZM4MS a try on Windows 2K.
I uninstalled Net 2.0 and out of curiousity, I tried to run Micorosft's Paint.Net. It crashed as would be expectd. So, I rebooted the machine, reinstalled Net 2.0 and executed ZM4MS. I waited for about 30 seconds and it crashed with the standard MS dialog indicating that it had encountered an error and had to close.
I then tried Paint.net and it worked without any problems.
