ZM 1.37.61 - ONVIF event messages issues.
abg
Re: ZM 1.37.61 - ONVIF event messages issues.
Post by abg »
It looks like I got myself some answers.
1. Home Assistant - ZoneMinder ONVIF interference
Indeed it looks like once Home Assistant is connected over ONVIF with the cameras, by starting ZoneMinder and attempting also to connect to the cameras through ONVIF the latter coughs and writes "Failed to get ONVIF messages! 28 Connection refused" in the log.
30.04.2025, 22:37:56 EEST	zmc_m2	2726	ERR	Failed to get ONVIF messages! 28 Connection refused	zm_monitor_onvif.cpp	207
30.04.2025, 22:37:55 EEST	zmc_m1	2704	ERR	Failed to get ONVIF messages! 28 Connection refused	zm_monitor_onvif.cpp	207
30.04.2025, 22:37:46 EEST	zmc_m2	2726	ERR	Failed to get ONVIF messages! 28 Connection refused	zm_monitor_onvif.cpp	207
30.04.2025, 22:37:45 EEST	zmc_m1	2704	ERR	Failed to get ONVIF messages! 28 Connection refused	zm_monitor_onvif.cpp	207
But then if I enter the monitor/camera settings individually for each camera (Console -> Edit Camera -> ONVIF -> SAVE & CLOSE) without modifying any parameters, (I guess) it triggers a fresh ONVIF authentication that is successful:
30.04.2025, 22:38:25 EEST	zmcontrol_1	2876	INF	Control server 1/onvif starting at 25/04/30 22:38:25	zmcontrol.pl	127
30.04.2025, 22:38:25 EEST	zmcontrol_1	2876	INF	Starting control server 1/onvif
So both Home Assistant and Zone Minder can communicate simultaneously with the cameras over ONVIF.
2. Motion detection events (in my case Person Detection - that's configured in the camera "intelligence") over ONVIF are received by Zone Minder (also simultaneously in Home Assistant ), but apparently Zone Minder doesn't know hoe to interpret them. I triggered manually (dancing in front of the camera) a Person Detection event and in the Zone Minder log I got:
30.04.2025, 22:35:58 EEST	zmc_m1	2704	ERR	Failed to get ONVIF messages! 8 (null)	zm_monitor_onvif.cpp	207
30.04.2025, 22:35:38 EEST	zmc_m2	2726	ERR	Failed to get ONVIF messages! 8 (null)	zm_monitor_onvif.cpp	207
30.04.2025, 22:35:37 EEST	zmc_m1	2704	ERR	Failed to get ONVIF messages! 8 (null)	zm_monitor_onvif.cpp	207
3. For Camera 1 I enabled SOAP WSA COMPLIANCE in the ONVIF section and haven't got any error in the log. Went outside, manually triggered (dancing in front of the camera) a Person Detection event and got in the Zone Minder logs the following (focus on zmc_m1):
30.04.2025, 22:48:20 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 1, fault:error, detail:null	zm_monitor_onvif.cpp	108
30.04.2025, 22:48:09 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 8, fault:(null), detail:null	zm_monitor_onvif.cpp	108
30.04.2025, 22:47:58 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 8, fault:(null), detail:null	zm_monitor_onvif.cpp	108
30.04.2025, 22:47:48 EEST	zmc_m1	3039	INF	UHU-1: 1100 - Capturing at 24.99 fps, capturing bandwidth 59865bytes/sec Analysing at 0.00 fps	zm_monitor.cpp	1845
30.04.2025, 22:47:47 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 8, fault:(null), detail:null	zm_monitor_onvif.cpp	108
30.04.2025, 22:47:37 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 8, fault:(null), detail:null	zm_monitor_onvif.cpp	108
30.04.2025, 22:47:26 EEST	zmc_m2	2936	INF	UHU-2: 13200 - Capturing at 24.97 fps, capturing bandwidth 13093bytes/sec Analysing at 0.00 fps	zm_monitor.cpp	1845
30.04.2025, 22:47:25 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 8, fault:(null), detail:null	zm_monitor_onvif.cpp	108
30.04.2025, 22:47:14 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 8, fault:(null), detail:null	zm_monitor_onvif.cpp	108
30.04.2025, 22:47:04 EEST	zmc_m1	3039	INF	UHU-1: 0 - Capturing at 0.00 fps, capturing bandwidth 685bytes/sec Analysing at 0.00 fps	zm_monitor.cpp	1845
30.04.2025, 22:47:04 EEST	zmc_m1	3041	ERR	ONVIF Couldn't create subscription! 8, fault:(null), detail:null
Meanwhile (in parallel /simultaneously) Home Assistant was correctly receiving through ONVIF the Person Detection event - see screenshot with the timestamp:
https://imgur.com/a/54CJdhD
In Home assistant I'm using the "standard" ONVIF integration - source code is here (it's open source - maybe good for inspiration - don't be shy :wink: ):
https://github.com/home-assistant/core/ ... ents/onvif
I noticed in this thread that there were some issues with the ONVIF implementation in the cameras FW - saw a reference to a TP-Link Forum thread. When I bought my TAPO C520WS V1 cameras back in February 2025, my "stock" FW was 1.2.10 Build 241025 Rel.55515n and the Home Assistant ONVIF integration worked perfectly fine with it, no issues whatsoever.
As a side note, I received today word from TP-Link, they're saying that the smart mode (white LED light) during night is not working properly (I understood from their long blabla that the luminosity is too low) and the camera might miss movements (won't record) so they won't fix it. They offered a refund. I guess I'll stick with the IR LEDs only during night. .. a flawed product :x
